Paddle shifters - column versus wheel C&D
I thought this was interesting. Got the latest issue of Car and Driver and there was a drool worthy comparo featuring the Ferrari 458 Italia (what a beauty). In it, they make this statement:
"A brief aside on those paddles, which are mounted to the steering column: Arguments exist for placing them on the steering wheel, as McLaren does, but Ferrari’s point is that you should not change gears while the wheel is turned."
It sparked my interest because when I was shopping for my TL, I also drove the Nissan Maxima and found that the paddles were on the column versus the steering wheel like the TL. I think there are pros and cons to both, but apparently Ferrari claims you should pick the gear you want BEFORE heading into a turn. Makes sense because I find them awkward to use in sharp turns anyway. I wonder if the Maxima is easier. Miss the old fashioned SportShift lever in my 2001 CL-S.
I strongly prefer autos to have the option to use the gear selector to shift (manu-matic?). I think many automakers have this option (even hyundai has it), and it is much more useful because i can make turns with both hands, and briefly tap the shifter with my right hand.. then it goes back on the wheel.
With the TL, especially for twisty back roads where you're steering wheel is rarely "center", I find that the shifters fly all over the place, especially when making tight turns. Extremely inconvenient for me.
I much prefer the setup the G37 has, where the paddles are column mounted AND there's the manual shift gate on the shift lever.
^^ The 07 Type S works in the same fashion. They got rid of the tapper in 09.
From someone with a couple hundred hours of auto-x and road track experience; I'd rather have them at my finger tips than having to make a move to the column.
The last thing you want is your thumbs getting bound up in the wheel on a switchback trying to keep the revs in the sweet spot. One thing to flip a stick where you're intending to drop one hand.
I loved the visceral feel of tap shifting gears on the shifter, but I like keeping my hands on the wheel more. I also prefer the paddle shifters be mounted to the steering column instead of the wheel so that they are always in the same place. The mental math necessary to figure out which paddle to hit if I want to downshift while the wheel is facing down is just too much for my simple brain.
I'd rather have them on the wheel just like say, your on a highway with a slight curve and you need to pass some jackass. Assuming you always have your hands at 10 and 2, I'd think it would be easier. Still, Brian Cooley on CNET ONLY wants them on the column. And just for the record, BMW changed the logic for shifting with a gate on the shifter (forward for downshift, back for an upshift).
The best kind of shifter:
I've tried different automatic shifters... IMO the best would be a button-style steering wheel mounted shifter like on late 90's-early 00's Lexus cars. Like so:
I go with the school of thought that you should be in the correct gear before the corner. The button-style shifters let you leave your entire hand on the steering wheel... all you have to do is move your thumb to downshift or tap on the back button to upshift.
Too bad those Lexus shifters were slow as hell, at least in the IS300s I've driven.... the one in the IS-F is lightning fast though.
Not sure which models/trims it applies to but the 3G TL-S auto, when in auto, will try to delay shifting when in a corner (detected via yaw sensor?) so as not to "upset" the car mid-corner.
So, at least on some level, Acura agrees with Ferrari's logic.
2G RL paddles are wheel mounted with stick capability also. If you know your car well enough
, the paddles have different textures in case you lose your spot and have to find the paddles. I have shifted many times pulling out onto a street (making a right turn), and my hands never left the wheel.
When I read up on performance driving techniques, I had always read what Ferrari was saying because a shift mid-corner could upset the car.
I know Lamborghini follows this same idea.
Porsche actually implemented that as well on some models.
[/quote]
[/quote]
It's probably a McLaren F1 car steering wheel, for whatever reason McLaren put the instrumentation on the top of the cockpit cowl in their cars. The old traditional place, all the other F1 teams including Mercedes Benz put their instrumentation on the steering wheels.
http://www.automotto.com/entry/new-f...to-compliment/
I have always wondered if they would be better on the column. The F has them on the wheel. I find it awkward to use them while turning regardless of where they are.
The wife's E350 has them behind the wheel. Doesn't really matter b/c she never uses them anyway. When I'm driving her car, I don't use them either.
If I was in a Ferrari, different story. I'd probably agree with them on the column mount...
There are times where you DO need to shift up a gear while mid corner and not having them on the wheel makes sense to have BUT that said if you wheel is turned that far that your hands cant reach where they are mounted you probably shouldnt be shifting.
My GTI w/ DSG gearbox has them placed in the perfect spot: On the wheel (behind).
Right side up shift
Left side down shift
Sure, Ferrari's logic of "don't shift mid-turn" may be sound, but I have found that now and again I will shift mid turn in a longer sweeping turn, and the paddles are right where I need them to be....no need to move my hands.
Not to mention they never get in the way like the column mounts tend to get from time to time.
Right side up shift
Right side up shift
Right side up shift
I think the wheel mount is the most useful for everyday driving, while Farrari and Lambo will cater to what us most useful on a track. Staying in gear around a corner is probably a good idea at 100+ mph. Doesn't really matter at 25.
It's not about speed, it's about weight transfer.Changing gears mid corner can transfer weight (the same as braking, accelerating, or steering to aggressively) and cause you to lose control.
The "changing gears in a corner" thing is certainly true for sportsbikes. As a rider myself I pick the gear and entry speed before I go into a turn and throttle steer out of the corner. Changing gears in a fast turn on a bike can lead to disaster.
In a car I can see how this principle would apply too. I agree with oo7spy, that this just doesn't matter if you're not going fast anyway. The vehicle would need enough torque difference while downshifting for this to matter. As for me, I have a G37 (with both the paddles and the gear shifter) and I prefer the paddles 10 out of 10 times. There is something to be said about keeping both hands on the wheel when you're downshifting to pass someone abruptly.
What about when I slow down from 70 into a gradual corner and come out going 55. Say I want to downshift a split second before completely straightening out, will I risk losing control?
So when I up shift going 25 around a gradual corner in my SH-AWD car I risk losing control?
If the speedlimit through the corner is 25mph and you're going 25 nothing will happen.
Then again it also depends on the curve?? I know long sweepers can require up shifts, or other corners that have slow entry but fast exits?
But when you're approaching a corner with your brake pedal buried, a downshift rockets you to within 1000 rpm of your redline and you're coming up on a tight turn.... you'd better take the steps necessary to make sure your car is ready to take that corner as much as you are. Heel-toe rev matching, proper braking sequence for weight transfer... so on.
Then again, I don't think you would do this in an RL anyway. It's a luxury car with a great AWD system, not a 350Z.
However, it's days are numbered.
x 1000
