RSX Engines on national backorder
Guest
Posts: n/a
I just went to the "New Car Client" held by my dealership (Acura of Brookfield) last night. When they took us into the shop and were showing us the cars I got to talking with one of the service guys and he showed me two RSX's that were in for blown engines. The owners (young kids) did the same thing as previously posted, mishifts, one from 2nd back to 2st at 6k+ rpm's and the other a 4th to 2st I think. Needless to say, the engines are toast. I asked Dan (service guy) how long to fix them and he said quite a while because Acura/Honda America is on a national backorder for the RSX engines because so many have been blown across the country. Hmmmmmmm makes me wonder, bad design or bad role-models from Hollywood (aka "The Fast and Furious" and not knowing how to drive).
Just thought this was a little tidbit of information that everyone on this board would like to hear.
Brenden
Brenden
Cajun Gumbo Man
Blown from NOT knowing how to manually shift properly ?????? Why isn't that car loaded with computers as our's is........
Guest
Posts: n/a
Originally posted by Fabvsix:
<STRONG>Blown from NOT knowing how to manually shift properly ?????? Why isn't that car loaded with computers as our's is........</STRONG>
I think its the way the tranny is made. Its a lot easier to mis a shift on GS-R/RSX trannies. The ECU have a rev limiter, but since the car is stick there is nothing they can do about that.
Spiro
Spiro
Guest
Posts: n/a
Yeah but a NATIONAL backorder?? That seems like a damn lot of engines. Of course I don't know how many "spares" are kept around for this type of thing. Just seems a bit excessive to me. Like I said...bad design? or bad publicity in a sense from Hollywood with everyone trying to copy F&F and get racers.
I'd imagine this is due to the drivers. Remember that the K20A engine has been out in Japan for a little while now.. and there's no manufacturing defects with them there.
I've seen dealers with 3 or 4 GS-R's at a time with bent valves and damaged pistons from people flubbing a shift. GS-R valves don't float until about 9000 RPM on the stock valvetrain... proof that there's plenty of idiot drivers out there.
Retired Post Whore
Too many little kids have been watching Fast and Furious. My cousin has no problems with his RSX-S. It's nice and smooth, plus he don't beat the hell out of the car. People abuse their new cars, and don't let the car properly break in!
The same thing happened when the Celica GTS came out. I dunno---I drove the RSXS after not driving a stick for awhile and had absolutely no problem with it other than not knowing the optimal way to take advantage of the 6th gear. But, in time that would obviously come to be second nature.
Why doesn't a rev limiter kick in? When I had my 240SX I shoved it into 2nd well past its max. speed and it seems as though a rev limiter kicked in unless that feeling of power shutdown (just like it feels on the CLS) was b/c the motor was screwed and not b/c of a rev limiter. No damage was caused by that action so I guess the car took care of itself.
Acura should install a switch like from Days of Thunder that recaps what the RPMs were at when the engine blows!! (I'm sure that;s probably logged in the computer code, but whatever).
Midnight Marauder
They've probably listened to the hype about getting it into redline all the time. If you mess up a shift but you are not even at redline yet the engine has somewhere to go, if you are in the red, sorry, don't think a rev limiter can help you there, the tranny is engaged and will spin the engine as fast as it can, cutting off the gas to the engine won't help with that. You'd be basically tourque braking in the extreme! People don't become familiar with their cars enough before going allout.
They deserve it, just consider the cost of their engine as an "IDIOT TAX" and we'll call it even!
Originally posted by NOMAD:
<STRONG>They've probably listened to the hype about getting it into redline all the time. If you mess up a shift but you are not even at redline yet the engine has somewhere to go, if you are in the red, sorry, don't think a rev limiter can help you there, the tranny is engaged and will spin the engine as fast as it can, cutting off the gas to the engine won't help with that. You'd be basically tourque braking in the extreme! People don't become familiar with their cars enough before going allout.
</STRONG>
So what your saying is-buy some shares of Honda?
This is not a design issue, it's customer negligence. All RSX-S catastrophic engine failures have been the result of a forced downshift under full-throttle. The majority of these failures have been in the hands of customers not adept at shifting a manual gearbox. They are slamming the shifter into whatever gate they can force it into.
The car is equipped with a rev limiter, but it takes time to slow an engine that's spinning at 9,000+ rpm.
The moral of the story - learn how to shift before playing John Force. This failure is not covered by the new vehicle limited warranty.
would floating a valve occur because the valve spring can't keep valve completely open or closed? at that point would you burn a valve and/or bend it?
yo SSMAN, meet me at carlsbad on 8/26!![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
[ 08-17-2001: Message edited by: Mike ]
Originally posted by RAdams:
<STRONG>I'd imagine this is due to the drivers. Remember that the K20A engine has been out in Japan for a little while now.. and there's no manufacturing defects with them there.
I've seen dealers with 3 or 4 GS-R's at a time with bent valves and damaged pistons from people flubbing a shift. GS-R valves don't float until about 9000 RPM on the stock valvetrain... proof that there's plenty of idiot drivers out there.</STRONG>
www.drippinwet.com
Originally posted by WI CL TypeS:
<STRONG>Yeah but a NATIONAL backorder?? That seems like a damn lot of engines. Of course I don't know how many "spares" are kept around for this type of thing. Just seems a bit excessive to me. Like I said...bad design? or bad publicity in a sense from Hollywood with everyone trying to copy F&F and get racers.</STRONG>
Moderator Alumnus
<STRONG>I asked Dan (service guy) how long to fix them and he said quite a while because Acura/Honda America is on a national backorder for the RSX engines because so many have been blown across the country.
Brenden</STRONG>
Brenden</STRONG>
Boy, sure would suck to have your car out for so long, and making car payments, AND also having to pop out the bucks for a new engine. (Which I imagine isn't pocket change)
Guest
Posts: n/a
Originally posted by ChodTheWacko:
<STRONG>
I wonder how long 'quite a while'. I can imagine with a national backorder, you could be talking a month? or more?
Boy, sure would suck to have your car out for so long, and making car payments, AND also having to pop out the bucks for a new engine. (Which I imagine isn't pocket change)</STRONG>
<STRONG>
Yeah he was speaking in months. He said it was AT least 3 weeks to get ONE engine in and he had TWO cars there. So...must suck to have to pay for all that. Heh, take a driving course next time and learn how to drive a manual before buying it. He also said the kid even asked if it was covered by warranty, heh...NOPE!
Brenden
Rock Chalk Jayhawk
Originally posted by CLpower:
<STRONG>same shit happened w/ the new celica's</STRONG>
I sure do hope this is consumer error (due to I know these are probably the same types that purchased the Si when it first came out and would race anything and everything on the block thinking their 160bhp and 111 ft-lbs could toast a Mustang GT
). I have already heard of RSX race stories where these people are driving extremely aggressive cuttin off people to insight a race to happen, with probably a total of only 50 miles on the car so far. Idiots.
Anyways, hope Honda learned from Toyota in regards the close gates, or they'll have a lot of angry customers if is indeed their fault, like this guy...
http://lemontoyota.0catch.com/
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
SidhuSaaB
05-30-2020 12:40 AM
cycdaniel
12-17-2019 10:58 AM
joflewbyu2
10-08-2015 11:16 AM
