Project "Round and Brown" Cuckmasters in Full Effect: rockstar143 Edition
Old 07-12-2017, 03:34 PM
  #161
Received 5,832 Likes on 3,853 Posts
I'd hate cleaning those wheels.
You wouldn't have to, that car isn't going anywhere fast enough to generate brake dust. The wheels will just grind the fenders away instead.
Old 07-13-2017, 05:58 AM
  #162
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
can't believe I now have THREE cars that need premium.
Old 07-13-2017, 07:29 AM
  #163
Okay, welcome to willkommen!
Sooo...got the bulbs in for the rear left brake and parking lights being out...easy, right? NAWWW...turns out it was a burnt wire...pulled it through and soldered directly to the board. FIXED
then, one bulb out on right...okay, no problem...WRONGGG...bulb melted into one of the socket, previous owner gave up on it. Used pliers and dremel to get the bulb out and the socket cleaned up and BAM, fixed. Just need to get the led upper brake light to work and license plate bulbs and lighting will pretty much be addressed.
Center console is falling apart, but I might delete the armrest anyway because it gets in the way of the ebrake when it's set low, and it's uncomfortable when it's set too high. B pillar material is pulling off, have to glue that...I threw a screw into the broken driver door handle...worked like a charm.
I messed with the door locks that aren't working...there's an adjustment knob I played with and got them both to lock and unlock, but there seems to be a correlation between one and the other and both never worked at the same time. I'm reading up, looking like there's a switch that senses that the door is open/closed I might need to source. The fact that at some point I got them BOTH to lock and unlock tells me that the actuator is actually not bad.
I checked the oil and it's due based on color/smell...so I'll tackle that, pull plugs to check them along with swapping coil packs. My CEL seems to be multiple misfires which can be felt with the somewhat rough idle...once you give it gas, it's good to go though so I'm guessing a tune up and new O2 sensors might solve that. Honestly, I was close to checking out some 18" oem wheels...but I think my money would be better spent keeping the car on a low budget and addressing making it run nicely.
So my final impression is that although it's got issues to address, and I got overwhelmed...that's part of the fun and the car is well put together and not too complex to take apart.
JT4 (07-14-2017)
Old 07-13-2017, 07:39 AM
  #164
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
$2.19 for Regular 87 here and $2.60 for Ultra 93... i welcome high gas prices because people get scared and dump their v8's... i go car shopping
Old 07-13-2017, 08:42 AM
  #165
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
That engine bay shot is so German that you can almost smell the schnitzel.
The following 2 users liked this post by cu2wagon:
losiglow (07-14-2017), TylerT (07-13-2017)
Old 07-13-2017, 08:43 AM
  #166
Old 07-13-2017, 09:20 AM
  #167
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
Originally Posted by SamDoe1
Same. $2.96 for premo is ridiculous.
I just paid $4.42/gal at the pump, yesterday, for 91.
Old 07-13-2017, 09:31 AM
  #168
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
Originally Posted by cu2wagon
That engine bay shot is so German that you can almost smell the wiener schnitzel.
fixed for accuracy
Old 07-13-2017, 09:33 AM
  #169
cu2wagon's Avatar
Oh. I figured that smell would be coming from the steering wheel (transfer from the driver's hands).
KaMLuNg (07-13-2017)
Old 07-13-2017, 09:34 AM
  #170
TacoBello's Avatar
and why does the shifter smell like... oh god.
The following 3 users liked this post by TacoBello:
KaMLuNg (07-13-2017), kurtatx (07-13-2017), RPhilMan1 (07-13-2017)
Old 07-13-2017, 09:46 AM
  #171
Majofo's Avatar
He does handle a lot of parts
Old 07-13-2017, 09:51 AM
  #172
KaMLuNg's Avatar
you guys got me rolling...
Old 07-13-2017, 10:12 AM
  #173
German cars love vacuum leaks and idle valve issues. If you're getting misfires at idle, I'd wager that it's not the O2 sensors (that would have its own code) and instead something to do with a lean condition surrounding the idle valve (clean or replace) or a leak in a vacuum line.
Old 07-13-2017, 10:35 AM
  #174
that was a code too, Sam...lean condition and maybe even something about idle valve...
I'll have to research cleaning that up...that would be great.
Just bought oil and a filter. At least I can do that.
J.
Old 07-13-2017, 10:40 AM
  #175
Received 8,584 Likes on 6,630 Posts
J.
it pulled a p0171 and a p0507
They're related :
https://www.audiworld.com/forums/a4-...p0507-2798576/
Sam on point
rockstar143 (07-13-2017)
Old 07-13-2017, 10:59 AM
  #176
THANKS A LOT photobucket!
Johnny, and Sam...thanks...I'll look into that!
I may try and clean it...
Old 07-13-2017, 11:06 AM
  #177
Looking like there's more to it than just a cleaning...
I may order one...cheap enough and probably and likely to help clear some of my codes.
So why people buy a new PCV valve? --> PICS
Old 07-13-2017, 11:23 AM
  #178
KaMLuNg's Avatar
oh wait you said PCV...
Old 07-13-2017, 11:26 AM
  #179
Majofo's Avatar
Fixes one issue.. becomes two issues.. domino effect.
Should have just left it as it is.. if it runs better, it's going to totally take a dump.
Probably
Old 07-13-2017, 11:31 AM
  #180
maybe you're right...lol.
that would explain the rough idle and lean condition/misfires though!
Old 07-13-2017, 11:33 AM
  #181
cu2wagon's Avatar
Now that you've fixed the short in the tail lights, there's probably a bad ground in the engine.
Wait. This sounds familiar...
Majofo (07-13-2017)
Old 07-13-2017, 12:07 PM
  #182
Old 07-13-2017, 12:22 PM
  #183
CCColtsicehockey's Avatar
Received 3,662 Likes on 2,495 Posts
This actually seems like a fun project J. I enjoy trouble shooting and fixing stuff as well.
I still think you need wheels and cut springs though. OH and Tints too
Old 07-13-2017, 12:28 PM
  #184
The "short" in the taillights WAS the ground for the engine. ...
Old 07-13-2017, 12:56 PM
  #185
Turd Polisher
TylerT's Avatar
Received 3,006 Likes on 1,514 Posts
All this stuff seems normal.
185,000 miles and probably a bit neglected, not really surprised
Old 07-13-2017, 12:58 PM
  #186
Majofo's Avatar
Old 07-13-2017, 12:59 PM
  #187
Majofo's Avatar
I'm sure the big 3 is at least 20 gauge speaker wire.
Old 07-13-2017, 01:03 PM
  #188
cu2wagon's Avatar
Can probably find a kit on ebay.
Old 07-13-2017, 01:04 PM
  #189
Why eBay when you can just go on CL?
Buy a cuck, get a free big 3 kit..
Unless they're talking about a different big 3....
Old 07-13-2017, 01:13 PM
  #190
In the Mid-South meow
SuperTrooper169's Avatar
Received 2,098 Likes on 1,086 Posts
Came in here for the round and brown gang bang but all I'm seeing is a giant circle jerk. I'm outta here.
Old 07-13-2017, 01:16 PM
  #191
shocked?
Old 07-13-2017, 01:39 PM
  #192
TacoBello's Avatar
That's because we were waiting for super trooper to show up. Now that he's here, cmon errrbody... it's gang banging time!!
Old 07-13-2017, 01:40 PM
  #193
Majofo's Avatar
I'm done with him boys, hope you like the taste of poodle doodle
Old 07-13-2017, 01:42 PM
  #194
TacoBello's Avatar
Well that was quick.
Old 07-13-2017, 01:44 PM
  #195
Majofo's Avatar
his pcv valve iswas tight
Old 07-13-2017, 03:00 PM
  #196
cu2wagon's Avatar
Does audi have an equivalent?
Old 07-13-2017, 03:01 PM
  #197
KY I believe
Old 07-13-2017, 03:03 PM
  #198
Majofo's Avatar
It's probably called CuckGrease, not surprising it's not widely known
Probably not sold, only available and applied at dealership..
You can probably watch while they use it though..
Old 07-13-2017, 03:04 PM
  #199
Ahhhh... One of those craft lubes.....
You probably never heard of it
Old 07-13-2017, 03:19 PM
  #200
Majofo's Avatar
I just said that.. shouldn't you be whoring in 2G TL?
Quick Reply: Project "Round and Brown" Cuckmasters in Full Effect: rockstar143 Edition
