Ground Loop
Old Nov 18, 2011 | 02:45 PM
gibbyisgibby's Avatar
Ground Loop
Does anyone know anything about grounding a computer case from a 60hz hum?
I am connecting my computer (tried an external usb soundblaster and onboard stereo out) to an amplifier (onkyo sv909pro) and im getting a significant hum.
-When i unplug the connection from the computer buzz stops. If I touch anything on the computer with the cable the buzz starts again
-There is no buzz from other sources on the amp.
-I am using a 3 prong plug on my computer, my amp only is 2 prong (ground difference?)
Old Nov 18, 2011 | 02:56 PM
CocheseUGA's Avatar
Simple thing you could try would be to add a ferrite ring (bead, core, etc) to the cord you are connecting to help filter out the noise.
http://en.wikipedia.org/wiki/Ferrite_bead
Should be able to get one at any computer shop, or DIY wiring place you might have around you. You could also scavenge one from a spare good quality USB cable you have lying around.
Old Nov 18, 2011 | 02:57 PM
TeknoKing's Avatar
^ Sometimes it can be something as simple as your computer vibrating itself, like a fan is loose, check that, I've had a similar problem before. My CPU fan, was loose and was vibrating the motherboard a little which brought resonance to the sound card connection.
Old Nov 18, 2011 | 03:16 PM
Thanks for the quick replies, ill try both out tonight.
Old Nov 24, 2011 | 08:24 AM
I ended up buying a ground loop isolator (which may be a large ferrite core, i dont really know how it works) which fixed the ground loop.
No more hum
emailnatec
29
Sep 28, 2018 04:27 PM
Acura604
20
Aug 5, 2017 12:55 AM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
