Wheels: Plastidip + Bronze Duplicolor??
i am looking for this effect above ^^ (not my exact car, but the same setup)
has anyone tried this?
it would entail two coats of plastidip as primer + duplicolor + gloss...on stock 18" wheels.
ive been told repeatedly that the plastidip allows it to be 100% removable...which its a deal breaker for me, since the car is a lease.
anyone care to chime in??
here's one source:
http://g35driver.com/forums/media-sh...lasti-dip.html
apparently, certain paints do not eat through the plastdip, such as duplicolor.
but any feedback here would be helpful!
My suggestion is to buy the products and find something made of metal of decent size and try it on it. I would be interested in seeing how well this works out.
What is the logic here? If you use plastidip you're going to be able to strip it off easily to get back to stock?
I still don't understand why you leased when every month you are talking about modding that car in some way.
the whole process costs $30 and its removable. plastidip peels off no differently than a cellophane wrapper.
to be honest, i think it's gonna look tacky/cheap. yeah, it's cost effective but i think it would ruin the integrity of the car, it is such nice/clean car stock. not to mention that you'd have to do something with the chrome trim around your windows and any other chrome on the car. i could be a little too critical here, but its just my opinion.
good luck with your decision/method of action
It's going to look like you plasti-dipped as primer and then spray painted it....in other words, awful...like the G.
It will come out looking nothing like the bronze on those 5Zigens.
Ok wow people are going crazy with plastic dip. Doing stripes on top of the paint. http://forums.corvetteforum.com/c5-g...ne-wild-5.html
It peels off leaving no marks in the paint just like if it were vinyl.
thanks guys...i just have the mod/handywork itch...and a long weekend to myself.
i think im going to vinyl wrap my roof instead. just need to figure out a plan beforehand as to how i am going to work around the shark fin antenna. any advice would be helpful.
If you're up for it, you can buy shark fin antennas off of ebay that are black and just relplace it. From the experiences that I've heard about in the past, it's a bitch to wrap the antenna with vinyl.
I took my antenna off when my roof was wrapped. I'm not sure how the interior of the IS differs from the TL but I removed the rear dome lights and the bolt for the antenna was an inch or two back from that area. I took a ratchet and took the nut of and pulled the antenna off.
yeah, im not wrapping the actual antenna. im leaving it white. im just trying to figure out how to wrap AROUND the antenna.
maybe i precut a hole in the material where the antenna would protrude, lay down the material, then work my way outwards with the antenna as a starting point.
you only get one shot, with a $100 piece of vinyl...
i came across a video on youtube. the guys precut the hole for the antenna, laid down the material, and then taped across the midsection of the car. they peeled the backhalf first, and negotiated around the antenna. then removed the tape around the midsection, peeled the front half, and finished up. all while leaving the sunroof open.
^^ i suppose this technique allows the rear half of the material to stick down around the antenna, so your antenna hole doesnt shift when pulling out the material for the rest of the roof.
i guess ill try this technique. may be a bitch, since im doing this solo, as opposed to three professionals.
http://www.youtube.com/watch?v=HVKxbXINPdo
IIRC, I know with the 3G you can access the antenna through the rear dome light, which made it easy to remove, but I am not sure about the IS. Do you have to remove the whole headliner or can you just loosen the rear to access the antenna? The measuring technique seems to be a good way to do it, but removing the antenna, laying the down the vinyl and cutting accordingly seems like less of a headache.
I'll be sure to ask for your permission next time I do something to my car
Nope but then again I never really went out and searched for problems with it. I have 3M material that's meant for outdoor applications.
