caliper seize
Old Apr 2, 2014 | 09:56 PM
buchwheat's Avatar
caliper seize
hello everybody car has been in storage, just last week tried to move it, rear passenger caliper seize solid doesn't want to move, what to do now.
Old Apr 2, 2014 | 10:48 PM
guitarplayer16's Avatar
Buy new caliper.
I've had to replace my rear right caliper in 2010 ($720 job at the dealer; never again), and my rear left caliper in 2013 (bought remanufactured caliper from Advance Auto Parts).
Have to replace my rear right caliper again this year because the mechanic snapped off the bleeder valve.
Old Apr 3, 2014 | 02:15 AM
ATLS_666's Avatar
3 2 GONE
Was your handbrake up?
Old Apr 3, 2014 | 08:08 AM
gnuts's Avatar
3.5 psi
not sure if you're a manual, but don't leave the parking brake up, just leave it in neutral and chalk the wheels or leave it in gear. That said i left my winter beater (automatic) parked for a while and my father put the ebrake on. It was stuck and i had to take a dead blow hammer to it to pop it loose. Never had to replace anything.
Old Apr 3, 2014 | 10:36 AM
ATLS_666's Avatar
3 2 GONE
What Gnuts said. I had mine seize over the summer and had to hammer it loose. Ebrake always stays down when leaving for a few days.
Old Apr 3, 2014 | 07:11 PM
buchwheat's Avatar
mine is 6mt, no, I never put on my ebrake, maybe I'll try to hammer the caliper from inside see what happens, thanks
Old Apr 13, 2014 | 09:28 PM
Tonyware's Avatar
'20 TLX SH-AWD A-Spec
There may be a chance to save the caliper if you remove the 2 bolts that hold the piston part of it together and spray some PB Blaster on top, at the edges of the piston and leave it there for a few minutes. After 10-20 minutes try to rotate it clock-wise to see if it loosened up a bit. Again, this isn't too safe to do in the long run but it may get you going for a bit. Eventually you'll have to change it.
Old Apr 13, 2014 | 09:35 PM
the TL's rear calipers like to seize.
moisture in the fluid?
Old Apr 14, 2014 | 09:19 PM
buchwheat's Avatar
got it fixed for now, took the wheel off and beat the rotor drum with a hammer and it loosen up, will have to get my mechanic to service my brakes before I take it off storage.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
polish_pat
Sep 30, 2015 12:22 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
