g-spot
dɐɹɔ ǝɥʇ ʇɐɥʍ
Below the belly button on her "front side", though its not as accessible on some woman as other's and if you have not been intimate with a woman for a LONG time don't just attack the g-spot with out a lot of other stimulation, it will probably be very awkward for her. Though, if and when you know a woman well, you can ignore the clit and produce a g-spot orgasm which is very intense and she will be your slave afterwards. But like I said some woman have an easier to find g-spot then other's. The best way to stimulate it with your wang is to put a pillow under her lowerback(this changes the angle of her hips) and apply pressure below her belly button with your hand while doing it in the missionary position, when you hit it she will let you know and eventually will start making carnal animal noises that are uncontrolable, in particular if she's never experienced g-spot stimulation before. It helps if your wang points slightly upwards naturally, 110º angle is optimal.
Good luck and godspeed!
Originally Posted by Jack_n_Coke
If only all men knew where it is, that would save them from getting embarassed for asking directions.
I keeps it real
1 Post
WTF, ya'll are funny.
Its a spongy piece of tissue on the front wall of the vagina. To locate the G-spot, turn your palm upward to face the ceiling and insert two fingers into her vagina. Feel the upper surface of the vaginal wall for a rough-feeling bump about the size of a half a walnut. The surface here may feel kind of ridged, like the roof of your mouth just behind your front teeth. If you insert your fingers all the way into her vagina, then bend them slightly like you’re beckoning someone towards you and start to pull them out, your fingertips should bump right into and come to rest on the G-spot. It should feel firm, but a little squishy.
Received 2,329 Likes
Andrew
Just do a move I call the "claw"
She'll practically rape you at that point.
Go Giants
Who's G-Unit???
I find that careful play can fold G-spot stimulation into an overall "gestalt' that makes the vaginal orgasm incredibly powerful, and allows quite a "ripple effect' to continue for some time to follow. Kind of a miracle to watch and share......
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by Always Dirty
Looks like you missed a couple of hairs shaving...
tiguy99
Dating & Relationships
14
02-08-2006 10:32 PM
