wheels with incorrect offsets
All your base belong to
1 Post
Is it possible to grind down the inside part of a wheel (the part inside that mounds to the car's hub) to get your desired offset?
Like if the wheels were currently a +43 offset, could you shave 7mm off to achieve a +50 offset?
Htown slab rider
Tristate ViP Crew
19x8 with a 45 offset , you should be fine especially with just a Pro-Kit.. Phrosttz01 had 19x8 with a 45 offset on Axis Mods with coilovers and never rubbed..Wasn't your last wheels that offset and 19x8
1 Post
I am running on Pro-Kits with 225/35's and I don't rub at all. However, the wheels sit pretty much flush with the car's fender in both the front and the rear. I would just like to move them a little bit back into the car's fender because I am worried about throwing rocks and chipping the side and rear of my car.
Example:
There is alot of rear tire exposed outside the rear fender well.
Example:
Just dial 1911
1 Post
Example:
Example:
pushing the wheel in would affect the way the car looks and it looks pretty as it is. i say get some clear bra material and place it behind the wheel, although i've never read about this being a problem.
nuldabz
09-03-2015 05:49 PM
