Brakes
Old May 20, 2010 | 10:14 AM
saiko_cl_duck's Avatar
Brakes
Brakes
Rotors are from 94-97 accord.
Dual piston calipers can be fit into car. Parts needed are Calipers from a Legend. Rotors are from a 92-96 Prelude VTEC or 3.0 CL and Legend Pads. For the Legend Calipers, Type II equipped including the GS sedan or LS coupe, 93-95. are the only kind with dual piston so you will need to locate these types. 2.2/2.3 needs the caliper brackets from 3.0CL, Legend, or 94-96 vtec prelude. Adding this will give you larger rotors and dual piston calipers for greater stopping power.
NOTE: The 97 front rotors are a hub-over-rotor design which means that you'll need to get them pressed on and off with a machine. Most places charge $200+ for this kind of job. Just FYI.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
