Want to install Springs.
ok just asking because most poeple use aftermarket. A lot of people on the zine were telling me to use aftermarket not oem.
im still guessing on what i should do either use my oem or aftermarket shocks/struts. if you do just use oem shocks, post a pic up i would like to see the turn out.
If you have time, DIY.
If not, call around.
I'm not from Toronto, but from what I know, most people on here will tell you to visit a shop that charges a lot.
I find best mechanics are the ones that worked at a shop but now work from their home.
Usually these mechanics are found by "word of mouth".
There's a member on here that charges $50 an hour, which is a super price.
I would contact him.
Here in Ottawa, I have a guy that works from his home, used to work at a shop for 25 years. Changed my front engine mount for $40 while other shops were asking $100-$120.
I msged the mechanic in his thread here and emailed him so I'll see if he responds.
$600 is WAY to much. Where im from the most was $320 but i found someone that does work for $50 an hour, and im going to pay maybe under $200. keep looking dude you'll find a good deal some where some how lol good luck tho.
Average price should be around $250 to change suspension.
$600 is something else...maybe they give you a massage while you wait, I don't know lol
I decided to DIY after hearing it costs $250.
Let's not get too side tracked haha unless one or two of you want to help me give it a go...
H&R DIY Installation
I changed suspension on my TL twice. It's mostly a 1 man job and should not take more then 3 - 4 hours even with jack stands on the floor. A second set of hands do come useful at times. However I do not recommend you using the stock shock unless you wanna do it all over again or pay someone in a few months or a year tops. I did shocks and springs the first time then changed to coil-overs. Save your self some money, labour and headaches and do it right the first time around. GET COIL-OVERS!
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
Zonian22
Nov 14, 2015 01:20 PM
... your OLD OEM STOCK SHOCKS will not last long once you lower it!
