I want to burn down my kitchen
Made/ate a horrible piece of meat tonight. Took one bite, spit it out. Gave it one more bite and then ended up throwing out the steak.
The steak was cooked properly. When purchased, (fresh just hours prior to cooking) the meat seemed to have the right thickness and marbling. In the end, it came out like a piece of rubber.
So my question is this - any tips on how to guarantee you get a good cut of meat? Is there some way that works or am I stuck with this hit and miss approach?
fwiw, cast iron, although relatively inexpensive, often works best to cook on too.
So the issue may be the meat, or it may be any of a number of other factors chemical, temperature, moisture and method of cooking.(ex. did you salt it hours before, if so , it will toughen the steak)
It was marinated (which should help even a bad piece of meat) and cooked medium on a very hot grill. I think the method was fine, as its worked for me in the past. I just got a dud piece of meat and I'm wondering if there are any special tips for ensuring that you are starting with a good piece of meat.
Originally Posted by SpeedyV6
Most supermarkets typically sell only "choice" cuts of steak. That is actually the lowest grade on the scale where "prime" is the highest, followed by grade A, and choice at the end. Try an upscale butcher shop that offers prime or Grade A. Thicker cuts ~ 1.5" usually work best.
It is actually
1) Prime
2) Choice
3) Select
There is no Grade A on beef and choice is the 2nd best. This is the reason supermarkets sell Choice. Most, like 90% of Prime is sold to top end steakhouses like RC's, Morton's, etc.
Originally Posted by dallison
i usually tenderize the meat witha fork and it is generally more tender
you should never have to tenderize a steak, unless you're buying blade or shoulder steaks,,,
what was the cut? How long did you marinate?
There are many factors at play here. For instance, if you bought flank steak and sliced it with the grain, it will horrible.
All beef, no matter the cut and with almost any quality, can come out tender and good. Just depends on how you cook it.
Originally Posted by Astroboy
jwhite, that's how it is in the states, but up here our grades are different, and our AAA, is better than USDA Prime by a long shot IMO.
I forgot about our Northern Friends. Although the original poster is from TX and should know his beef.
I had the same problem a couple times. I usually get my meats at the super market. I don't have time to get it at a butcher.
What I have learned is that I need to stay away from the ones that are already marinated.
I usually get a piece that is on the thicker side. Marinate it with olive oil and whatever spices that you like. Sometimes I just do salt and pepper. Leave it in the refrigerator for about an hour or so. Then I broil it in the oven. If it's really thick, I will cover it with some foil for a couple minutes so that the inside cook without burning the outside.
To me, it comes out better than most resturants.
Get prime beef...order it from the internet if it's not available locally. Find out what cut you like best...then get it cut THICK! The quickest way to ruin a steak is getting a cheap, thin, steak. It will get tough before you even think it's done....don't be cheap....get good meat.
I actually like the marbling because of the flavor. It has a lot to do with how it's cooked.
Berner....get a timer. Measure the thickness of the next steak you get and see how long it takes to cook to desired level. If you over shoot it, then keep adjusting the time. You will eventually get it.
calrow
May 3, 2017 10:21 PM
