What grill are you using?
Old May 10, 2016 | 03:09 PM
  #201
CCColtsicehockey's Avatar
Good idea. Right now all I have is a plastic scraper. Going to get one of those metal chain pieces Sam suggested too.
When I am done washing them I have been paper towel drying them and then putting them on the stove for about 5min over medium heat to fully dry it.
Made some spicey garlic shrimp last night in the pan. Was so good I wish I had more shrimp. Between 2 of us we went through 2lbs of shrimp.
Maybe I should start a cast iron thread so we don't keep taking up the grill thread.
Old May 10, 2016 | 03:11 PM
  #202
stogie1020's Avatar
Needs more Lemon Pledge
Do Eeeeett!
I don't know how aggressive you really need to be with the pan, I mean, you should be able to clean it just fine with a green scrubber... I have never had any issues getting it clean with just a green scrubber.
Old May 10, 2016 | 03:13 PM
  #203
maharajamd's Avatar
+1 on a permanent scrubber for the cast irons. I usually scrub my pans with olive oil and and then wipe off the excess.
You all know the tip for cooking the best crisp bacon? Start the bacon on a cold pan/griddle. Presto! Funny after all these years I still learn new simple things.
Old May 11, 2016 | 11:01 AM
  #204
The first time I burnt the bacon a litte. It cooked so much faster in the cast iron compared to what I was used to in a regular pan.
I also need to get a larger cast iron pan it seems. My largest is a 10in pan and it sucks for bacon as I can barely fit 5 strips in the pan which is just not enough bacon.
The seccond go around it came out great. Not too crispy but not too soft. Do you drain some grease while cooking or just keep it all in the pan while cooking?
I am however having trouble cleaning it after use. There is some brown stuff left in the pan. Is it bad to leave that or should do I need to clean it up better? One other question is do I oil it once I am done cooking with it or did it get oil from me cooking in it?
I don't drain it but it's up to you. I do between batches but not in the same set.
Some brown stuff is ok but it should be pretty clean. The chain scrubber will fix all of those problems.
No need to paper dry, just dump the excess out and use heat for the rest. Always oil after every cook. Once you have it on the stove and it's completely dry, give it a thin coat over the whole pan to add to the seasoning.
Do Eeeeett!
Don't use a green scrubber on a cast iron! It'll abrade the coating. Use a chainmail scrubber or a plastic one to scrub. Neither will destroy the coating. The chainmail scrubber is easily one of the best things for cast iron, I HIGHLY recommend it. Also never use olive oil, smoke point is too low and your food will taste burnt.
Old May 11, 2016 | 11:21 AM
  #205
stogie1020's Avatar
Not sure i understand how a metal chain is less abrasive than a green scrubber, but I will take your word for it.
Old May 11, 2016 | 05:07 PM
  #206
Because each link is a circle, not a jagged edge. It feels like silk when it's in your hands. srs, buy one and try it.
Old May 18, 2016 | 09:08 AM
  #207
maharajamd's Avatar
I ALWAYS clean and finish with a extra light olive oil before storing. Not cook with.
However, I think you'd be surprised how small the smoke point temperatures are between oils. Not all oils are created or refined equally.
This is not rocket science. Lol.
Also I use a nylon scrubber for my cast irons and pizza stones.
Old May 18, 2016 | 09:35 AM
  #208
Ringer is extremely soft and non abrasive and perfect for the cast iron! I love mine
I clean/finish with coconut oil
Old May 19, 2016 | 09:53 AM
  #209
Nylon is probably fine, it's much softer than steel.
Olive oil coating will smoke before you get to a sear temp. You want the highest smoke point oil (flaxseed to be specific) for the coating and can use less for cooking.
The smoke points for various types of oil vary quite a lot...not sure what you're talking about.
Old May 19, 2016 | 10:16 AM
  #210
maharajamd's Avatar
This will be my last post about damn pans. Lol.
- You don't really use flaxseed oil because of it's smoke point. You also don't continue to use flaxseed every time. You don't cook with it. It's something you do once...like breaking in brake pads. Because there is a process there you won't do every time you use the pan.
- Nylon is fine...it was literally made for this purpose.
- Cleaning oil != cooking oil
- HUGE range in oil smoke points. There can be a HUGE range in olive oils alone. Thus my comment.
Old May 19, 2016 | 10:52 AM
  #211
Correct, not every time you use it or after every use, just for initial seasoning and not during cooking.
Yes you do because the higher the smoke point, the harder it is to get it off during normal cooking.
Nylon was made for other purposes but I know what you're trying to say.
There's a huge range in olive oil depending on how it's processed but the general EVOO that people use has a pretty low smoke point.
Old May 19, 2016 | 12:59 PM
  #212
Damn I should have gotten flaxseed then. It was right next to the Safflower oil I got and for the same price.
Old May 19, 2016 | 01:00 PM
  #213
Oh and you guys know there is a Cast Iron Thread now too
Old May 23, 2016 | 04:11 PM
  #214
NSXNEXT's Avatar
Picked up a used Weber Genesis Gold B for the mountain house for $150. Owner replaced the flavorizer bars and grates. That's about $100 right there.
It's in amazing condition. Here's a stock photo.
I have a Gold C at home that is 12 years old and still in amazing shape.
File Type: jpg
Old May 30, 2016 | 01:47 PM
  #215
Legend2TL's Avatar
AZ Community Team
New S/S burner tubes, $18 on Amazon.
Old tubes were corroded and warped
Old May 30, 2016 | 01:52 PM
  #216
Legend2TL's Avatar
AZ Community Team
Memorial day cookout at a friends house, they have a high-end custom egg charcoal grill. Excellent for temperature control, from smoking to high end grilling
Flank steak pinwheels with prosciutto
Old May 30, 2016 | 03:24 PM
  #217
stogie1020's Avatar
^yum!
Old Jul 12, 2016 | 01:46 AM
  #218
nfnsquared's Avatar
Anyone have/used a pellet grill/smoker, e.g. RecTec, Traeger, Yoder, Mak?
Re: smoke boxes:
https://www.amazon.com/Amazen-Pellet.../dp/B00CS6YFIC
Old Jul 17, 2016 | 07:55 PM
  #219
stogie1020's Avatar
I have a tiny charcoal grill. mainly just for kabobs/shashlik, but I had a tough time getting the briquettes to light. I didn't want to use lighter fluid because I think it makes the food taste weird, but I didn't need one of the full size chimney starters from Weber that are about $15. Also, I kind of wanted to make one myself... Seemed pretty easy.
I started with a large 105oz can. I used hominy because it was the cheapest product I could fin in the store in that sized can.
I stripped the label, tossed the hominy in the disposal, and discarded both lids.
Then I took some mesh rabbit-fence I had in the garage and cut a square slightly larger than the opening of the can. I cut this square halfway down the center and folded into a slight cone and secured it to itself with the left over wire sections. I trimmed the outer edges of the cone a bit and then forced it into the can about 3/4 of the way down. It sticks into the grooves in the can and stays put nicely. Knowing I would need to tip the can over to dump out the coals, I dremmeled two slots into the can and then used a folded over section of the wire fencing to make a handle.
All I will probably need to do (need to see how it burns) is make a few vent in the lower edge to let some air inside... I have a few starter cubes, so maybe I wont need too much air, but we will see. I can always just put it on top of a few stones or briquettes to let air underneath it.
Inaugural run is this evening for some lamb skewers...
Old Jul 18, 2016 | 09:06 AM
  #220
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Old Jul 18, 2016 | 09:14 AM
  #221
Nicks2001tl's Avatar
Looks good! Drilling some 3/4 inch holes towards the bottom will only make it work better bringing more air to the briquettes.
Don`t like lighter fluid either. If you don`t have a charcoal starter, crumple up some newspaper and put it under the bottom grate and then but the briquettes on top. It` hit or miss (not enough room or air).
Old Jul 18, 2016 | 11:09 AM
  #222
stogie1020's Avatar
Did lamb this time, marinated overnight in a garlic, pureed onion olive oil, zataar, pepper lemon juice marinade.
On the grill:
Finished meat:
Old Jul 18, 2016 | 12:04 PM
  #223
(Mid-Atlantic)
  #224
(Mid-Atlantic)
Just got a new set of Kabob skewers too
Old Jul 18, 2016 | 02:39 PM
  #225
stogie1020's Avatar
I need a better set, flatter.
What did you get Ack?
Old Jul 18, 2016 | 02:41 PM
  #226
stogie1020's Avatar
BTW, the grill is:
Backyard Grill Small Portable Charcoal Grill - Walmart.com
Old Jul 18, 2016 | 02:50 PM
  #227
ballin out of control!
Old Jul 18, 2016 | 02:52 PM
  #228
(Mid-Atlantic)
I picked these up because I wanted the stand, I also liked that they had the rings that you can slide the kabobs off with
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Now I just want to use them
Old Jul 19, 2016 | 10:59 AM
  #229
stogie1020's Avatar
^Nice! I need flatter ones...
Old Jul 19, 2016 | 11:00 AM
  #230
stogie1020's Avatar
I know, right? But for two people, two skewers each, it's perfect. I mean, for the ten uses total it holds up for...
BTW, that food on the grill above resulted in leftovers... Neither of us are huge quantity eaters.
Old Jul 19, 2016 | 12:07 PM
  #231
(Mid-Atlantic)
Flatter?
One of the reasons I bought these is because they are completely flat
Old Jul 19, 2016 | 01:38 PM
  #232
Those Kabobs look awesome.
I need some flat skewers like that as well. I love kabobs but hate making them right now with the ones that I have currently.
Old Jul 19, 2016 | 03:03 PM
  #233
stogie1020's Avatar
Flatter?
Flatter LIKE yours, not rounded like mine...
Old Jul 19, 2016 | 03:31 PM
  #234
The ones I have are like Stogies but black
Old Jul 19, 2016 | 03:44 PM
  #235
maharajamd's Avatar
Flat is good because they are less likely to 'tear' through the goodies they are skewering.
Old Jul 19, 2016 | 03:57 PM
  #236
Jakes_tl's Avatar
I like flat because the meat turns with the skewer when you turn then over.
Old Jul 20, 2016 | 09:14 AM
  #237
(Mid-Atlantic)
Old Jul 21, 2016 | 08:57 AM
  #238
Legend2TL's Avatar
AZ Community Team
+1, I have both round and flat and prefer the flat ones as well
Old Jul 21, 2016 | 01:00 PM
  #239
nfnsquared's Avatar
Hmmm....Thoughts? $295 with coupon code "SEARS35OFF300"
Sears.com
Old Jul 21, 2016 | 01:14 PM
  #240
(Mid-Atlantic)
Not a bad price, Sam's has the better version for $369
Smoke Hollow 4-in-1 Combo Gas & Charcoal Grill - Sam's Club
