TSX more a Vigor than 4 door RSX?
What, me drive fast?
I saw an Acura Vigor on the way to work this morning and I was thinking that maybe the TSX is more akin to the Vigor than a 4 door RSX. The Vigor was pretty much a stand alone car as the TSX will be. And the TSX doesn't look at all like the RSX. Also, my guess is that the TSX will be a bit bigger than the RSX but smaller than the TL...much like the Vigor was bigger than the 'teg but smaller than the Legend. Sorry if this has been mentioned before.
A second comment/question...back in the Vigor day, it was just an Acrua-ized 4 door Accord, right? Was the Legend a whole new platform or was it also somehow built on an existing Honda platform?
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
2004 Acura TSX Specifications
Detroit, MI 01/05/2003 --
2004 ACURA TSX
POWERTRAIN
Engine Type
16-valve, DOHC, 2.4-liter, I-VTEC 4-cylinder
Horsepower, SAE Net
200 hp @ 6,800 rpm
Torque, SAE Net
166 lb-ft @ 4,500 rpm
Emission Control
LEV-2 (Low Emissions Vehicle-II)
Transmission
6-speed manual or
5-speed Sequential SportShift(TM) automatic
CHASSIS
Body Type
Steel unit body
Front Suspension
Independent double-wishbone with coil springs and stabilizer bar
Rear Suspension
Independent multi-link double-wishbone with coil springs and stabilizer bar
Steering Type
Rack-and-pinion
Wheels
17x7 7-spoke alloy wheels
Tires
P215/50R17
Braking System
4-wheel disc brakes with 4-channel ABS
FUEL ECONOMY
Estimated EPA Fuel Mileage-City/Highway*
Manual: 21/29
Automatic: 22/31
* Preliminary EPA mileage estimates determined by Honda. Final EPA mileage estimates were not available at the time of printing.
Use for comparison purposes only. Your mileage may vary.
EXTERIOR DIMENSIONS
Overall Length
183.3 in (4,657 mm)
Overall Width
69.4 in (1,762 mm)
Overall Height
57.3 in (1,456 mm)
INTERIOR DIMENSIONS
Front
Head Room
37.8 in (960 mm)
Leg Room
42.4 in (1,076 mm)
Hip Room
54.4 in (1,381 mm)
Shoulder Room
55.4 in (1,406 mm)
Rear
Head Room
37.3 in (947 mm)
Leg Room
34.2 in (868 mm)
Hip Room
54.4 in (1,382 mm)
Shoulder Room
53.5 in (1,360 mm)
Volumes
Passenger
90.9 cu. ft.
Cargo
13.2 cu. ft.
Total
104.1 cu. ft.
WARRANTIES
Vehicle
4-year/50,000-mile limited warranty
Outer Body Rust-Through
5-year/unlimited-mile limited warranty
Acura Total Luxury Care (TLC) with roadside assistance
4-year/50,000 mile
2004 ACURA TSX
POWERTRAIN
Engine Type
Horsepower, SAE Net
200 hp @ 6,800 rpm
Torque, SAE Net
Emission Control
Transmission
6-speed manual or
CHASSIS
Body Type
Steel unit body
Front Suspension
Rear Suspension
Steering Type
Rack-and-pinion
Wheels
Tires
P215/50R17
Braking System
FUEL ECONOMY
Manual: 21/29
Automatic: 22/31
EXTERIOR DIMENSIONS
Overall Length
183.3 in (4,657 mm)
Overall Width
69.4 in (1,762 mm)
Overall Height
57.3 in (1,456 mm)
INTERIOR DIMENSIONS
Front
Head Room
37.8 in (960 mm)
Leg Room
42.4 in (1,076 mm)
Hip Room
54.4 in (1,381 mm)
Shoulder Room
55.4 in (1,406 mm)
Rear
Head Room
37.3 in (947 mm)
Leg Room
34.2 in (868 mm)
Hip Room
54.4 in (1,382 mm)
Shoulder Room
53.5 in (1,360 mm)
Volumes
Passenger
90.9 cu. ft.
Cargo
13.2 cu. ft.
Total
104.1 cu. ft.
WARRANTIES
Vehicle
4-year/50,000 mile
Re: TSX more a Vigor than 4 door RSX?
yea AcuraFan is right, they simply developed this new model to bridge the gap, you can consider the cl to be the coupe version of the legend since there never was a coupe version of the vigor. but the RL is in fact the replacement of the legend just like AcuraFan said.
The Acura Granddaddy
Yep, its still a Legend outside the US. And to answer the earlier question both the Legend coupe and sedan share no platform with other honda cars. In fact the coupe and sedan are more different than the CL\TL.
Re: Re: TSX more a Vigor than 4 door RSX?
Originally posted by AcuraFan
However, the TSX isn't a 4 door RSX, it's a completely different platform. I think they are lumped together because they are the smallest coupe and sedan in the Acura lineup...but that's where the similarities stop.
I know it's going to take some time for people to accept that there's no replacement for the 4-door Integra... but everyone needs to realize that the TSX is NOT a 4-door RSX.....
I think that the RL is called the Legend in Japan still?
The Vigor became the TL, just as the Legend was replaced by the RL. So the TSX fills the "void" left by the 4 door Integra. However, the TSX isn't a 4 door RSX, it's a completely different platform. I think they are lumped together because they are the smallest coupe and sedan in the Acura lineup...but that's where the similarities stop.
As somebody else noted, the successor to the Vigor is the 1st-gen TL. The Vigor has a longitudinal 5-cyl engine, as did the 2.5TL.
Re: Re: Re: TSX more a Vigor than 4 door RSX?
Originally posted by DtEW
I think one of the reasons people are calling the TSX "a 4-door RSX" to replace the 4-door Integra is because the only 4-cylinder Acuras have ever been Integras/RSXs. (Remember the 4-cyl appeal issue I've been harping about?) It also helps that particular case that both use the new K-series engines w/VTEC-i, although in reality both the displacement and the VTEC-i mechanisms are significantly different.
Re: Re: Re: Re: TSX more a Vigor than 4 door RSX?
The only 4 cylinder Acuras were Integras/RSXs? I thought the first gen CL had a 4 cylinder as well.
Re: Re: Re: Re: Re: TSX more a Vigor than 4 door RSX?
Oh, right. Forgot. But people tend to remember the Integras. The CL's were never that big in the public consciousness, at least compared to the Integras. (No offense.)
Audi Driving Snob
Originally posted by jimcol711
how much does the TSX weigh?? has that been announced yet?? what about the weight distribution
No one knows yet and the longer it goes without that info being released the more scared i get! The accord type-s in europe weighs in about 3050lbs, same as japan. I would expect the acura to probably weight well over 3100lbs approaching 3200lbs. It shoudl still perform decently well, but the lower they can keep the weight the better things will be.
But is the Legend in Japan the same thing as the RL here? Same car, different name? Or is it a different car filling the same niche in the market?
Acura 3.5 RL = Honda Legend
an adult perspective
ALSO, for those who don't recall, the engine/platform of the early generation Legend's were shared with the British built Sterlings, until they came out with the 827 (I believe it was). Sterling had a beautiful coupe design concept which really outshown the Legend, but they never built it. Remember, Acura's advertising of the late 80's read: Genuine Mercedes Replacement Part.
IBankMouse
06-13-2020 12:53 PM
kixo
09-25-2015 03:07 PM
