Need a little help with cooking ribs.....
ENGAGE MY VTEC BABY!!!!!!
I am in charge of making the ribs for my wife's grandmothers 80th birthday. I have made ribs before but they want them basically so tender that they are almost falling off the bone.
How should I do this, bake them first and then slow cook them on the BBQ? Obviously a wet rub combo I think with a little dry.
Thoughts and advice a greatly appreciated
Joe
Joe
Personally, I boil the ribs first until they are almost cooked. This makes them very tender and much of the fat is boiled away as well. I then finish them off on the BBQ with plenty of sauce. Not too long, just enough to complete the cooking and give them a nice dark colour. If done properly, the meat literally falls off the bone.
Terry
Terry
Acura drove me away too..
Terry
Terry
![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
I've been slow cooking them on a rotisserie attachment for my grill. I rub them down about 18-24 hours before I start. Then I cut them down to 3-4 rib sections. I place drip pans below them so there is no direct heat. And I usually only run one or 2 burners on low. It takes about 2-3 hours. The last 30-45 minutes, I will brush on some home made sauce every 15 minutes.
The outsides are usually somewhat firm, but they fall off the bone.
I am #76,361,211,935
Here's a GUARANTEED tender ribs technique - no BS.
Put the ribs "arch up" on a big sheet of tinfoil. Season the ribs however you like, dry rub
your fav BBQ sauce - whatever. Just make sure there's a fair amount of sugar in the
seasoning cuz you want the sugar to carmelize during cooking. Then lift the sides of
the tinfoil up and fold them together basically making a tinfoil "tent" for the ribs. Try
to leave airspace between the ribs and thetent so air can circulate while they cook.
You want the tent to be as airtight as possible so the steam stays in - this is what
makes the ribs "falling-off-the-bone" tender. That's it! Put the tinfoil tent on a low
grill for 1 hour 40 minutes. If you are doing them in the oven set the temp at 275F, you
want it to cook low-and-slow,
You end up with super tasty and extremely tender ribs. A bonus is that the grill doesn't
get messed, no fat dripping and flaring up - its ultra easy.
If you want to put just a teeny bit more effort in, after the ribs are done cooking, peel
back the top of the tinfoil tent exposing the ribs and putthe heat on high for 5 to 10
minutes. This will dry-up the surface of the ribs some and add more of a smoky flavor.
Sanest Florida Man
marinate them for 24hrs then smoke them for 6hrs at 215 degrees. Then check on them baste with bbq then smoke another 1hr or 2hrs. then take them off, wrap them in plastic wrap and store in the fridge until you're just about ready to serve. Then take them out and grill them while basting with bbq. You'll know they're ready when they start falling apart on you while you're grilling them, usually it's about 5-7 minutes at 450degrees. That's how the restaurant I work at makes them and we're known for having the best ribs in town.
Needs more Lemon Pledge
1. Drive to local rib shack
2. Purchase large quantity of awesome ribs
3. Drive home
4. Dispose of packaging (must be
about this step)
5. Place purchased ribs on grill for all to admire
6. Claim the glory
3. Drive home
![Ninja](https://acurazine.com/forums/images/smilies/ninja.gif)
6. Claim the glory
Sanest Florida Man
Well played, stunna, well played...
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
Super Car Enthusiast
Boiling ribs??? Slow cook them in a smoker or oven for a few hours (they should literally be falling off the bone) in BBQ and rub then throw them on the grill to caramelize them.
We did this at my in-laws one time. We boiled a couple racks and then finished them differently. One with a mild sweet sauce, one with medium, and one with hot.
Personally I like mine dry rubbed and grilled without too much sauce. Just a light touch of it to form a light sweet, caramelized coat to off set the hot spices I use.
I have decided to cooks ribs for dinner this evening.
Terry
Terry
Sanest Florida Man
I wonder what goat ribs taste like?
all work and no play
I made my first attempt at making ribs last Thursday, it was spur of the moment so I didnt let them set overnight this time
I dry rubbed them with an awesome mix I found from http://www.willinghamsbbq.com/ then cooked em low and slow on my gas grill with indirect heat @ 200 degrees read at the surface of the grate for 4.5 hours. I had removed the grate on the heat side and had a smoker box with Mesquite chips over the heat diffusers, and a drip pan underneath the grate under the ribs with a can of beer in it. Every hour I game em a spray with a mix of apple juice and Cider Vinegar.
I had a little trouble with the temp at first since it was my first attempt at low and slow on gas. They wern't fall off the bone....but they certainly were delicious!
