quieting my pc
Old Oct 11, 2007 | 11:14 AM
RJANACONDA's Avatar
Registered TL Lover
Question quieting my pc
What can i do to make my PC run quieter without sacrificing sufficiant cooling? also im not looking for it to be an expesive mod.
Old Oct 11, 2007 | 11:28 AM
NetEditor's Avatar
Big White Chocolate
It's hard to give specifics without knowing your exact set-up, but buying silent fans to replace your current fans will most likely quiet it down.
Old Oct 11, 2007 | 11:54 AM
RJANACONDA's Avatar
Registered TL Lover
i have this case wich has 2 fans
http://www.atxpowersupplies.com/atx-...CA-c-2628U.htm
i have 2 physical hard drives western digital 7200 rpm
my power supply has a fan but i am not sure of the model
i have a pentium 4 processer with the standard cpu fan that it comes with
my graphix card is fan cooled
thats all the noise making components i can think of with out being at home to open it up and look
Old Oct 11, 2007 | 11:59 AM
sho_nuff1997's Avatar
I disagree with unanimity
liquid cool it FTW
Old Oct 11, 2007 | 12:10 PM
bz268's Avatar
Because Of You
If the fans are getting really old, they can make alot of noise.
Sometimes replacing the fans can help a little bit.
Old Oct 11, 2007 | 12:38 PM
nicholbr's Avatar
Also make sure to keep the system free and clear of dust and other particulates (I give mine a good spraying with compressed air once a month). This, obviously, causes system temperatures to rise quite a bit and thus the fans to work harder.
Old Oct 11, 2007 | 12:45 PM
Python2121's Avatar
The hair says it all
You could probably use a few of these:
http://www.frozencpu.com/products/24...l?tl=g36c15s58
but the real culprit i suspect are your WD hd's. I have one in my desktop and it is very loud, I can't imagine having 2.
Old Oct 11, 2007 | 12:46 PM
Whiskers's Avatar
Go Giants
Some people put velcro around the hard drives...
Old Oct 11, 2007 | 01:33 PM
Lister00169's Avatar
Yes, he did that
Switch to Ball Bearing cooling fans with adjustable fan speed.
Old Oct 11, 2007 | 02:03 PM
Stapler's Avatar
I like big low rpm fans myself.
There are also tricks like Whiskers said, also i've seen people use that soundmat stuff from car audio fame on the inside of the flimsy sides.
http://www.extremetech.com/article2/...2064987,00.asp they go over some more stuff that isn't too expensive in here.
Old Oct 11, 2007 | 05:30 PM
stangg172004's Avatar
_____ like a rabbit
Originally Posted by sho_nuff1997
liquid cool it FTW
http://www.tigerdirect.com/applicati...4129&CatId=499
might be over kill but i dont know waht your setup is...
Old Oct 12, 2007 | 12:44 AM
RJANACONDA's Avatar
Registered TL Lover
i just opend her up and found i had 4 case fans instead of the 2.
Liquid cool is not needed im only running a pentim 4 2.3ghz 2g ram (DDR2 333) slightly overclocked (ram not cpu)
nitrogen cooled FTW
I dust regulary as well escpecially since the pc in a room with 2 cats... well at least they are short hair cats i couldnt imagine long hair breeds.
i just turned on the computer (momentarily) with all 4 case fans disconected and it made a pretty noticeable differance and i distintively heard my cpu fan or maybe cuz i was just looking at the thing.
I think i will replace the case fans and look into replaceing the cpu fan. I really dont want to replace a perfectly good power supply but then again i was saying the other day that a power supply was one of the FEW copmputer components i dont have spare on.
Old Oct 12, 2007 | 10:07 AM
Ashburner's Avatar
Unplugging it should quiet it down
Old Oct 13, 2007 | 12:17 AM
GranSkyline's Avatar
Vroom
Old Oct 13, 2007 | 04:00 PM
HittingDaLine's Avatar
All the way to redline
I have antec 900 (like on the link posted above) It's not too bad with the fans it comes with on low... but once you turn it to high and add a few more fans... well lets say it's louder then the servers at work :o)
4drviper
Apr 23, 2025 07:13 PM
marinrain
ILX
Oct 6, 2015 12:36 AM
rockyboy
Oct 2, 2015 10:45 PM
TL14
Sep 24, 2015 04:37 PM
Tsov Tom
Sep 20, 2015 07:31 PM
