Wheel Question
Old May 26, 2011 | 02:42 PM
invisiblewar's Avatar
an asshole from florida
Wheel Question
I know Ill be told this should be in the CL section but I need a quick response and know Ill get it here.
I have an 01 CL-S I just got some bbs ck off of a 2007 camry, the wheels fit on the front but it they dont fit over the (im guessing the hub) center of the rotor.
Will the wheels need to be machined to fit over or could I buy some type of spacer to get the wheel on?
Old May 26, 2011 | 04:17 PM
SuperTrooper169's Avatar
In the Mid-South meow
Your safest and best bet is to have the hub bored out on the wheels. I don't personally know if they make spacers to fit in that kind of senario, but I wouldn't take a chance on a quick fix verses doing it the safe and correct way.
Old May 26, 2011 | 04:29 PM
oonowindoo's Avatar
That sounds weird. From what i know Camry's front and rear centerbore are the same size (60.1mm) and CL's front and rear have the same centerbore size too (64mm)
If your BBS fits the front , then it should fit in the rear too. There might be hub centric rings already installed on those wheels. You might wanna check.
Old May 26, 2011 | 04:50 PM
AZuser's Avatar
_
I think the OP is saying that the wheels fit bolt pattern-wise (5x114.3), but don't fit bore size-wise. If that's the case, OP needs to have the wheels center bore bored out to 64.1mm
Old May 26, 2011 | 05:00 PM
the front fit but the rear dont. so yeah Im looking for a place that will bore them out. thanks everyone.
Old May 27, 2011 | 01:25 PM
Slayer's Avatar
sell the wheels to a Camry owner and buy ones with a 64.1mm bore. I wouldn't re-bore used wheels.
booma1218
May 3, 2016 07:39 AM
lland
Oct 4, 2015 04:47 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
bailey24
Aug 31, 2015 05:38 PM
