Shorter strokes
Yes it is!
Shorter strokes
Kind of an odd request for advice. I lurk here a lot but barely post. Finally have a question and you guys seem to be pretty experienced.
This happened last night. While in the act, my partner and I got into the doggy-style position, which is a position she seems to be able to come in more easily than others. Getting her to orgasim (in any position) doesn't happen every time and is sort of an accomplishment, which is why I like to do it.
Problem is, in order to get her there she likes it a little fast and rough. Last night I almost had her to the point, but she couldn't ignore the pain anymore before we had to stop. Turns out I was actually bottoming out and nailing her cervix. Ouch.
So I guess my question is, is there an effective method to keep my strokes shorter, while maintaining a fast and hard rhythm? Is there some way to modify the doggy-style position, or is there another position all together where I can effectively angle my wang up on her G-spot and go pretty fast without worrying about bottoming out like that?
Is this your way of telling the world you have a large cock?
My first Avatar....
If you are behind her - your hips have to be ABOVE (higher) than hers. You might try a squatting position, with your feet on the surface. Not kneeling with your knees on the surface. This is tough on your thighs if your legs are not up to it though.
If you are on top of her - your hips have to be BELOW hers. You can try pillows under her hips or extend your legs so they are next to her torso. this puts you into a sitting position, instead of a kneeling position. These positions should give you good angles.
have fun experimenting and be patient with each other, you'll get it right.
Wants an M3 in
Here is an idea ... Have her lay on her stomach then enter from behind. You can either lay on her back or basically sit on the back of her thighs. I love this position and if she has ANY sort of rear end there is an automatic cushion so your entire member wont be able to go in! Usually feels the same/better than doggy.
Good luck!
Good luck!
50? you must be kidding!
they're right, angel down a bit during penetration from behind, it makes your entry shorter, and concentrates the strokes on the front of her opening where a lot of the feeling comes from...for her...
yeah i'm bored.
Good luck!
Good luck!
awesome postion...makes her ass feel so nice too!
Yes it is!
Good luck!
Good luck!
Seems like quite the angle though. Would you recommend a pillow under her hips or something?
Good luck!
Good luck!
Yep. Definitely one of my favorites. The angle makes the pussy feel really tight.
perfect situation to use that old cliche "different strokes for different folks". :wink:
Good luck!
Good luck!
friend of fast
that's funny i just got done a few minutes ago and i jump on the site and there is this. that position with the butt as a cushion works wonders, i just did it and it ended in her saying...getontopofmerightnow...haha. just remember to kiss on her neck/shoulders/back first...
Why I watch sci-fi...
Originally Posted by Deity711
Yeah, this sounds like exactly what I was looking for. I'll have to give it a shot sometime soon, thanks!
Yes it is!
I tried to get into that position a few weeks ago and it was a no go. She didn't nix it altogether but was for some reason not in the mood for it. Something tells me she's tried that position before and wasn't thrilled.
Good news is I took the "angle down" advice and that's working pretty well. Different pieces of furniture producing different (good) results. When I bottomed out she was on her bed, but it works better on my bed (even though I think mine is higher) for some reason. She kneels on the bed while I stand on the floor, FYI.
We have this problem a lot, too. He bottoms out on my cervix a lot and it fucking hurts. It's a weird feeling, too... it's not really a pain, as much as it is an ache. A slow, spreading ache that gets worse with every bump.
So we've tried the position where I lay down flat, which does feel awesome, but you don't get the opportunity to go very fast that way, which I think you said she *needs* to get off.
I've found that the real *trick* to being able to do doggy style comfortably is to start off in another position. It's boring, but missionary is the best position to start off in because it's the most comfortable initially and it gives the girl-parts a chance to warm up and stretch out. Once you both get into it, you can flip her over and go to town.
Also, make sure she arches her back so that her butt is pointing upward but her lower spine/stomach is pointing downward (like a stripper). In this position, you can hold onto her hips/ass as you go in, thereby giving you more control over how deeply you go.
09-17-2015 09:01 PM
gavriil
12-15-2003 03:59 PM
