Problem!!!
Old Jun 4, 2005 | 11:48 PM
8grandpegged's Avatar
3rd Gear
Unhappy Problem!!!
I just did a tune-up on my 2000 3.2 TL and now my check engine light keeps coming on, and my car is bucking and shaking. All the plugs are in tight and gapped, and you cant screw up the firing order because of the harness, any suggestions?
Old Jun 4, 2005 | 11:49 PM
synth19's Avatar
define "tune up"
Old Jun 5, 2005 | 08:42 AM
Crazy Bimmer's Avatar
How many lbs did you torque down the spark plugs?
Also are you running colder plugs or stock spec ones?
Best bet is swap in the old plugs and see if that takes care of the problem.
Old Jun 5, 2005 | 10:25 PM
3rd Gear
i used bosch double platinum plugs, then i swapped in auto lite plugs. tune-up; just spark plugs and a thermostat.(the old thermostat was stuck closed) i got the plugs tight, i didnt use a torque wrench.
Old Jun 5, 2005 | 10:39 PM
mrdeeno's Avatar
It does sound like a misfiring problem though. Maybe you should use a torque wrench and recheck the tightness of the plugs as they CAN be too tight.
And as someone mentioned, try putting in new plugs or the old ones to check if you have a defective new plug, as defects rarely but DO sometimes make it past QC.
Old Jun 9, 2005 | 10:33 PM
3rd Gear
Thumbs up
I ran my OBD scanner today, all the coil packs are miss firing. this is gonna be expenseive, but oh well thank you guys for all your help
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
