Took this for a ride today...
Looked at the post source for the image information and found this as the image src URL....
http://webmail.aol.com/43792/aol/en-us/mail/get-attachment.aspx?uid=1.24763103&folder=NewMail&part Id=2&a=1620&z=359299
Dude, you still using aol???
It's the Can-Am "Spyder Phantom Limited Edition"
I didn't go very far with it, I was limited in time. I was delivering a car to my friend's aunt (The BMW in the background - Try showing a 70+ year old women how to operate everything in a Nav equipped BMW...
2+ hours and she still doesn't understand) and he came to see how she was doing with the car as I was finished showing her everything so I just jumped on it and went for a quick spin. I'm a bit of a rookie on a bike though, so I can't really appreciate it as much as he does (he's been riding bikes for years). It was weird riding something that actually has a reverse gear and only one brake (foot). The clutch and shifting is the same like any other bike though.. I'll be back there next week and plan on using it a little more. It was definately different than i've ever experienced!
Turning ratio was similar to a bike. I didn't go fast enough to take turns at any speed to show how it handles. This thing has ABS, stability control, the whole 9!
Okay... Here Is The Tricky Stuff
Two wheels in the front, one in the rear... This thing must handle like Fred Flintstone's Brontosaurus. No! Even Wilma would be right at home peddling the Spyder through its paces. You see, the engineers at BRP have created what they call the VSS (Vehicle Stability System), a control system they developed in conjunction with Bosch (a German-based leader of technology - check them out on the web at www.bosch.com).
There are three parts to the VSS:
1- The Stability Control System (SCS) - which continually analyzes the motion of the vehicle and assists the rider in correcting any negative situation. The SCS individually brakes the wheels and reduces excess torque until rider control is regained. I found this to be an amazing feature that instantly develops confidence on how this machine will handle under adverse conditions.
2- The Traction Control System (TCS) - which optimizes rear wheel traction to prevent any excess rear wheel spin. Unless, of course, you are in that burn-out factor range where the designers allow you to spin the rear tire as long as you have the Spyder pointed straight.
3- Anti-Lock Braking System (ABS) - helps you maintain control of the vehicle while braking, no matter how quickly you need to come to a stop. Fred used to wear out the bottom of his feet but with the Spyder, sensors monitor the rotation of all three wheels independently and help the rider maintain control steer through any adverse situation.
And then there is the DPS (Dynamic Power Steering). The DPS provides a computer-programmed variable power assist that helps adjusts the amount of steering effort required according to your speed. Okay... That came right out of their marketing brochure, but I can tell you the SCS, TCS, ABS and DPS add up to a combined safety feature found only in high-end sports cars. You can push the Spyder through the turns and the on-board sensors will respond. Barney would be jealous.
I've always thought the riding dynamics of the CanAm to be odd.....as in pull right to go right....pull left to go left......the exact opposite of riding a motorcycle.
The bike doesn't lean, the handlebars turn like a standard bike. The suspension works like a car, so to speak, so if you take a turn very fast, HOLD ON!
neuronbob
23
Jul 16, 2019 10:48 AM
emailnatec
29
Sep 28, 2018 04:27 PM
4drviper
Sep 23, 2015 07:42 PM
