Excelerate Performance A full service speed shop offering performance parts for your Acura
Excelerate Performance: Ingalls Camber Kits and Engine Torque Dampers
Old Feb 28, 2011 | 07:19 PM
Excelerate's Avatar
Former Sponsor
This is an Acurazine Special Sales Event for Ingalls' Camber Kits and the Engine Torque Damper. The pricing event will consist of the Ingalls' Camber Kits for Acura vehicles.
Ingalls Adjustable Front Upper Control Arm Ball Joint
Featuring the lowest profile of any adjustable ball joint on the market. These ball joints replace the non-adjustable O.E. ball joint and are indexed to make accurate installation easy. Ingalls Engineering Company’s patented adjustable ball joints have ample stud travel to eliminate binding. They also include a larger stud base and heavy-duty boot and retainer for long service life.
Ingalls SmartArm Rear Adjustable Lower Links (Rubber) Replaces Both Lower Arms. ONLY Honda/Acura kit that properly adjusts camber and toe!
Newly redesigned, SmartArm Links feature forged steel ends for maximum strength. Most can be installed either on the left or right side of the vehicle (depending on application) with an adjustment range from -2° to +3° depending on the application.
A self-contained elastomeric shock that mounts on brackets between the engine and the chassis. It reduces extreme engine movement and dampens the motion, providing many benefits:
- Greatly improved off-the-line acceleration
- Reduced wheel hop
- Improved vehicle stability
- Reduced shock loads on driveline components
- Smoother shifting
- Reduced wear on exhaust system joints
- Less vibration transmission to the driver compared to polyurethane motor mounts.
- Less shock load, compared to torque straps and chains.
- Drifting – helps reduce shock loads when wheels gain traction.
- Reduces motor movement – decreases the chance of motor parts rubbing against the hood and frame.
http://store.excelerateperformance.c...202&Make=ACURA
Here are links to some of the more common kit parts:
Acura: 01-03 CL, 96 - 08 TL, 04-08 TSX- Front Camber Kit Part #35590
http://store.excelerateperformance.c...0/i-60159.aspx
Acura: 01-03 CL, 96 - 08 TL, 04-08 TSX- Front Camber Kit Part #35591
http://store.excelerateperformance.c...1/i-60160.aspx
Acura: 99-02 TL, 03 TL*, 01-03 CL- Rear Camber Kit Part #38720
http://store.excelerateperformance.c...0/i-60219.aspx
Acure: 03 TL*, 04-08 TSX, 03-06 3.5 RL- Rear Camber Kit Part #38725
http://store.excelerateperformance.c...5/i-60220.aspx
*38725 for Vehicles with un-equal length arms, 38720 for vehicles with equal length arms.
In order to determine what camber kit you need it is best to have an alignment first so that you can determine how much your camber is off. Ingalls recommends certain part #'s based on ride height drop. Therefore we recommend part #'s based on specific ride height drops, but it is not definitive nor 100% accurate. Therefore it is the responsibility of the consumer to determine what kit they need.
AIM Screen Name: Excelerate04
E-mail: Sales@ExceleratePerformance.com
or PM me.
RETURN POLICY
- ALL RETURNED AND/OR CANCELLED ORDERS ARE SUBJECT TO A 25% RE-STOCKING FEE PLUS ALL SHIPPING CHARGES (Includes original and return S&H fees).
- ALL AUTHORIZED RETURN MERCHANDISE MUST BE NEW, UNUSED, AND IN ITS ORIGINAL PACKAGING. ALL DOCUMENTATION, WARRANTY CARDS, INSTRUCTIONS, AND HARDWARE MUST ALSO BE RETURNED.
- ITEMS MAY BE RETURNED WITHIN 15 CALENDAR DAYS FROM THE RECEIPT OF MERCHANDISE.
- SPECIAL ORDERS ARE NOT RETURNABLE.
- ALL DEPOSITS ARE NON-REFUNDABLE.
EXCELERATE LLC
998 West Main St
Branford, CT 06405
(P) 203-483-6100 (F) 203-483-6101
www.ExceleratePerformance.com
Old Mar 23, 2011 | 11:32 PM
gremlin714's Avatar
can u pm me prices on a camber kit, front and rear for 05 tl, 92801
Old May 10, 2011 | 11:44 AM
NSXCessive's Avatar
Originally Posted by Excelerate
This is an Acurazine Special Sales Event for Ingalls' Camber Kits and the Engine Torque Damper. The pricing event will consist of the Ingalls' Camber Kits for Acura vehicles....
I'm also interested in a kit for the Rear Camber for my '05 Base TL. Is the sale still going on and if so is the price listed on your website the sale price?
How does this compare to the Spc/Eibach version?
Thanks,
Old May 10, 2011 | 12:57 PM
Excelerate's Avatar
Former Sponsor
Thanks,
The website price is the sale price. The Ingalls rear kit for the 3rd gen TL includes 2 arms: 1 for camber and 1 for toe.
You need a qty of 2 of these.
Old May 10, 2011 | 01:30 PM
NSXCessive's Avatar
Ah I think I got you now, I didn't know the Ingalls kit are 2 separate arms so the Spc is only the single arm? I know there are 4 arms back there the Upper, Lower, Control and Trailing arms. So I'm assuming the Ingalls replace arms 'Upper' for Camber and 'Lower' for Toe on the rear correct?
I will be installing Tein Basic's shortly and already have Spc front, and wanted to get the rear shortly.
Old May 10, 2011 | 04:45 PM
Excelerate's Avatar
Former Sponsor
It's the 2 rear arms. Take a look at the instructions to see more specifics.
http://www.ingallseng.com/Instructions/38725.pdf
Old May 10, 2011 | 10:17 PM
thisaznboi88's Avatar
Hey,
Do you sell the custom brackets to mount the ingall td behind the rear mount by itself? (I already have the TQ dampener. )I saw in a post that you had it for the TL. I wanted to know would it work in the accord. I know Sean had something similar, but he hasn't been responding. So just let me know what you got.
Thanks,
Ken
Old May 11, 2011 | 05:38 PM
Excelerate's Avatar
Former Sponsor
Originally Posted by thisaznboi88
Hey,
Thanks,
Ken
I'm not sure if it fits on the Accord. However, we could sell the bracket separately for $100.
Old May 13, 2011 | 10:26 AM
unlimited's Avatar
im interested in the rear camber kit, does the kit come in a pair, or will i need to order two?
Old May 13, 2011 | 05:17 PM
Excelerate's Avatar
Former Sponsor
You need a qty of 2 to complete the rear of the car.1 kit does one side of the car.
Old May 23, 2011 | 11:48 AM
jkr_j32a2's Avatar
C E R T I F I E D
After my alignment, what should I be looking for in order to determine which front kit to buy?
Old May 23, 2011 | 05:18 PM
Excelerate's Avatar
Former Sponsor
If you have less than +1.5 to -1.5 degrees of camber you want part # 35590 (qty of 2).
If you have -1.5 to -3.0 degrees of camber you want part # 35591 (qty of 2).
Old May 31, 2011 | 04:20 AM
nokiaboy808's Avatar
06 6spd TL BAGGED
do you sell just the the toe arm's for a 2006 TL? I already have the camber arms thats why.
Old May 31, 2011 | 04:59 PM
Excelerate's Avatar
Former Sponsor
The kits only come complete. Sorry.
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
ExcelerateRep
Dec 11, 2015 12:58 PM
Sep 14, 2015 03:16 PM
nuldabz
Sep 3, 2015 05:49 PM
