Hardwiring a dashcam
Hi everyone!
I've been thinking about getting a dashcam, and am looking for the easiest way to hardwire it. I'll be mounting it behind the rearview mirror, and only want it to activate when the car is active.
I've currently got no experience removing interior panels (on the RDX).
I was thinking of hardwiring the 12v into something near the rearview mirror , such as the auto dimming mirror or the sunroof switch.
Do you think that'd be possible? Or too much of an electrical risk. (3M wire taps)
Thanks in advance.
Thanks in advance.
Ignore the sunroof idea - the switch probably sends the signal to a module
I'd love to wire it through the a pillar, but I haven't got the faintest idea how to remove it. I'd probably yank it if I wasn't sure I'd break the clips!
the pillar is super easy.
you will see a square "button" it should say like airbag or something.
DONT worry. there's no air bag there.
use a butter knife wrapped in a cloth to pry the little square button up.
once the square is up, you can lightly pull on the a pillar from top to bottom to release the clips
TheNewAcura (02-07-2014)
Really? No need to break and replace the little clip that Acura suggests?
The reason I was thinking about using the rearview mirror is because its already wired, like this
SocaliCLS
10-24-2004 05:24 PM
