what do you think caused this?
Old Oct 18, 2005 | 10:14 PM
ZeroPSI's Avatar
All your base belong to
What do you think would cause the scoring on the cylinder walls?
http://www.1320video.com/img/rach/cyl2left.jpg
http://www.1320video.com/img/rach/cyl2right.jpg
http://www.1320video.com/img/rach/cyl3.jpg
Old Oct 18, 2005 | 10:24 PM
S A CHO's Avatar
That was uncalled for...
My guess is metal shavings of some sort...Im expecting to be completley wrong...
Old Oct 18, 2005 | 10:59 PM
HQuakers's Avatar
giggity giggity giggity
Seizure and scoring are two different stages of the same problem. When the oil film on a cylinder is
momentarily burned or brushed away, the metal surfaces of the piston and the cylinder wall will
actually touch. When this happens, there is a sort of scraping that takes place between them. When
the oil film is resumed, the marks from this scraping will often remain on the piston and (or) the
cylinder wall. This momentary scraping or "scoring" seldom causes any permanent or performance
robbing damage. No significant damage takes place because the oil film is resumed before the piston and cylinder have a chance to start exchanging material onto one another.
Scoring is commonly seen on the piston face directly below the piston ring end gaps. The blast of
combustion can get between the large end gap of a worn out ring and burn the oil off the piston and
cylinder in that area...Hence the surface scoring. In most cases, score marks can simply be sanded
off of the piston and cylinder. However when ever you see scoring, it's a good idea to find the
source so that it doesn't develop into a full blown seizure.
http://www.picknowl.com.au/homepages...ech/piston.htm
Old Oct 18, 2005 | 11:22 PM
mclarenf3387's Avatar
That oil looks slightly cooked.
Old Oct 19, 2005 | 01:52 PM
dallison's Avatar
registered pw
wrong grade of oil?
dirt of some sort
overheated
thegipper
Sep 28, 2015 01:01 PM
h22lude
Sep 27, 2015 06:22 PM
Froid
Sep 27, 2015 06:16 PM
ceb
ILX
Sep 27, 2015 10:56 AM
