Tired of the Old Audi...
Old 07-23-2018, 08:06 AM
  #121
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
I think I have the diverter as well...
you'll hear it with the downpipe and high flow or removed cat!
1killercls (07-23-2018)
Old 07-23-2018, 08:32 AM
  #122
Received 5,832 Likes on 3,853 Posts
Diverter is the way to go. Dumps excess pressure back into the intake so it doesn't need to be done again rather than dumping it outside where it doesn't matter. Also, less ricer sounding.
The following 2 users liked this post by SamDoe1:
1killercls (07-23-2018), TylerT (07-23-2018)
Old 07-23-2018, 09:21 AM
  #123
it's what the car came with though...
I think I replaced mine on the Audi...the diaphragm on the older ones was prone to separation and leaking.
Old 07-23-2018, 11:08 AM
  #124
brian2's Avatar
Originally Posted by 1killercls
OK..will do later today.
Old 07-23-2018, 11:38 AM
  #125
GEEZER
1killercls's Avatar
Received 2,214 Likes on 1,418 Posts
Originally Posted by brian2
Old 07-23-2018, 11:49 AM
  #126
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
Why don't you JB4 it, in the mean time, while under warranty? It's a cheap mod, and you can do it so that it is completely reversible without a trace (there's an AFR wire you have to tap, but, you can build or buy a small harness that avoids you having to tap it, making it completely reversible without a trace).
According to their site...
The JB1 is a true user adjustable plug and play solution for all MQB based models in the VW Audi Group range. Power Gains: Starting at 45bhp and 45ft lb with 91 octane with + 4.80psi boost over stock on the default setting. Up to 90bhp and 70ft-lb with bolt on modifications, higher octane and boost adjustment with the optional BMS Data Cable.
They have a dyno on a stock A3 that appears to have gained just over 52lbft of torque. Those numbers quoted above likely are on the low end.
JB1 & JB4 VW Performance Tuner - BurgerTuning.com
Old 07-23-2018, 01:59 PM
  #127
2024 Honda Civic Type R
RPhilMan1's Avatar
Received 1,454 Likes on 923 Posts
The 2.0T is a "Closed" Turbo system. It has a Diverter Valve Rather than a Blow Off Valve. Weird thing..I could hear my diverter on my old audi with a tune...can't here the the turbo or the diverter on my A3.
Same thing on the ST, until I changed to a BoV.
When I first got the car, I couldn't hear the turbo that much until I put on an aftermarket intake. Then the whoosh was nice and loud!
hobo2424
08-16-2012 05:01 PM
Godwhacker
20
12-09-2007 09:23 PM
gavriil
01-30-2004 02:09 PM
gavriil
02-02-2003 05:39 PM
Quick Reply: Tired of the Old Audi...
