Seagate readies 750GB hard drive
Old Apr 21, 2006 | 05:52 PM
F900's Avatar
With the way games MP3, videos etc...and the amount of space there starting to take up, might be the way to go....
Seagate is on the verge of announcing a 3.5in desktop hard drive with a capacity of 750GB - increasing the Barracuda 7200.10 line's maximum storage space by 50 per cent. Seagate hasn't formally announced the 750GB model, but it is already beginning to appear on the company's marketing material.
The drive runs at 7,200rpm and contains 16MB of cache memory. Like other models in the line, it has an average latency of 4.2ms. Seagate will offer the HDD with a choice of Ultra ATA 100, 1.5Gbps SATA or 3Gbps SATA interfaces. The Serial ATA versions both support Native Command Queuing (NCQ).
http://www.reghardware.co.uk/2006/04...0gb_barracuda/
Old Apr 21, 2006 | 06:10 PM
srika's Avatar
Moderator Alumnus
Good gravy. You know, shouldn't we get to a point where data becomes unlimited? It would be like, an unlimited HD. It would use fiber optics or other light technology combined w/ data multiplication to make a continually resizing hard drive. Kind of like a CVT transmission. It expands as the need arises. Yeah.
Old Apr 21, 2006 | 07:16 PM
BstonBruin's Avatar
Go B's Go
to put that hd space really into perspective
750GB = about 187,500 mp3's
750GB = about 550 dvd quality movies
wow
Old Apr 21, 2006 | 07:33 PM
Mizouse's Avatar
wow
Old Apr 21, 2006 | 07:53 PM
Billiam's Avatar
Big Block go VROOOM!
And you're going to back up 750GB with...?
Old Apr 21, 2006 | 07:56 PM
Stapler's Avatar
My holodrive >_>
I just hope that the 500gb drive drops quite a bit in price as a result.
Old Apr 21, 2006 | 08:09 PM
Whiskers's Avatar
Go Giants
Most people believe that magnetic hard drives will eventually be phased out with flash memory getting phased in......Im still waiting for the 1 TB flash drive....
Old Apr 21, 2006 | 08:43 PM
srika's Avatar
Moderator Alumnus
1TB flash drive... sign me up.
I had a curious problem today though. I was copying files from a 1gb SD card to a computer, and got file corruption errors - it couldn't copy certain files. wtf? I thought that would never happen on an SD card or other RAM-type memory device.
Old Apr 21, 2006 | 08:46 PM
Whiskers's Avatar
Go Giants
Maybe the problem was on the HD of the computer...
Old Apr 21, 2006 | 09:14 PM
srika's Avatar
Moderator Alumnus
doubt it... copying to my freshly-reformatted (NTFS) XP Pro laptop that I setup this week w/ no problems.
Old Apr 21, 2006 | 11:21 PM
Mizouse's Avatar
i can definately fill that up
Old Apr 22, 2006 | 05:32 PM
BstonBruin's Avatar
Go B's Go
where's your head??
Old Apr 22, 2006 | 06:47 PM
JSuppi's Avatar
Why??
Why even produce an Parallel ATA HD anymore?? Should just make them either SATA1, SATA II or SAS.
Old Apr 23, 2006 | 12:03 AM
Billiam's Avatar
There are low-end SAN and NAS systems out there that use PATA backplanes.
Old Apr 23, 2006 | 04:22 AM
srika's Avatar
Moderator Alumnus
hard drives in the future will be organic. they will be living, breathing organisms, that you have to feed. so it will be like having a pet, except it stores all your data. as long as you don't let it die, you're all good.
Old May 7, 2006 | 11:43 AM
Water-S's Avatar
go like hell
that's what I was thinking. Your gonna need at least 3(250 gigs) big secondary hard drives. also I have a 80 gig Hard drive. when I built this machine I thought that's tons of space(which it is) I in the 3.5 years I've owned it. haven't 1/2 filled it up. so IMHO: unless your running some HUGE ASS programs or has a lof file transferring both from the net and intranet or LAN a 750 gig HD unless it's for a mainframe. it's not really worth it on a PC
Old May 7, 2006 | 01:12 PM
Sly Raskal's Avatar
http://www.newegg.com/Product/Produc...82E16822148133
http://www.newegg.com/Product/Produc...82E16822148134
Old May 7, 2006 | 02:02 PM
Beelzebub's Avatar
For that price I can get 3 400GB hd's
Old May 7, 2006 | 02:36 PM
Sly Raskal's Avatar
I just got a 500GB Seagate 3Gb/s drive for $280 which isn't bad.
Old May 8, 2006 | 11:50 AM
bigman's Avatar
'Big Daddy Diggler'
Great, let me put 750gb of important data on a single unit and loose it all because of disc failure and then have to pay 3 grand to recover it. Sorry, just had 3 500 gigs die in 3 diff computers in the last 6 months. I work with a photographer/videographers and we put all the raw footage and pictures in back up drives and use different drives to edit. And we've tried a raid configuration, but premiere slows to a crawl.
Old May 8, 2006 | 12:01 PM
Sly Raskal's Avatar
That's odd, because depending on your RAID configuration, the RAID setup is suppose to be faster. But then again were you using a software based RAID controller or hardware based?
Old May 8, 2006 | 12:19 PM
Sly Raskal's Avatar
I don't know your experience level on computer setups so I'm just throwing this out there..
http://www.pcmech.com/show/harddrive/296/1/
The more commonly used RAID levels are RAID 0, RAID 1, RAID 0+1, and RAID 5. Each "level" is simply a different configuration of the RAID standard, each providing certain benefits and performance parameters.
RAID 0
RAID 0 could be said to not be technically RAID. Why? Because it lacks the "R" - redundancy. RAID 0 is basically a RAID setup that employs the striping I talked about above. This setup requires at least two hard drives to be configured into a "striped set". RAID 0 is becoming increasingly popular amongst power users. As discussed before, this setup offers much higher read/write speeds than normal and will really help to speed up a computer. People who are into raw speed for gaming, multimedia, etc, will enjoy RAID 0. But, because it lacks the redundancy factor, it is not typically used in corporate, mission-critical environments. If one drive of the RAID 0 array dies, the whole array is screwed.
RAID 1
RAID 1 employs the mirroring capability discussed previously. It can, in some cases, provide a little performance benefit, but it is primarily used for redundancy, pure and simple. With RAID 1, you have the option of attaching a third drive to the controller. It acts as a spare drive. It is not part of the RAID array, but simply kicks in in the event that one of the drives fails. The controller would perform an automatic restore to the spare drive, notify you of the failure, and continue operating as though nothing happened. RAID 1 is used more on corporate networks andweb servers. Desktop users don't typically need it, although some who REALLY need that redundancy do use it on desktop machines.
RAID 0+1
RAID 0+1, as you might be able to tell from the name, gives you the best of both worlds. It can be costly, though, as it requires at least 4 hard drives to do it. Two of the drives are striped, as in a RAID 0 array, and the other two are mirrors of the first two. This is the only option for IDE users who want both the speed and the redundancy. Due to the cost of buying 4 hard drives plus a RAID controller, this is not the most popular option in town. It does, though, kick ass, and you will find desktop users and web server guys using this.
RAID 5
RAID 5 uses the high performance capability of striping with the increased integrity of the parity bit. The setup requires at least 3 drives. To see why it needs 3, see the discussion of parity above. By comparing the data on two of the drives, it can "fill in the blanks" on the third drive, just like solving an algabraic equation. This is what gives RAID 5 the security. Because both the data and parity info is spread out across all drives, it is often called "distributed parity".
RAID 5 is typically not an option for desktop users. It offers the best of all worlds, but typically only SCSI RAID controllers have the ability to handle it. This means IDE cannot be used, which in turn means this option will cost a crapload. RAID 5 is typically thought to be used in enterprise servers and the like.
what RAID setup were you using??
Old May 8, 2006 | 12:48 PM
Billiam's Avatar
And to make things even more confusing, there is also a configuration commonly referred to as RAID 10. Where as 0+1 is a mirror of stripes, RAID 10 (or 1+0) is a stripe of mirrors. In something like video editing, where I/O throughput is a concern, you definitely want to stick with RAID 0+1.
BTW - The other thing that can come into play a bit is the cluster or block size but in this day and age this is usually more of a concern over effeciently using disk space than a performance issue.
Old May 9, 2006 | 11:29 AM
bigman's Avatar
'Big Daddy Diggler'
I do have experience, and i had a raid1 setup on an asus motherboard with a built in controller, but i was informed by adobe that the premiere rights everytime you do anything this way you dont lose time if shit happens. They also said that becuase of the reading and writing all the time, the software takes longer to do certain tasks.
Old May 9, 2006 | 11:30 AM
bigman's Avatar
'Big Daddy Diggler'
I think have to try the 0+1 setup with a different controller. It could also be a mobo thing.
Old May 9, 2006 | 11:53 AM
Sly Raskal's Avatar
I didn't know that about premiere, thanx for the info.
rockyboy
Aug 4, 2024 10:35 AM
PortlandRL
Sep 14, 2015 12:01 PM
ja17
Sep 7, 2015 06:08 PM
asahrts
Sep 4, 2015 05:55 PM
