Thinking about getting an M3
F1 cart racer
the only real bad thing i hear dof them is the rear subframe tearing where the shocks and suspension hooks up. i think it was reinforced on the later models. search m3forum.com and e46fanatics.com. the problem is not to common but it happens if your aggressive with the car.
generally the 2003.5 and up are better then the previouse years. new rear tails and other things that were changed and added.
The hair says it all
^^ Werd, get a more recent models. No new car is without bugs, and the M3 had a bunch. The original engines were prone to blowing for some reason, that was quickly addressed.
F1 cart racer
werd i forgot to mention that, there was some issue with the head gasgets it think, i don't remember. i did some extensive research when i thought about buying one 6 months ago and remember most of it.
if m3forum.com deosn't work try m3forum.net , sometimes one works and the other doesn't
No expert here...but, wasn't there some issue with the engine literally blowing up as well...?
That being said, I absolutely love this car. I'd get one in white with red interior, please.
Engineer
bastard that is the combo i have wanted for the past couple years...
the problem with the engines blowing up had to do something with a bearing which was ceasing up... i believe in involved only SMG versions around 2002 but i could be wrong. There was a related recall i believe...
F1 cart racer
yup i believe that was it, 2001-2002 maybe even late 2003 there was an issue with a bearing seizing and blowing the motors, they called all motors to have it done and was fixed after 2003.
There are going to be alot more maintenence issues and related expenses with those cars compared to an Acura. Oil changes are $100 (uses some special weight oil IIRC), The BMW "inspections" are quite costly on that model...I think I heard $1200 somewhere
Originally Posted by Fibonacci
Anybody here thinking of getting a new one? Wonder what kind of wait time.
After his sunk cost in mods, he might as well have.
Inspections are roughly every 30k and are expensive at the dealer 1K+, not nearly as bad at a good Indy.
Oil is expensive as well $60+ for oil and filter, roughly every 15k.
I am partial to 2003.5 and beyond. The cars are not cheap to maintain but the majority of engines (particulary when you get larger than 3L) which have over 100hp/L are as or more expensive to maintain.
I think it's almost the same...they are both luxury car.
___________________
Adding acura accessories of my car...
___________________
Engineer
Originally Posted by stright-(paint)balling
no offence new C63>new M3
And your reasoning for this? The M3 has always been the benchmark in this class, don't expect that to change.
The C63 might be faster in a straight line (not by much though), but that is probably about it.
And on that note, the OP is asking about the old M3 anyhoo...which also gets another checkmark for better looks.
it is fair to say it is common knowledge that the M3 is the benchmark period
One of the Supra tuner/shops I know (HPF) in Calif has seriously moved into moding Bimmers with their turbo kits. Here's a video one of HPF"s customers, his new M3 has their turbo kit on it; about 425rwhp on pump gas and 600rwhp on racegas
http://youtube.com/watch?v=QAe9B6cIuGA
Originally Posted by Crazy Sellout
Your reasoning?
#1. I my opinion the 3 series looks better EXCEPT the M3 vs C63.
#2. Benz Amg line has always been known as Torque monsters
the new C63 running 0-60 in 4.5 seconds.
#3. Hp numbers M3 414 hp vs 457 hp of the Benz
yes i admit the old C class AMG were stright line bullets but AMG went all in on this new C63 and i think this is gonna be a real M3 fighter i think it will finally turn and brake like a M3.
I feel the need...
they just redid both the C class and 3 series.
1. Styling is highly subjective.
2. Agreed.
3. Benz is heavier which negates hp advantage.
Personally, I find rowing the gears more fun in a true sports sedan than slushbox, but that's just my
It will be fun to see the RS4, M3, LS-F, C63 comparos. Amazing how Acura is missing from the picture.
Mile High
So owning a 2000 M5 wouldent be a good idea if a person lives 3 hours from a dealer and gets it serviced by an independent? Are M5's relatively reliable? Not breaking down all the time?
Originally Posted by JBlueCLS6
Bumping this...
Apparently you can buy a full service warranty 6 years/100,000 which would include oil changes, changing brakes etc for CPO BMWs.
Is this true?
Is this true?
rockyboy
08-04-2024 10:35 AM
nuldabz
09-03-2015 05:49 PM
