Question on brake calipers
Mazda3 and Honda Civic in
We are changing brake pads on my 02 Si and we cannont get the caliper(rear) to compress to get it around the new pads. I even went and bought a clamp and the damn thing still will not compress.
I need some ideas and help here.
dɐɹɔ ǝɥʇ ʇɐɥʍ
If its on the rear they may turn in, if there are two notches opposite from each other on the piston then you need a caliper set to turn them back in. Or your caliper is seized, you can try cracking the bleeder free and then pushing the piston in, on newer vehicles that will usually work. Just make sure you bleed at least that side afterwards, it would probably be fine, but its better to be safe then sorry.
dɐɹɔ ǝɥʇ ʇɐɥʍ
Originally Posted by Repo1234
Have you tried releasing the handbrake!
nuldabz
09-03-2015 05:49 PM
