Why no Direct Injection Engine yet for Honda...
Old Dec 24, 2010 | 06:06 PM
ParaSurfer1979's Avatar
Question Why no Direct Injection Engine yet for Honda...
Why is this neat technology not being put into any of their engines?
Old Dec 24, 2010 | 06:42 PM
phile's Avatar
Pinky all stinky
http://world.honda.com/HDTV/news/2003-4031127a/
not sure why Honda hasn't implemented it though. probably would help if I watched the whole video, but it gets really technical and I get bored easily.
Old Dec 24, 2010 | 06:50 PM
Infamous425's Avatar
fap fap fap
why no push button/smart key in every Acura? why no 6AT in every Acura? why? why? why? who knows.
Old Dec 24, 2010 | 07:10 PM
OperationDarkie's Avatar
Ultra Negro
Isn't direct injection derived from diesel engines?
Old Dec 24, 2010 | 07:29 PM
friesm2000's Avatar
B A N N E D
originally yes
but as far as no direct injection from Honda yet...
they normally like to test and prove technology (minus VTEC)(and let others work out the bugs, and get a bad rap for the technology) before they bring it out themselves, basically all so that the technology is proven and reliable before customers ever see it
there are things that Honda has brought out over the years, and really never made a mention of it till it was proven, such as SH-AWD (it's been on the MDX since it debuted or 2001, but was not named till 2005 with the RL)
Old Dec 24, 2010 | 07:50 PM
fsttyms1's Avatar
its honda. they are behind in many things, need any one say more?
Old Dec 24, 2010 | 08:03 PM
friesm2000's Avatar
B A N N E D
but then again didn't the J25 in the Honda inspire/saber in japan have direct injection
trying to remember lol (and have not seen one with the beauty shields removed either )
Old Dec 24, 2010 | 08:08 PM
S14 n Tsx's Avatar
mmmmmm....
honda is far behind...
Old Dec 24, 2010 | 08:58 PM
calgary2800's Avatar
Whats so great about DI, I've driven the new Sonata with DI and it not a engine that what I would call fun, my Accord is a much sweeter engine for those who are into cars.
DI is overrated just like LEDs TVs.
Old Dec 24, 2010 | 09:04 PM
friesm2000's Avatar
B A N N E D
DI just has to be built into a purpose built engine, not just retro-fitted onto an existing engine; kinda like those flex-fuel engines with E85; but you look at the Subaru (or forced inducted cars) scene and people love it, cause they can crank the boost up, to use it's full potential
Old Dec 24, 2010 | 09:36 PM
csmeance's Avatar
Doesn't honda use DI on all of it's cars with the V6's and K series 4 cylinders? I don't think that they'd use carburetors on anything like the accord or civic...
Old Dec 24, 2010 | 09:59 PM
friesm2000's Avatar
B A N N E D
DI is Direct Injection
what you are probably thinking of is Port Injection, which injects the fuel into the intake manifold BEFORE the valves, where DI it injects the fuel directly into the combustion chamber (like where the spark plug is)
BTW: gators suck ass, Seminoles are better :hack: :hack:
Old Dec 24, 2010 | 10:02 PM
AMUA6's Avatar
ScoobyZINE
Old Dec 24, 2010 | 10:23 PM
friesm2000's Avatar
B A N N E D
Originally Posted by AMUA6
i am not
Old Dec 24, 2010 | 11:10 PM
CLtotheTL32's Avatar
<-both parents are FSU Alumni
Old Dec 24, 2010 | 11:48 PM
Ken1997TL's Avatar
I think some of you have direct IGNITION and direct injection confused..
That having been said, there are concerns among gearheads about premature wear due to direct injection using current methods. I'm not educated enough on the issue to debate it one way or another. I'm sure Honda has its reasons.
Old Dec 25, 2010 | 01:07 AM
Eoanou's Avatar
'10 Hyundai Genesis Coupe
DI works more efficiently on turbo charged cars from what I gather. Something with the fact that they can pump fuel into the cylinder much easier. A DI engine can work as efficiently as a motor with 1300cc injectors from a fuel delivery perspective, from what I've been told.
Old Dec 25, 2010 | 01:14 AM
Aman's Avatar
Your Friendly Canadian
Considering most of Honda's engines are relatively old in design (K-series has been around since early 2000s, J-series has been around since the birth of Jesus), I'm guessing there'll be a new line of engines on the horizon, which should have DI. Patience.
On another note, how would VTEC work with DI? Would you have to have another set of cam lobes and tweak the ECU to adjust how much fuel is injected?
Old Dec 25, 2010 | 01:47 AM
SpiderX1016's Avatar
Why doesn't Chevy ditch the pushrod V8? Cause it works.
Honda will go to DI sooner or later. Whatever they feel like.
Old Dec 25, 2010 | 08:31 AM
friesm2000's Avatar
B A N N E D
i would think they would probably do a common rail (pretty common and proven on modern diesels), and use piezoelectric injectors, so the additional lobes would not be needed
biggest issue i see is packaging, but with say a new head design, should be no issue to factor it in
Honda will go to DI sooner or later. Whenever they feel like.
very well said (btw also fixed lol)
Old Dec 25, 2010 | 09:48 AM
F23A4's Avatar
Indeed: Honda on Direct Injection
Old Dec 25, 2010 | 02:26 PM
StreetKA's Avatar
pioneer was Mitsubishi with their GDI motor. it saves gas when you are easy on throttle and if you are not then its way no gas saver. look at the toyota/lexus V6 and V8 engines they have both DI and old one injection for that reason.
wikipedia
The major advantages of a GDI engine are increased fuel efficiency and high power output. In addition, the cooling effect of the injected fuel and the more evenly dispersed mixtures allow for more aggressive ignition timing curves. Emissions levels can also be more accurately controlled with the GDI system. The cited gains are achieved by the precise control over the amount of fuel and injection timings that are varied according to the load conditions. In addition, there are no throttling losses in some GDI engines, when compared to a conventional fuel injected or carbureted engine, which greatly improves efficiency, and reduces 'pumping losses' in engines without a throttle plate. Engine speed is controlled by the engine control unit/engine management system (EMS), which regulates fuel injection function and ignition timing, instead of having a throttle plate that restricts the incoming air supply. Adding this function to the EMS requires considerable enhancement of its processing and memory, as direct injection plus the engine speed management must have very precise algorithms for good performance and drivability.
The engine management system continually chooses among three combustion modes: ultra lean burn, stoichiometric, and full power output. Each mode is characterized by the air-fuel ratio. The stoichiometric air-fuel ratio for petrol (gasoline) is 14.7:1 by weight, but ultra lean mode can involve ratios as high as 65:1 (or even higher in some engines, for very limited periods). These mixtures are much leaner than in a conventional engine and reduce fuel consumption considerably.
Ultra lean burn mode is used for light-load running conditions, at constant or reducing road speeds, where no acceleration is required. The fuel is not injected at the intake stroke but rather at the latter stages of the compression stroke, so that the small amount of air-fuel mixture is optimally placed near the spark plug. This stratified charge is surrounded mostly by air, which keeps the fuel and the flame away from the cylinder walls for lowest emissions and heat losses. The combustion takes place in a toroidal (donut-shaped) cavity on the piston's surface.[citation needed] The cavity is displaced to one side of the piston, the side that has the fuel injector. This technique enables the use of ultra-lean mixtures that would be impossible with carburetors or conventional fuel injection.
Stoichiometric mode is used for moderate load conditions. Fuel is injected during the intake stroke, creating a homogenous fuel-air mixture in the cylinder. From the stoichiometric ratio, an optimum burn results in a clean exhaust emission, further cleaned by the catalytic converter.
Full power mode is used for rapid acceleration and heavy loads (as when climbing a hill). The air-fuel mixture is homogenous and the ratio is slightly richer than stoichiometric, which helps prevent knock (pinging). The fuel is injected during the intake stroke.
Direct injection may also be accompanied by other engine technologies such as variable valve timing (VVT) and tuned/multi path or variable length intake manifolding (VLIM, or VIM). Water injection or (more commonly) exhaust gas recirculation (EGR) may help reduce the high nitrogen oxides (NOx) emissions that can result from burning ultra lean mixtures.
It is also possible to inject more than once during a single cycle. After the first fuel charge has been ignited, it is possible to add fuel as the piston descends. The benefits are more power and economy, but certain octane fuels have been seen to cause exhaust valve erosion. For this reason, most companies have ceased to use the Fuel Stratified Injection (FSI) operation during normal running.
Tuning up an early generation FSI power plant to generate higher power is difficult, since the only time it is possible to inject fuel is during the induction phase. Conventional injection engines can inject throughout the 4-stroke sequence, as the injector squirts onto the back of a closed valve. A direct injection engine, where the injector injects directly into the cylinder, is limited to the suction stroke of the piston. As the RPM increases, the time available to inject fuel decreases. Newer FSI systems that have sufficient fuel pressure to inject even late in compression phase do not suffer to the same extent; however, they still do not inject during the exhaust cycle (they could but it would just waste fuel). Hence, all other factors being equal, an FSI engine needs higher-capacity injectors to achieve the same power as a conventional engine.
Old Dec 25, 2010 | 02:38 PM
Aman's Avatar
So Honda's putting all of its resources into hybrid vehicles, instead of DI.
Honda of America, I think their priorities are a bit out of whack. What's a good hybrid system if you're mating it to a (soon to be) old-fashioned design system. Port fuel injection seems like it'll soon go the way of the carboreutor, and Honda will be even more behind in engine tech that in it now.
Sucks
Old Dec 25, 2010 | 03:48 PM
HondaOnWORKS's Avatar
Je t'aime...
Because Push Start is an useless feature. Granted, it would be nice to have it on every car in the line up as an option. MB and BMW offers the push start as an option, which cost nearly $700 ( I think ). In my mind that's a rip off.
The 6spd AT... Personally the TSX, I feel it doesn't need it on the I4 model. The TSX I4 with 5spd AT can pull better MPG than its rival the IS250 (6SPD AT). So in my mind giving the TSX a 6spd AT would be quite pointless when MPG are pretty good already.
Old Dec 25, 2010 | 04:58 PM
Aman's Avatar
Meh, I don't know about you, but I'd like some extra torque at highway speeds, and I feel the space between fourth and fifth is too large. Having a 6 speed would hopefully allow for a bit more usable torque and a taller top gear.
Old Dec 25, 2010 | 05:12 PM
StreetKA's Avatar
first of all IS250 is V6 and TSX is i4... TSX in 5AT has absolutely no torque... i would never buy an automatic if it wasnt at least V6... second of all lexus and their 6 speed automatic transmisions are awesome, they are very quick and smooth
Old Dec 25, 2010 | 10:03 PM
Je t'aime...
I can say the same on the IS250, it produces 185 lb-ft. I wouldn't consider that "torquey", but it is 15 more than the TSX. But at the end the TSX pulls better 0-60 #s and quarter mile #s. The TSX also handles better too, while the IS250 trails behind with lifeless steering. I don't get what you are trying to prove when the TSX I4 w/ 5spd AT performs better than the IS250, and still has better MPG.
Old Dec 25, 2010 | 10:16 PM
StreetKA's Avatar
I was trying to explain why is the tsx got better milage compared to is250. It has simply two cylinder less to feed. Sorry but im the last person who would buy honda/acura car with their auto tranny. Im not gonna argue but honda has better motors and toyota has better Auto trannys hands down.
Old Dec 25, 2010 | 10:35 PM
Je t'aime...
The TSX has two less cylinders, but the IS250 has 6spd AT which should at least help the MPG.
I'm not going to argue with you, because I think both companies Honda/Toyota both offer good engines and transmissions.
However, the transmission I hate at the moment is Nissan/Infiniti's 6spd manual. So not smooth...
Old Dec 25, 2010 | 10:36 PM
friesm2000's Avatar
B A N N E D
not entirely true, it's more about total displacent, and how much fuel it has to feed; and if anything the 6 would edge out, because it should be able to get more complete combustion per chamber (cause the flame front does not have to travel as far; which with direct injection, you could kinda compensate for the larger k24 bore, because you can get the fuel charge concentrated towards the center of the combustion chamber, by injecting late enough), but then again you got more drag with those two additional cylinders with the rings, bearings, valves, etc.etc.
but yes generally considered is the more cylinders there are, the more fuel it uses
ghttf's Avatar
Toyota has better autos but Honda has great manuals
BTW the KA24 got shit mileage with 2.4 liters, even for 1990
Old Dec 25, 2010 | 10:46 PM
friesm2000's Avatar
B A N N E D
Originally Posted by MTwEeZi
Aisin has better autos but Honda has great manuals
fixed (it's who makes alot of Toyota parts, but they are a division of Toyota now though)
Old Dec 25, 2010 | 10:57 PM
StreetKA's Avatar
i test drove also IS350 and i was surprised of its performance and tranny was damn quick
Old Jun 26, 2011 | 03:38 PM
mg_tl's Avatar
7th Gear
okay i may not know everything about fuel economy, but what im certain of is:
a small v6 compared to a big I4 is a joke..
everyone knows that a small block v6 2.7L will out preform and have better fuel economy then big block I4 2.5L...
This is proven every day yet... ppl never smarten up.
doesnt matter what tranny, 4 spd 5 or 6...
if you look at an old rx6 mazda and a new vw city golf.. whos got the better numbers ?? haha
but anyways,
now on the matter of FI to DI .. its simple.. although DI technology and actual use in vehicles has been around for years. Its just not perfect yet. where as FI has no draw backs. Yes DI is said to save on fuel and increase power..but currently these engines are known to require a large increase in maintenance expense...
Old Jun 26, 2011 | 03:44 PM
mg_tl's Avatar
7th Gear
ohh and .. only the IS350 awd and the IS F are fast.. the is250 300 and even the 350 fwd is too slow in my opinion... these cars are priced at what and go how slow???? lmao.. end of story
Old Jun 26, 2011 | 04:18 PM
mrmako's Avatar
Someday, an RS6 Avant+
Nope. I owned one of the J25 Sabers. It was a NA V6. I'd have to dig around my old computer files to find a pic, but it definitely was not a GDI engine.
Old Jun 26, 2011 | 05:00 PM
Saintor's Avatar
Think about it.
Accord V6 271HP 20/30mpg
Sonata 2.0T 274HP 22/33mpg
10% difference.
The day that Honda will decide to integrate direct injection and a 6th speed, it will match or do better than the Sonata, efficiency-wise.
Old Jun 26, 2011 | 05:26 PM
csmeance's Avatar
Originally Posted by Saintor
Think about it.
10% difference.
That's apples to oranges, that's a Tubocharged 4 cylinder vs. a Naturally aspirated v6. With the turbo added you only get the HP at upper RPM ranges that you normally wouldn't hit in the city and def. wouldn't hit cruising on the Highways so you have no need to dump extra fuel because you aren't in boost.
However acura did the same thing with the RDX and it screwed them over because the car would go into boost at the slightest touch of the gas pedal!
Old Jun 26, 2011 | 07:07 PM
StreetKA's Avatar
toyota/lexus uses both injection types... in one engine
Old Jun 26, 2011 | 08:37 PM
Rockstar21's Avatar
The Dumb One
Think about it.
10% difference.
and I'll still kick a sonatas dick in the dirt with my 8 year old accord
