Quick RAM question
Old Nov 9, 2005 | 03:12 PM
JimmyCarter's Avatar
likes it raw
Quick RAM question
Figured this was the place for it...
If I have a 2.8 P4 (prescott ) processor with an 800mhz FSB, and I'm planning on upgrading my RAM, should I be going with PC3200 or PC4000?
The computer is a Sony, and I don't plan on overclocking (if that would even be possible) or anything like that. Just looking for the best plug & play performance.
It's a 2x1 setup so I was thinking 2 x 1GB chips. Any suggestions?
Old Nov 9, 2005 | 03:33 PM
FastAcura's Avatar
I
No idea, but did you try www.crucial.com ? They seem to have a lot of answers and they recommend what's best for your computer.
Old Nov 9, 2005 | 03:35 PM
bkknight369's Avatar
depends on what your motherboard can support...dont get ram with a faster clock rate than what your mobo can support
perhaps the sony site/documentation might tell you what type of ram it is...and you'd have to search a bit hard to find out if your mobo can support faster
Old Nov 9, 2005 | 03:36 PM
Whiskers's Avatar
Go Giants
Just stop putting Doritos in your PC.....
Old Nov 9, 2005 | 03:38 PM
likes it raw
But orange chips look faster and taste better...
And to the others, both PC3200 and PC4000 will work. It seems like PC4000 has more use for overclocking (not sure why) but they're both listed as compatible. The computer is currently running PC3200.
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
PC3200 most likely for that chipset. Depends on your board, but i'd imagine it's 2800 or 3200. Most likely 3200.
Old Nov 9, 2005 | 04:00 PM
likes it raw
Well looking up the computer on crucial it says PC3200 but when you click the performance memory tab it says PC4000 works too. I guess I was just wondering if I'd even notice any difference in using 4000 over 3200 and whether it was worth it to go for the 4000.
Old Nov 9, 2005 | 04:57 PM
Ken1997TL's Avatar
Get 3200
4000 wont be a noticeable improvement and you have use 4000 exclusively, no mixing.
Old Nov 9, 2005 | 05:00 PM
likes it raw
Get 3200
Pretty much what I was looking for.
Thanks to all for the suggestions
Old Nov 10, 2005 | 10:28 AM
ib_jimmy's Avatar
it depend on ur motherboard...if u get the PC4000 and ur system only handle a 400mhz FSB then its just gonna set itself slower. I usually try to by the better one if the prices isnt to far apart. If ur have one slow and one faster ram, it would set all the memory to the slower one. Reason why i get the faster one even if my computer wont take full advantage of it, is just in case in the future i upgraded my CPU/motherboard that would.
Old Nov 12, 2005 | 05:08 PM
likes it raw
Ok, one more piece of info.
Opened her up and there are 4 RAM slots. The comp takes a max of 2GB, so 4x512 (or 2x1GB I suppose)
Since its already got 2 256 chips in there I figured I'd go with 2 more 512 chips for 1.5GB total.
So 2 more questions:
1) Does the comp only work at the timing of the slowest RAM? The two chips in there now are CL3 so if I buy CL2 would it be pointless since it would only work at CL3 anyway? Would the two speeds even work together?
and
2) What is the proper way to set them up on the mobo? The 4 slots are in 2 sets of 2, like this:
---A---
---B---
---C---
---D---
Currently the two 256 chips are in slots A & C. Does that mean A&C are matching slots and I should keep those there and put the two new chips in B&D? Or do I pair them up AB and CD?
Thanks again.
Old Nov 12, 2005 | 07:09 PM
NiteQwill's Avatar
Adventurist.
If the computer has dual channel capabilities... it doesn't matter what the speed of a pair of memory sticks are, as long as they are identical in each slot.
A computer sets it's CAS timing by the SLOWEST chip on the board... so if you have a 3-3-3-8 and a pair of chips which are 2-3-3-7... it will run at the first chip's speed.....
Old Nov 13, 2005 | 12:12 PM
likes it raw
Old Nov 15, 2005 | 04:31 PM
likes it raw
Originally Posted by newegg
11/15/2005 14:04:00 DELIVERED[D]
Newegg r0x0rz.
1gb for 69 bucks after mail in rebate.
http://www.newegg.com/Product/Produc...82E16820220037
I'll try to post some benchmarks tomorrow once it's all installed
Rdub81
ILX Photograph Gallery
Mar 17, 2016 03:02 PM
06TLMatt
Oct 2, 2015 08:14 PM
Strath
Sep 27, 2015 11:53 PM
HOWELLiNC
Sep 20, 2015 04:21 PM
datadr
Sep 12, 2015 09:12 PM
