Tundra 86'd for an 86 which was 86'd for a Sequoia
Old 03-29-2022, 04:07 PM
  #2561
LFG RANGERS!!!!!!!!!!!
e30cabrio's Avatar
Received 1,932 Likes on 1,327 Posts
Push to start, hazard and TRD Pro Sequoia letters that are matte not shiny are out for delivery, without the lens on the gauge cluster the upper dash "fits"
Old 03-29-2022, 05:29 PM
  #2562
e30cabrio's Avatar
Tracking still says out for delivery but UPS brought two other packages
Old 03-30-2022, 10:56 AM
  #2563
e30cabrio's Avatar
Chinese gauge cluster connectors cleared customs!
2022-03-30 02:53
Clearing Customs
Custom clearance successful
civicdrivr (03-30-2022)
Old 03-31-2022, 04:06 AM
  #2564
e30cabrio's Avatar
I was wrong, the push start & hazard were not out for delivery. Hazard came yesterday, start is not shipped.
Hazard switch works but the triangle that lit up on the original switch doesn't, looking into if it should.
Old 03-31-2022, 10:24 AM
  #2565
e30cabrio's Avatar
Turns out it lights up when the headlights are on, but does not flash.
Old 03-31-2022, 08:02 PM
  #2566
e30cabrio's Avatar
In the event I can't get the '19 cluster to work, I can live with this.
First drive to Applebees:
Old 04-01-2022, 12:18 PM
  #2567
rockstar143's Avatar
Received 19,982 Likes on 14,493 Posts
You have gone to great lengths!
Old 04-01-2022, 01:42 PM
  #2568
Received 6,000 Likes on 3,953 Posts
I never dynoed either. The Tundra & Sequoia both feel much better. The AFRs are much better.
feel much better how? Just more responsive? I can't imagine you can get any appreciable extra power out of a tune for one of these...
Old 04-02-2022, 08:40 AM
  #2569
e30cabrio's Avatar
It has much better throttle response, feels significantly more responsive and the transmission shifts better.
I have the AFR difference somewhere, I'll find it, it is much better.
Old 04-02-2022, 10:09 AM
  #2570
e30cabrio's Avatar
Soooooo000 I took the truck to the bodyshop Thursday night, they were "overbooked" and said they could not work on it for a week. Having already waited 2 weeks for them I said good day sir!
Old 04-05-2022, 06:29 PM
  #2571
e30cabrio's Avatar
I have most of the wires toned out & terminated. Not a fun job!
civicdrivr (04-05-2022)
Old 04-06-2022, 11:58 AM
  #2572
your reputation precedes you!
you would be a NIGHTMARE customer!
1killercls (04-19-2022)
Old 04-06-2022, 01:11 PM
  #2573
e30cabrio's Avatar
The PDR guy came & made it like it was not there, saved me more than 500 bucks, he gave me a company that does bumpers that are coming Tuesday to give me a quote, they did not want to from pictures.
Before.
civicdrivr (04-07-2022)
Old 04-07-2022, 07:22 PM
  #2574
e30cabrio's Avatar
Got the cable together, it's a mixed bag but progress.
Good news/bad news.
It immediately saw open door when installed.
It sees the 4WD status. Sees gas & volts, no oil or water no tach.
Code U0155 indicates the instrument cluster is not receiving or transmitting messages on the CAN bus.
Old 04-08-2022, 06:41 AM
  #2575
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,323 Likes on 4,900 Posts
Do you think that's a wiring issue or coding?
Old 04-09-2022, 08:27 AM
  #2576
e30cabrio's Avatar
It's coding the CAN. The addresses changed. I need an emulator that will take in the data from the truck and send it to the correct address at the cluster. I have been getting a ton of help from a guy on Tundras that made his regular cab short bed 2007 into a 2018+ and all he has left is the cluster.
Here is his message on that:
This is the part where this swap gets really tough and probably the reason nobody has actually pulled it off yet. The wiring was the easy part. You have now made it as far as I did about a year ago then quit.
As I have mentioned everything can be fixed with the CAN bus signals. The CAN H and CAN L wires you hooked up are a massive network of data flowing in and out of the cluster and all the ECUs. The data is sent with an address line and then 8 bytes of data.
For example (address) 2C4 (Data) 20 12 00 01 45 00 12 34
Would be one message all in Hexadecimal.
Almost all the data to run the cluster comes in on these messages: Speed, Rpm, Coolant Temp, Fuel Use, All indicators/lights, Warning messages, 4wd , Key On/Off, Door open signals, and more.
The problem is really the address of the message. Most are the same (reasons some things are working now) but some have moved addresses. The address can be one of over 1,000 variables. The 2018 cluster is looking for addresses with data that your trucks ECUs are not producing. For example on 2007-2017 the RPM signal is sent from the engine Ecu on address 2C4. However on 2018+ it was moved to address 1C4. So your truck is sending the RPM signal out on 2C4 but the newer cluster is looking for it on 1C4. It can’t see it being on the wrong address so the gauge doesn’t work.
Same for all the LDA, PreCollison warning messages. The 2018 cluster knows that address 411 is data from the front radar. Your truck has no front radar ecu and doesn’t even transmit a message on the 411 address but the cluster is looking for it. When it sees nothing it shows the error message.
I have spent almost a full year now, first mapping all the signals produced by my 2007 truck. Addresses, data location ect. Then more recently trying to figure out what data moved where on the 2018+. I have read almost every Toyota CAN bus log file on the internet and spent hours playing back data to my clusters.
To me the only way this works is with a 3rd party CAN microchip, translator wired in between the cluster and the body harness of your truck. It would read data in from the truck, move it to the new address and send it out to the new cluster. So it would have to be programmed to read the data coming in on the 2C4 address, then turn around and send that same data out on the 1C4 address to the cluster to make the RPM work. That is one of about 10 address that need to be moved or created. I have figured out how to do all this just sending the data from my laptop but programming a microchip inline with the truck to automatically do it is the next step if this is ever going to work.
Also, this came yesterday & I found its harness.
Old 04-09-2022, 09:05 AM
  #2577
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
And that bullshit is why I don't like these new cars that are rolling computers. That's such a headache. Should just be able to switch one wire to another pin and make things work.
But it sounds like this is the kind of challenge you like. Good luck, I'm rooting for you!
The following 2 users liked this post by cu2wagon:
civicdrivr (04-09-2022), e30cabrio (04-09-2022)
Old 04-09-2022, 09:08 AM
  #2578
e30cabrio's Avatar
Filling the hole!
lol
Old 04-09-2022, 10:15 AM
  #2579
civicdrivr's Avatar
Yeah I would've thrown the towel in long ago lol
Old 04-09-2022, 12:45 PM
  #2580
e30cabrio's Avatar
Agreed.
I doubt that. You may not want to do the projects I do (and I'm not up for many of yours) but we are similar in the fact we persevere and get them done.
I have seen your house thread remember?
:P
civicdrivr (04-10-2022)
Old 04-18-2022, 01:50 PM
  #2581
e30cabrio's Avatar
Need a chest Xray, went to Simonmed, 3 hour wait (they do not accept appointments) I said ok, I'll be back in 2+ hours, no, you have to sit here. Give me back my referral.
She's talking about their policy, my policy is to ignore stupid policies. Let me make an appointment & keep me waiting an hour or let me walk in and come back a bit before the time you quote.
They open at 8:30, I'll get there about 8 tomorrow and hopefully be at the front when they open.
Old 04-19-2022, 10:49 AM
  #2582
e30cabrio's Avatar
Got to Simonmed at 7:45 to be at the front of the line. (Open at 8:30) Xray tech called in sick it will be at least an hour
Gaaaaa
Old 04-21-2022, 03:23 PM
  #2583
e30cabrio's Avatar
Not that anyone cares but it was over 2 hours and I don't have a broken rib.
Old 04-22-2022, 10:14 AM
  #2584
civicdrivr's Avatar
Well that's good. What happened?
Old 04-22-2022, 11:55 AM
  #2585
e30cabrio's Avatar
We use the garage 99.999999999% of the time to come & go. There was a delivery, between the garage & house is the laundry room. There are doors on both sides of the laundry room. I usually treat it as an "airlock" to keep flies out & dogs in. I did not shut the inner door, garage was open, puppy came into the garage. I stopped rapidly to contain him, fell and landed on the 2500ah battery backup I have on the garage door and landed on my chest. This will be 3 Saturdays ago tomorrow, still hurts.
Sneezing felt like I was reenacting the Christ impalement. It still hurts to sneeze & cough. I do not recommend it.
:P
Old 04-22-2022, 12:01 PM
  #2586
civicdrivr's Avatar
Ouch. Get some rest. Glad nothing is broken.
Old 04-22-2022, 01:42 PM
  #2587
e30cabrio's Avatar
Left out right after it happened I got my first stomach flu in decades and was also throwing up. Damn that hurt!
Thanks.
Old 04-23-2022, 11:45 AM
  #2588
e30cabrio's Avatar
Installed new battery connectors, used a memory saver to keep from having to reset all my stuff.
__________________
Old 04-25-2022, 09:35 AM
  #2589
Received 5,422 Likes on 3,712 Posts
TRD E30 BMW?
Old 04-25-2022, 08:59 PM
  #2590
e30cabrio's Avatar
The cluster lives!
civicdrivr (04-26-2022)
Old 04-26-2022, 08:07 AM
  #2591
civicdrivr's Avatar
That bench is speeding.
e30cabrio (04-26-2022)
Old 04-26-2022, 08:56 AM
  #2592
Not in parts of TX it isn't
Old 04-26-2022, 09:15 AM
  #2593
e30cabrio's Avatar
My house has no limits! :P
Old 04-27-2022, 03:44 PM
  #2594
e30cabrio's Avatar
Last week was the 1 year anniversary of the Sequoia. 4874 miles driven, 480 gallons, 1694.50 spent (per Fuelly)
civicdrivr (04-27-2022)
Old 04-28-2022, 10:40 AM
  #2595
e30cabrio's Avatar
My TPMS, which worked for a year stopped yesterday. Gauges are fine. Weird stuff, I was going to call IDATALINK but thought, let's see if there is a new firmware.
Immediately after the update (so glad I bought the Bluetooth version)
Old 05-06-2022, 06:50 PM
  #2596
e30cabrio's Avatar
Since I have had the Sequoia for a year and know it expires in May I logged into the the MVD site and it says 8 days. Luckily it does not need smog so I paid it. I am used to getting a notice so I call, tell the woman I just paid my registration online and it was expiring in 8 days and I have another car that expires next month and I am concerned about that one.
She is relatively rude and asks if I have an account online. I literally just told her not only that I do but I paid for my renewal and am concerned about the other car she says it's a courtesy notice and we're debating continuing it.
I said you could have just said I'm sorry you did not get your notice, sorry the system is buggy from an upgrade and we have not finalized the notices but good thing you have the account and were proactive instead of being rude & hung up.
Old 05-07-2022, 04:07 PM
  #2597
e30cabrio's Avatar
Holy shit it's early May!
Old 05-13-2022, 05:09 PM
  #2598
e30cabrio's Avatar
Scrapes & scratches being removed as I type, about to paint.
civicdrivr (05-14-2022)
Old 05-13-2022, 09:20 PM
  #2599
e30cabrio's Avatar
Old 05-16-2022, 07:53 AM
  #2600
Painting bumpers without removal is baffling but it does look like it came out nicely
Quick Reply: Tundra 86'd for an 86 which was 86'd for a Sequoia
