vtec pressure switch
i was just lookin at the accord helms manual and it says that the wire is blue/black unless im a complete idiot.
The reason for all of this is:
since this swap went down i've been getting "code 22:" which is the vtec pressure valve which has to do with the vtec pressure switch. What i just found out from searching honda-tech is that JDM motors dont come with vtec pressure switches..my motor is a JDM H23A so it obviously doesn't come with a pressure switch, so back when this started happening I swapped on a h22 pressure switch that i thought would fix the problem but of course it did not. So my car has been in limp mode since i swapped the motor and i have had no idea why cuz we've checked everything and i mean everything.
So anyways, i was fucking around on h-t yesterday and found out that since "JDM" motors dont come with pressure switches the way to get rid of the CEL and MAD LIMP MODE is to find the pressure switch wire in the harness and ground it on the chassis then bye bye code 22 and limp mode. So that's what im hoping will fix the problem now i just need to find out the colour of the pressure switch wire.
Also, i would just find it in the engine harness where the pressure switch plug is suppose to be but the shop that did the wiring got rid of it somehow cuz i can't find it.
I don't know if all that made sense but i just put it all out there cuz im tired of not driving my car and not enjoying the time/effort i put into it
/rant
/rant
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
i can't help u, especially if u're looking at the helms manual cuz that's all i have to help, but just wanted to say hi allan.
Ciao Pho Eva eva
Originally Posted by SilverCL97
did your motor come with the switch?
ok so i went down stairs to look again..
theres 2 parts the metal cylinder shaped thing that has 1 green wire coming out of it... and theres a green plug with a brown and green wire coming out of it.. i took a pic with my phone i can post at work tomorrow..
Ciao Pho Eva eva
and JDM motors have pressure switches.. only diff between JDM H22 and regular is internal / external dizzy, and no crank angle sensor..
BUT u do have an H23a.. is it OBDI or II?
i do have that but it didn't come with the motor so i got one off a spare h22 i had lying around. We wired it straight to the ecu and i still get code 22
& my motor is obd2 but i converted to obd1
(Mid-Atlantic)
(Mid-Atlantic)
spare h22 i had lying around luv it, u sound like me
For the OBD1 ecu you can bridge pin A4 to D6 to get rid of this CEL.
I converted to OBD1 and had CEL 22 as well. I disabled the vtec pressure switch it in the ROM using eCtune but bridging those two will do the same thing.
any updates on this? did u figure it out? maybe you should go back and pull out the H22 component u added and ground the wire.
did you figure out what color the wire was? I was cleaning my engine bay and I found out that my VTEC pressure switch on my f23 wasn't plugged in and that the connector is nowhere to be found... I was thinking that maybe the 97's dont have that connector and maybe it's a 98-99 thing only but I don't know,... I have yet to find a wiring diagram that has the pressure switch wire it in... I'm lost
One custom CL
i never used that wire.
the cl harness doesnt come with it. you need it for sure man. you need to wire it. if you get me the exact name of the switch then i can tell you what color the wire should be and the pinout for it. im gonna need this too.
I just checked honda estore and they show the 2.2 CL having the vtec pressure switch which is what I assumed since a vtec car needs to have that connector in order for vtec to engage... I just don't know why the connector is nowhere to be found on my car. I have the vtec pressure switch on my f23a1 engine and I saw a diagram showing that the 2.2 CL ecu has the pin out for the vtec pressure switch... this is really confusing me...
IBankMouse
06-13-2020 12:53 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
xsilverhawkx
09-28-2015 06:51 PM
