Installation instructions for 2016 RDX LED fog lights
I am considering order OEM Acura 2016 LED fog lights. Does anyone have an pdf instructions/and/or tips for installation?
I thought you have to remove the bumper and get into the dash?
Seems like a lot of work?
Popular Reply
Jun 28, 2015, 05:07 PM
Alright everyone, as promised I snapped some photos during the install for you guys of the LED foglights.
Make: Morimoto
Model: XB (type s) standalone
Temp: 5000k LED
Price: $170 + shipping or $190 + shipping with yellow Laminx film
Tools: Flat head screwdriver, a short and medium phillips screwdrivers
Installation time: 20-30 minutes
Looking from underneath the front bumper prey off the 4 "bitch clips" that hold the bottom plastic to the bumper:
Once you have removed the clips you then want to remove the one screw that holds the bumper to the fender:
After this you will have full access to the foglight housing with plenty of room to work:
To remove the OEM foglight, disconnect the connector from the bulb. Then there are two phillips screws diagonal from each other you want to remove from the back of the foglight. This is where you will need two different size phillips screwdrivers:
After that the foglight comes right out. Here is a comparison between the two:
The next step is to connect the power and ground wires to the supplied female plug in the kit. Make sure you check your factory plug to match the new one. Black goes with black and red goes with white:
Screw in the Morimoto Foglight, connect the plug and reinstall the splash guard and repeat the steps for the opposite side.
Before:
After:
I also installed the same kit on my 2014 TL but with the yellow Laminx they provide. They also turned out really nice:
Overall Impression: Honestly it was worth every penny. Just as nice as the factory option LEDs in my opinion. They shoot a sharp beam just like the Diamond LEDs or HID's with projectors. The install was super easy (plug and play). Best of all the 5000k match the Diamond LEDS perfectly. Same exact color. The 5000k with yellow laminx is a really nice crisp yellow. I highly recommend these for anyone looking to upgrade their factory fogs.
Make: Morimoto
Temp: 5000k LED
Before:
After:
You can find the accessories installation instruction in the following link. https://estore.honda.com/acura/acces...&modelName=RDX
Installation doesn't look too bad. I have the 2016 Advance and swapping the factory dogs for Morimoto XB 5k LED Foglights. Direct replacement with OEM fitment.
Morimoto's are around $200 instead of $675.
Thanks in advance.
Foglights arrive tomorrow. Not sure if I'll have time to install after work so most likely they'll be on Saturday. I'll post pictures of the RDX and TL with them to give everyone an idea of the yellow and white XB's look like since I ordered both pairs.
Sounds good, carbonTSEX. I'm looking forward to it.
Make: Morimoto
Temp: 5000k LED
Attachment 46622
Attachment 46623
Attachment 46624
Attachment 46625
Attachment 46626
Attachment 46627
Before:
Attachment 46628
After:
Attachment 46629
Attachment 46630
Attachment 46631
Attachment 46632
Make: Morimoto
Temp: 5000k LED
Attachment 46622
Attachment 46623
Attachment 46624
Attachment 46625
Attachment 46626
Attachment 46627
Before:
Attachment 46628
After:
Attachment 46629
Attachment 46630
Attachment 46631
Attachment 46632
Sticky under the 2G Garage?
Thanks for the detailed install pictures.
I just picked up my new 2016 Graphite Luster Advanced Package this morning and ordered a set these lights from Amazon this afternoon. I really can't stand mismatched color temps. between the factory lights (not just an Acura problem). For $600+ I was just going to leave the fogs turned off but for $170 plus easy installation I'm all over this mod.
Excellent thread and thanks for taking the time to document the install.
I'm still considering an RDX with the Advanced package and was going to purchase the LED fog lights as an accessory. If I do decide to the pull the trigger on an RDX I'll definitely be skipping that option and save some money by purchasing and installing these instead.
Car looks great!
Car looks great!
Excellent thread thanks guys. Just picked up my graphite/greystone 16 Adv today. The salesperson was under the impression the fogs were LED. Today she learned something. I will be ordering my Mori's today
Glad I am able to help everyone out and find an alternative that cost less with just as good quality. You could run 3 sets of the morimoto's for the price the dealer charges. Installation is really quick and easy too. Great mod for all RDX owners. I've had no issues with them since install, they are super bright and color is just about identically to the DRLs and HIDs on the 16's. Feel free to add your pictures before and after install if you'd like.
My dealer is a Acurazine vendor and I get a great discount but not on the Morimoto's. If you think $170 is a little pricey, you can always wait for theretrofitsource to have a sale like 20% off but not gonna get much lower then that. When you compare these with other fog light options, these are by far the best (personal opinion).
Enjoy and happy modding.
Now for license plate lights and door curtiousy lights those are perfect.
Can anyone who has done this install successfully post up the adapter that came with their fog lights to help me set my mind at ease before I waste my time opening up the bumper to find out I'm screwed?
Thanks all!
Hi Giovane, how did you determine that from oemacuraparts.com, regarding 1st gen vs 2nd gen and 2016s? I get different part numbers searching there. I may be missing something - I am looking at the fog lights for the 2016 as an accessory, whereas they were standard equipment in 2008. Thanks.
Hey sorry I just read this. The connector does look correct. Was it already connected or did you have to plug the wire prongs thru the females plug? Mine was the same, had to put it to put it together. Just make sure the wires are in the correct way or you'll have a hard time getting them out clean Aniyah the reuse them. It literally takes no time to open the bumper like I showed. Let us know how it goes.
Thanks to all for the great DIY instructions and the feedback!
Question, with the extra length of cable added with the morimotos, how did you secure it to avoid contact with the other surfaces?
Just got mine installed yesterday into a Canadian model RDX.
Note: Passenger side fog light: The top right fog light mounting screw is hidden behind the windshield washer fluid storage tank. You will need a small angle screw driver to get to the self tapping screw.
You can order the fogs through a Canadian supplier.
OEM fog lights are quite expansive because they come with bumper trims, harness, dashboard lever and of course bulbs.
I wonder how much they would cost without the whole bundle, just the bulbs.
Here's a thread on the ILX subforum where a user shows the OEM LEDs.
https://acurazine.com/forums/photogr...-light-930621/
I tried to check online for the Koito brand and serials but I had no luck.
I seen the kit sold online and the price for the OEM LED fog lights is ~ 450 USD.
I ordered the Morimoto fogs via a Canadian supplier and installed yellow Lamin-X on them. They look super slick.
