Volkswagen Touareg towing a 747...
Old 12-05-2006, 10:11 AM
Yumcha's Avatar
Received 22,942 Likes on 14,058 Posts
...from the guys of 5th Gear but brought to you by Youtube.
Link: http://www.youtube.com/watch?v=05zRyoBbcfI&eurl
Old 12-05-2006, 10:29 AM
vishnus11's Avatar
Ho
Ly
Shit!
Damn!
Old 12-05-2006, 10:32 AM
Yumcha's Avatar
Now see, if a Hummer did that, I wonder how many pieces it'll be in now...?
Old 12-05-2006, 10:40 AM
daemonicus's Avatar
dont planes usually get taxied around the runways by SUVs/trucks anyways?
Old 12-05-2006, 11:22 AM
vishnus11's Avatar
no
Old 12-05-2006, 11:46 AM
99 TL, 06 E350
Black Tire's Avatar
no...those are Aircraft Tow Tractors. Don't know the specs, but their towing capabilty is imense.
Old 12-05-2006, 12:26 PM
daemonicus's Avatar
ahhh yes. i knew they resembled a truck but i couldn't put my finger on what they were.
Old 12-05-2006, 12:52 PM
drcookie's Avatar
With enough torque and weight, you could do it with any truck.
Besides, the Touareg only tows it for a few feet.... it is unusually but nothing special.
Old 12-05-2006, 12:57 PM
Bagel Bomber
Mach30SiR's Avatar
EXACTLY, with enough torque and weight - does your Chevy S10 have "enough". No. there is no way you'd get that thing even rolling if you don't have alot of torque at that low of am rpm. If you dont know what your talkn about, dont post "nothing special"
Old 12-05-2006, 01:08 PM
AcuraFan's Avatar
I think I've seen videos of people pulling jumbo jets with their teeth or something.
Old 12-05-2006, 01:15 PM
srika's Avatar
Received 10,928 Likes on 5,543 Posts
yeah.. pulling jumbo jets is nothing to brag about. I mean, I used to do it back in the day. with my left pinky.
Old 12-05-2006, 01:17 PM
Floyd Mayweather Jr.
Black CL-S 4-Life's Avatar
They should have fired up the 747 engines and put them in reverse just for a little fun.
Old 12-05-2006, 03:13 PM
checkmate...
mr.motoring's Avatar
If only the engines weren't fake.
Old 12-05-2006, 03:34 PM
Yumcha's Avatar
Le pics of the le towing...
Press release...
Record-breaking: Touareg tows Boeing 747
TDI power: A Touareg V10 TDI takes a 155-ton jet along for a ride
Wolfsburg, November 24, 2006. “Wanna bet that a Touareg V10 TDI can tow a Boeing 747?” “A 155-ton jet?” “Never!” “Sure it can!” This verbal exchange by two Volkswagen employees had consequences: A few months later, on Thursday this week, a Volkswagen crew did indeed hook up a new generation Touareg V10 TDI to a 747. The certified result: The SUV pulled it off easily. However, the receipt of orders from airport operators wanting to replace their tow vehicles weighing up to 70 tons with the significantly more economical Touareg could not be confirmed.
The “Touareg tows a Boeing 747” event took place at the Dunsfold Aerodrome in England, located 40 miles from the gates of London. From the very start the question, entirely seriously meant, was posed about how powerful a modern, top range SUV with engine, four-wheel drive and chassis is.
The Touareg is innately the ideal towing vehicle: Maximum load capacities are 3,500 kilos for trailers and 1,640 kilos for the rear axle. But when instead of a 3.5 ton boat trailer a jet weighing over 155 tons – consisting of 511 m2 of wing surface, 4 engines, 450 seats and a fuselage the size of a block of houses – is attached to the hitch, things look quite a bit different. Careful preparations must be made.
In order for the Touareg V10 TDI to be able to tow the big bird, the weight of the Volkswagen had to first be increased. This sounds paradoxical but is absolutely necessary so that the power of the engine can be converted into propelling force. For this purpose steel balls and steel plates were distributed in the SUV. Extra weight: 4,345 kilos! Total weight of the Touareg: 7,030 kilos. Weight distribution: 2,755 kilos in front, 4,275 kilos in back.
The other modifications were kept to a minimum. For the front axle drive the shorter transmission of the Touareg V8 was integrated in place of the V10 TDI transmission. The crew increased air pressure in the standard Michelin tires to 4.5 bar. And finally, the maximum speed was limited – not out of fear that the unusual harnessed system would become airborne, but to protect the tires. Everything else, from the engine to the shock suspension system and four-wheel drive corresponded exactly to the series production version.
An extra device was then used to hook up the Boeing 747 to the Touareg’s standard trailer hitch. The experiment could begin. Based on the maximum torque of the V10 TDI (750 Nm) and the transmission ratio, the engineers had previously calculated that the Touareg would be able to put approx. 200 tons into motion. But who would trust his calculations if a 1.7 meter high, 4.75 meter long car was suddenly attached to a 19.4 meter high jet over 70 meters long? Nobody would. Especially not when typical English weather with heavy rain and headwinds were lashing across the car and jet as if there was no tomorrow.
But the Touareg did the job. Volkswagen technician Uwe Krieghoff took the wheel. He started the engine. Using the four-wheel drive control on the middle console he selected the “LOW” setting for reduced off-road speed. 50 percent of driving force was now distributed to the front axle and 50 percent to the back. Krieghoff manually selected the second gear of the automatic transmission, accelerated slowly and reflected on getting the 18 head-height wheels of the 155 ton 747 rolling from a standing position. The greatest power was required in these few seconds. As soon as this harnessed system got moving, it would move. But the only thing that budged at first was the engine speed. Krieghoff continued to push down the gas pedal to about the halfway position. And with not a hint of traction problems the Touareg and the jumbo jet started moving. After a distance of 150 meters Krieghoff slowed the harnessed system to a stop.
A post check-up of the Touareg did not find any evidence of damage to the car. Everything was A-OK.
Incidentally, the new generation of the Touareg is now available for order. The SUV comes standard equipped with ESP plus trailer stabilization. It is extremely effective at preventing trailers from dangerously fishtailing when improperly loaded or traveling at excessively high speed. The system didn’t kick in during the test with the 747 – the speed was only eight km/h.
Old 12-05-2006, 04:47 PM
crazymjb's Avatar
"553 pounds-feet of torque at 2,000 rpm"
Nothing to brag about.
Mike
Old 12-05-2006, 05:46 PM
cmark's Avatar
i don't know of any iteration of 747 with engine nacelles joined like that.
i call
Old 12-05-2006, 07:51 PM
drcookie's Avatar
Woow !!! I guess someone took it too personally on this topic.
Too bad this is just a forum where people are free to express their opinion.
Cheers !!!
Old 12-05-2006, 08:38 PM
Photography Nerd
Dan Martin's Avatar
I've seen a number of jets pulled by people so it's not overly impressive that an SUV can.
Hell, this dude (David Huxley) pulled a 184 ton 747-400 298 feet in only 87 seconds in 1997:
That's 22 tons more than the 747-200 the Touareg pulled, and he's not exactly a monster either.
Old 12-06-2006, 09:35 AM
99 TL, 06 E350
Black Tire's Avatar
Now the American car makers have to do the same....
Old 12-06-2006, 12:16 PM
vishnus11's Avatar
i call
it was a special decommissioned 747-200 built for use in the new Bond movie "Casino Royale". More details regarding this can be found on the Youtube link that the OP provided.
Old 12-06-2006, 12:32 PM
Bagel Bomber
Mach30SiR's Avatar
It wasn't a 200 series. Look up boeing 747SP Its too short to be a 200.
http://www.747sp.com/
Those engines are fake. Engines are usually the firsting taken off the body and reused for parts and/or overhauls
Old 12-06-2006, 12:52 PM
RaviNJCLs's Avatar
Wow. That's amazing.
Old 12-07-2006, 03:51 AM
Vollgas auf der Autobahn!
JensH1963's Avatar
I have never seen a Boeing 747 with an engine setup like that. What is it????
Jens
Old 12-07-2006, 10:38 AM
Nom Nom Nom Nom
SwervinCL's Avatar
Now if they were on a conveyor belt............................
Those Touareg's are pretty crazy... I saw one take out a pretty good light poll, with little damage to the vehicle.
Old 12-07-2006, 11:08 AM
EuRTSX's Avatar
Wooo! That was crazy stuff haha ~
Old 12-07-2006, 11:22 AM
99 TL, 06 E350
Black Tire's Avatar
This track looks like the same track that TOP GEAR does it show on. That must be the plane we keep seeing in the background during their runs.
Old 12-07-2006, 04:10 PM
csmeance's Avatar
Received 2,016 Likes on 1,435 Posts
If this is ture, how can the car's frame handle that much weight being pulled? Also how did the hitch stay attached to the car? surely the bolts would have come off.
copmagnet82
3G MDX (2014-2020)
71
11-05-2015 08:29 PM
Nizmosis
10-13-2015 02:25 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
95oRANGEcRUSH
09-25-2015 12:50 PM
Rob144
09-21-2015 08:18 AM
Quick Reply: Volkswagen Touareg towing a 747...
