Yumcha Buys Car, Arrives After World Ends, Abuse of Vehicle Ensues
#762
#763
#765
Are you sure??? Should have gotten the 440iGC..... shit had the #s since 2014
#768
Still, I would like to see what the psi is at all times.
#770
#771
Well he is he probably would not notice any way
#775
I got those avant garde and was like when I tried to take the TPMS out of the stock tires.
You literally inflate the new tires to correct PSI and set it in the MMI. It uses the abs sensors to determine that
one wheel has an aberration from the others and alerts you...even at low speeds. I was like, love you smart
ass mother fuckers. Since you know, Audi and TPMS would be like $1000 each if they needed it.
#776
On the Caddy there's a wand a tech has to use to reset the TPMS...he goes through a process and sequence at each corner to clear it.
I found that there was a delay on the displayed PSI so I'd use the analog gauge and then confirm it once rolling.
#780
#782
ttribe (05-01-2019)
#795
mine seemed like I needed to get very close to the car to make it work. especially driver door handle when
key in pocket. Just needed a new battery although I'm sure that's not the case for you. Was fob in the dash
or in your purse?
someone already did the windows up AND down with the fob through vagcom on mine.
Looking forward to getting the OBDEleven to mess with some things like no more wink when signalling
and maybe brightest setting for the DRL
or in your purse?
#797
#799
