Need help installing HID fogs
Can anyone explain the process, i've never installed lights in my life.. especially not ones with ballasts.
Do i have to remove the bumper or just put it on a hoist/jack?
If you aren't installing a relay you can just go through the wheel well. Both sides can be done in like 10 mins. The bulb itself should have 3 connectors for the ballast, and then 1 additional connector for your stock harness. Then just find a place to mount the ballasts and you're good.
haha well good luck. It's pretty hard to mess it up so you should be fine. And yep, just crank your wheel all the way to the right to get access to the left wheel well, and obviously the opposite way for the other wheel well. No need to lift the car. The only thing you'll struggle with is the limited space to do everything, but it can still be done with some patience.
haha no worries bro let me know and you dnt need a jack dont worry about that lolz . also when i shift from park to drive or reverse theres a slight jerk... am i the only one or are others facing the same thing ?
Good info regarding the transmission jerk
https://acurazine.com/forums/3g-tl-problems-fixes-114/p-d-hesitation-jerk-then-normal-831034/
take bumper off, it makes for a easier and cleaner job. Taking the bumper off may seem intimidating at first, but its really simple. Theres a video of it on youtube somewhere as well.
My Hid fogs should be arriving next week. Going to install them along with daytime drls
You must have some special clips cause 3 of mine snapped when I was taking off my rear bumper. Be careful with them OP if you do decide to take the bumper off. I haven't done it yet, but I'm assuming it's similar to the rear bumper, just with more bolts, clips and screws. It's an easy job, the only thing you'll break are the clips haha
