X6M track tested - 0 to 60 in 4.3s
X6M track tested - 0 to 60 in 4.3s <hr style="color: rgb(244, 244, 244); background-color: rgb(244, 244, 244);" size="1"> <!-- / icon and title --> <!-- message -->
When BMW introduced the idea of the SAV (Sport Activity Vehicle) with the original X5, we scoffed appropriately. Then we drove it and were shocked that the ungainly beast was not ungainly at all. Then BMW took it a bit further and rolled out the X6. It appeared even more useless, yet it, too, was a surprisingly entertaining drive.
BMW didn't stop there, of course, as it rolled out Motorsport versions of both the X5 and the X6 earlier this year. There was no good reason for them to exist, but BMW went ahead and built them anyway. After testing the X6 M, we're glad BMW took the time.
You see, this X6 is so fast that its odd looks, big sticker and pointless existence don't really matter. You simply have to respect it for what it can do. And we're not just talking about going fast in a straight line. It stops and turns amazingly well, too. It's a triumph of engineering over design and marketing. Just take a look at the numbers if you don't believe us.
Vehicle: 2010 BMW X6 M
Odometer: 357
Date: 9/30/2009
Driver: Josh Jacquot
Price: $95,025
Specifications:
Drive Type: All-wheel drive
Transmission Type: Six-speed manual
Engine Type: Twin-turbo V8
Displacement (cc/cu-in): 4,395cc (268cu-in)
Redline (rpm): 7,000
Horsepower (hp @ rpm): 555 @ 6,000
Torque (lb-ft @ rpm): 501 @ 1,500
Brake Type (front): 15.6-inch ventilated cast-iron disc with two-piece rotors and 4-piston fixed calipers
Brake Type (rear): 15.2-inch ventilated cast-iron disc with two-piece rotors, and 2-piston sliding calipers
Steering System: Speed-proportional, driver-selectable hydraulic-assist rack-and-pinion power steering
Suspension Type (front): Independent, double wishbone, coil spring, driver-adjustable variable dampers, self-adjusting active antiroll bar
Suspension Type (rear): Independent, multilink, self-leveling air springs, driver-adjustable variable dampers, self-adjusting active antiroll bar
Tire Size (front): 275/40R20 106W
Tire Size (rear): 315/35R20 110W
Tire Brand: Bridgestone
Tire Model: Dueller H/P Sport
Tire Type: Summer Performance
Wheel Size: 20-by-10 inches front -- 20-by-11 inches rear
Wheel Material (front/rear): Aluminum
As tested Curb Weight (lb): 5,256
Test Results:
0 - 30 (sec): 1.7
0 - 45 (sec): 2.9
0 - 60 (sec): 4.3
0 - 75 (sec): 6.4
1/4 Mile (sec @ mph): 12.6
0-60 with 1 foot of rollout (sec): 4.1
30 - 0 (ft): 28
60 - 0 (ft): 107
Braking Rating: Excellent
Slalom (mph): 68.6
Skid Pad Lateral acceleration (g): 0.91
Handling Rating: Very Good
Db @ Idle: 43.3
Db @ Full Throttle: 70.4
Db @ 70 mph Cruise: 66.0
Acceleration Comments: Very quick in default mode. Few will ever need to use "M" mode. Still, this thing absolutely honks with all the limiters turned off. Best run with minimal brake torque -- all while ignoring launch control "flag" indicator.
Braking Comments: First run was the shortest (107 feet!). Consistent pedal, but distances got longer with every stop (up to 112 feet).
Handling Comments: Skid pad: Truly an impressive-handling SUV. Corners dead flat, offers incredible feedback and has enough power to influence chassis. But why can't I disable stability control? Slalom: Stability control never is truly off, which is why "on" number is faster than "off" number -- get aggressive with it off and it will punish you.
IL Track Tested: 2010 BMW X6 M
Odometer: 357
Date: 9/30/2009
Price: $95,025
Specifications:
Test Results:
0 - 30 (sec): 1.7
0 - 45 (sec): 2.9
0 - 60 (sec): 4.3
0 - 75 (sec): 6.4
30 - 0 (ft): 28
60 - 0 (ft): 107
Slalom (mph): 68.6
Db @ Idle: 43.3
If this engine ends up in the next M5... then.. eep.
Just be sad to lose the high revving engines. But those times might have been lost..
From Edmunds about the X5 M with the same engine.
http://www.edmunds.com/insideline/do...ticleId=158706
I can' t stand the X6...
We thought Porsche had written the final word on high-performance sport-utility vehicles. We were so wrong.
I'd prefer a super sedan to both "super crossovers" (<-- "super crossover" doesn't even sound right. sounds like a transformer or something lol)
Whats up with RDX owners?
Id much rather have an X5M if I had to get a truck, but that engine in an M5 would be bonkers.
The Third Ball
Received 4,948 Likes
X6 M is HOT
Gawdang that is fast.
The stopping distance from 60' is only four feet longer than my CTS-V (103 feet). That is INCREDIBLE for a 5200 pound truck.
Someday, an RS6 Avant+
For who?
I just don't get why anyone would you own that vehicle? Does it really serve some type of utility? Or is it the "I can afford anything crowd"? It is very fast, but
I see more point in a Trailblazer SS than I do this.
Registered Member
Registered Member
Seriously .91g's skidpad in 5000+lb SUV?? That's insane. Enough power and anything will go fast in a straight line. Still would rather take the X5M over this ugly whatever you want to call it.
The magic of german engineering.
Seriously though, that is outright impressive.
I shoot people
love the X6... always have... and I love how there are haters... makes it even better.
I like the look of the X6 and the ZDX, but I don't like the reduced utility for their sizes and the poor gas mileage. I'd rather have a sedan or 4 door coupe than one of these coupe crossover monsters.
Punk Rocker
My Garage not
1 Post
who's going to buy this thing besides some dudes in dubai? i've seen about two x6's on the streets of la where literally every model bmw is driving around. i've seen way more dinan and alpina package 7-series than x6's around.
I shoot people
I've seen more X6's than that... and Yes, I'm in Southern Cali too. They didn't make as many of these than the 7 series... nor do they expect to sell as many. Last I checked... they're selling quite well
I shoot people
to each his own...
if there's a market for it... they'll make it (and that goes for EVERYTHING in life).
