Still weary of long oil changes? Check this out
#42
99 TL, 06 E350
my dad is sp cheap that he buys the cheapest non brand name brand oil from any dept store for his 1990 Accord. The car still runs great...he just changes at 10k intervals.
#43
On the way!
Originally Posted by vishnus11
...Like McLaren said, one of the most telling examples is that a 2007 Porsche Boxster S requires an oil change every 20000miles!!! And you know Porsche expects a car of this calibre to be driven hard at high speeds, and high rpms.
IMO - Porsche is not a good example.
I run Amsoil 5w-30 on 10k intervals. 3k intervals are crazy, but I do want the synthetic oil because they tend to last better/longer. Granted, at 10k intervals you're kinda in the grey zone as to whether or not synthetic is required over regular dino oil.
#44
Audi was telling people to change every 10k on dino.
Well, that was till the whole oil sludge issue.
So dont always go by what they say.
Now its every 10k with synthetic but my audi tech told me to do it every 5k. Personally i think they say to do it every 10k miles because they offer it for free. It seems like thats when they started telling everyone to do long intervals.
![Chuckle](https://acurazine.com/forums/images/smilies/chuckle.gif)
#45
Originally Posted by ChrisQ1980
I don't mind paying the price for Mobil 1 oil and changing it every 5k, even though it comes out as clean as it went in. Why take the chance? As the oil gets dirtier, loses it's additive package you are using more gas since there is more friction, wearing out the motor all because you can't take the time to change it? That makes no sense to me.
Originally Posted by speedzer
No one has mention whether it was safe or not to switch back to conventional oil if currently using synthetic.
#46
Originally Posted by I Go To Costco
Since it has been established that newer motors make the 3k intervals absolutely unnecessary, what do you guys recommend for a 12 year old Integra LS with 150k miles? All stock
for now.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
If it matters, there's this guy with a Del Sol with 300,000+ miles (who knows what he has now), every 3k with synthetic IIRC. Honda offered to trade him ANY vehicle in their current line up if his motor/car lasted until 500,000 miles.
Here's a page I found with info concerning synthetic vs. dino oils.
http://forums.yellowworld.org/showthread.php?t=1136
Really interesting. The guy who wrote the bolded text is a NASA Engineer who studies the properties of lubricants. He recommends that you DON'T run dino (mineral) oils for more than 1000-2000 miles between changes.
![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
Then he mentions piston ring seals in new motors, which has been a huge debate concerning the break-in of new motors. He recommends using single weight mineral oil (he specifies Havoline 30) for the first 2000 miles, then to switch over to synthetic. He mentions that Corvettes come new with Mobil 1 in them, and people brought them back to the dealers because they were burning oil.... but I personally think that its the dumb Corvette owners who aren't breaking in their engines properly.
Then he makes another point which is confusing: he says to avoid running multi-weight oils for more than 2,000 miles, but then he said its safe to run Mobil 1 for up to 10,000 miles.
![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
This article also recommends using dino oil to break in your engine, found under the section "Conventional Oils"
#47
fwiw, here's a primer on motor oil put together by a retired physician who is an ardent auto enthusiast. He may not know nearly as much about oil as a tribologist but it makes for an interesting read. The guy is a big proponent of lighter weight oils:
http://63.240.161.99/motoroil/index.html
#48
Drinking Beer In
In most cases, using syn is sorta like using nitrogen in your tires. Is it better? Yes. Will it make any difference in the long run? Nothing you can measure.
Costco - use the cheapest stuff you can find, and just change it regularly. If you are worried about usage due to engine wear, go up a weight.
#49
....This article also recommends using dino oil to break in your engine, found under the section "Conventional Oils"
It's also a good idea not to mix brands of oil. Stick with a particular brand at least for your current oil change and when adding oil later, keep using the same brand. Always have an extra quart or two readily available. Although you can change brands between changes, I recommend choosing a brand and sticking with it to avoid potential incompatibilities.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
IIDXholic
10-08-2015 07:53 AM
darksky
09-05-2015 03:11 AM
