Should I get a OBDII Scanner?
Old May 5, 2014 | 11:42 AM
cabanalane's Avatar
I am a DIY when it comes to maintenance items. On "real" repairs, I let the pros take care of it.
I was thinking about getting a OBDII reader.
Questions
1. To reset the Check Engine Light, what's the difference using the code reader to clear it vs. disconnecting the battery to reset it?
2. I was told that some sensors can go bad without triggering a code for the reader to read. True, sometimes, not that often. Most issues will trigger a CEL and a code.
3. If I do take it to shop, do shops often appreciate or frown on owners telling them what's wrong? Shops sometimes charge a diagnostic fee. So if I inform them "what is wrong" will they likely wave that?
4. If I buy a code reader today, will it still be effective tomorrow? Meaning, cars and technology changes. I assume there will be new codes? Do codes change? Codes for 2000 car are the same as 2012? Do some readers do a firmware update and some don't?
Old May 5, 2014 | 11:50 AM
neuronbob's Avatar
1. Yes, every driver should have a GOOD OBDII reader. It will help the pros to do their job and allows you to reset the CEL on your own.
2. This happened on my first CTS-V. GM has its own special device (Tech-II) to read some sensors that are not available to most OBDII readers.
3. A CEL light doesn't say what's wrong, it only localizes the problem. My experience is that a good shop will look at all available data, not just a CEL code.
4. Yes for the most part, in my experience. I've had a Scanguage II for almost ten years and it's been useful for all the cars I've owned in that timeframe.
Old May 5, 2014 | 12:00 PM
JS + XES's Avatar
I drive a Subata.
Get a Torque app!
mada51589
Jan 9, 2025 04:40 PM
Jamus22
Jun 11, 2023 10:08 AM
Dec 7, 2020 05:39 PM
NSXNEXT
Jun 26, 2008 07:10 AM
