Nitrogen instead of air in tires.
Anyone use nitrogen in their tires instead of air? It's supposed to hold tire pressure much longer than air and give a better ride. At least that's what the guy on the news said. Opinions? They said that it’s safe to mix the air and nitrogen if you ever need to fill the tire in an emergency.
Burn some dust here
They've been doing this in Nascar for awhile.
Aircraft tires are filled with nitrogen. It does not allow the moisture in the air to condense inside the tires. That moisture can settle into one area of the tire at high altitude and freeze and cause a severe out of balance condition upon landing.
My Work is Done Here
1 Post
My CL is great and all, but I'm not so worried about this happening with air in my tires.
Oh, and another thing. It doesn't expand and contract as much either. So the pressure stays more constant with changes in temperature.
Received 2,329 Likes
Nitrogen is complete overkill for 99.9% of people.
Tuxedo Cat
Nitrogen is somewhat less able to escape through rubber than some of the other gases in compressed air. So there is a bit more stablity.
It is a bit less sensitive to temperature, but within the normal operating range of street tire temps that's unlikely to be an issue.
Aircraft tires use nitrogen because it is guaranteed 100% dry, so the issue of condensation at very low temperatures experienced at altitude disappears with nitrogen. In truth, any completely dry gas would achieve the same result, but nitrogen is used because it is relatively cheap and also inert.
http://www.tirelast.com/id15.html
I think it may be a bit over-kill. They also say that it will increase your gas milage by reducing road resistance.
Still trolling
99.99999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 99999999999999999999999999999999%
Spinnin them beats
99.99999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 9999999999999999999999999999999976
If it were easily available, and cheap, I'd fill all my tires, and the tires of my parents, sister, girlfriend, etc with it.
Why? Because they never check their pressures, and the only time it is checked is when I do it every so often, only after noticing a severely deflated tire.
On my 19's if it does leak less, Id use it just to make sure I am always up to the proper PSI which would make me less prone to bends.
So the $100 question is, where do you find Nitrogen gas that can be used to fill your tires?
Learn to swim
what about no air at all
http://www.michelinman.com/differenc...01102005a.html
Registered AssHat
Originally Posted by Dan Martin
Isn't air 80% nitrogen anyways? I think this is just another way to squeeze you for a few bucks.
Edit Sorry it's 78%:
80% hahah ur lame.
Originally Posted by Lung Fu Mo Shi
80% hahah ur lame.
Mile High
Originally Posted by Always Dirty
I only fill my tires with air directly from the supple, pink lungs of a baby panda bear aged 6 months or less. And not one of those ghetto captive/zoo pandas, either.
I just check my tires a couple of times a month. Besides, tire pressure changes as climatal conditions do, so you still need to deflate or inflate the tires to the proper pressure. Sounds like a bunch of hype and waste of time and money to me.
Originally Posted by Acuraluvr
i believe its
Dude, you guys are idiots. In order to have 99.99999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 99999999999999999999999999999999999999999999999999 9999999999999999999999999999999976 % of people you must have a minimum of 10^150 people. There has never been so many people in the history of the universe and nor will there ever be (heck, this number is larger than the number of atoms in the universe).
Photography Nerd
Registered AssHat
Originally Posted by badboy
the million dollar question is not where do you get N2, but how do you fill your tire to 100% Nitrogen??
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
It's very common in race cars, most use nitrogen. Doesn't escape as easily and doesn't fluctuate as much when the tires are warm. Most of the guys I detail cars for swear by it
I just watched this video:
http://www.n2revolution.com/
and in there they state that if you are a costco member you can go there and fill up your tires for free with nitrogen even if you haven't bought tires from them.
