Transmission fluid change
Old 04-24-2011 | 12:22 PM
Bankz's Avatar
Looking for a cheap but good place to do a transmission fluid change
Old 04-24-2011 | 02:25 PM
gnuts's Avatar
3.5 psi
DIY. I did mine in my driveway and no garage, no experience.
Old 04-24-2011 | 03:12 PM
Bankz's Avatar
how did that go gnuts
Old 04-25-2011 | 12:56 PM
gnuts's Avatar
3.5 psi
i found a DIY on this site (for my CL). Jack the car up...make sure it's level. Drain the fluid, put bolt back in, full with new fluid until fluid comes out of the check bolt, then put the check bolt back on. Done. I used Amsoil synthetic MTF fluid.
Old 04-25-2011 | 07:46 PM
Bankz's Avatar
what type of fluid should i use for my 05tl
Old 04-26-2011 | 11:34 AM
gnuts's Avatar
3.5 psi
just stick with Honda ATF or MTF. GM Synchromesh and Amsoil are probably the best, but are more expensive.
Old 04-26-2011 | 06:39 PM
Bankz's Avatar
thanks
Old 04-28-2011 | 06:11 AM
Locomaaan's Avatar
Gm synchromesh is great im loving it right now. Gear changes are so smooth.
Old 04-28-2011 | 08:11 AM
TmaX's Avatar
UA7 6MT
Whatever you don't use Honda ATF/MTF.
Stick with Amsoil at the very least and GM Synchromesh if you have a MT.
You pay a little bit more upfront now to save you a lot more down the line.
I have done the 3x3 with Amsoil ATF shortly after purchasing my TL and it made a world of difference performance wise and will help your engine last longer.
If your looking for someone to do it for at an inexpensive price check out Chi @ 360 Auto in Markham.
But like gnuts said it is definitely something you could DIY once the weather warms up with just a lift.
Old 04-28-2011 | 10:55 AM
gnuts's Avatar
3.5 psi
Ya you get what you paid for. I wouldn't say the honda ones are "bad" but the other ones mentioned are on a different level. I used Amsoil and loved it.
cobra10363
07-23-2024 04:13 PM
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
fifer16
1G RL (1996-2004)
10-16-2015 08:54 AM
quake97
08-30-2015 07:57 PM
Quick Reply: Transmission fluid change
