Wheel Question
an asshole from florida
Wheel Question
I know Ill be told this should be in the CL section but I need a quick response and know Ill get it here.
I have an 01 CL-S I just got some bbs ck off of a 2007 camry, the wheels fit on the front but it they dont fit over the (im guessing the hub) center of the rotor.
Will the wheels need to be machined to fit over or could I buy some type of spacer to get the wheel on?
In the Mid-South meow
Your safest and best bet is to have the hub bored out on the wheels. I don't personally know if they make spacers to fit in that kind of senario, but I wouldn't take a chance on a quick fix verses doing it the safe and correct way.
If your BBS fits the front , then it should fit in the rear too. There might be hub centric rings already installed on those wheels. You might wanna check.
I think the OP is saying that the wheels fit bolt pattern-wise (5x114.3), but don't fit bore size-wise. If that's the case, OP needs to have the wheels center bore bored out to 64.1mm
DiamondJoeQuimby
09-10-2015 11:40 AM
