Brakes
Brakes
Brakes
Rotors are from 94-97 accord.
Dual piston calipers can be fit into car. Parts needed are Calipers from a Legend. Rotors are from a 92-96 Prelude VTEC or 3.0 CL and Legend Pads. For the Legend Calipers, Type II equipped including the GS sedan or LS coupe, 93-95. are the only kind with dual piston so you will need to locate these types. 2.2/2.3 needs the caliper brackets from 3.0CL, Legend, or 94-96 vtec prelude. Adding this will give you larger rotors and dual piston calipers for greater stopping power.
NOTE: The 97 front rotors are a hub-over-rotor design which means that you'll need to get them pressed on and off with a machine. Most places charge $200+ for this kind of job. Just FYI.
The following 2 users liked this post by saiko_cl_duck:
bamaborn74 (02-11-2014),
Murda1 (05-21-2018)
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
