Is my tire repairable?
Old Apr 24, 2013 | 12:18 AM
Mongolian's Avatar
I used my continental DWS 2k miles now and I noticed a small bolt in the highlighted area of the picture below. That area is towards the inside of the wheelwell.
Can legitimate tire shops repair this?
Old Apr 24, 2013 | 12:23 AM
Hapa DC5's Avatar
אני עומד עם ישראל
I wouldn't put my family in a car with plugged tire that close to the sidewall.
No road hazard warranty?
Old Apr 24, 2013 | 12:27 AM
Mongolian's Avatar
Didn't bother to get it since I rarely drive this car. So no good?
Old Apr 24, 2013 | 12:32 AM
Hapa DC5's Avatar
אני עומד עם ישראל
You can plug it. It probably would be fine for daily driving. Would I risk it? Probably not. If you asked the broke 21 and under version of me I would've drove it on multiple plugs
But if I can afford a new tire, I'd just get a new tire.
Old Apr 24, 2013 | 12:35 AM
Mongolian's Avatar
I will personally never do any tire repair myself, but wanted to know if a reputable tire place would repair this for me.
If they say no, then no choice but to get another tire....
It's currently not leaking any air.... Looks like there is a high likelihood that I'm going to get bent over.
Old Apr 24, 2013 | 12:38 AM
Hapa DC5's Avatar
אני עומד עם ישראל
That would be very close for a patch, a plug would work. Just that increased chance of a blow out wouldn't jive with me.
See what they say tomorrow.
Old Apr 24, 2013 | 02:20 AM
Will Y.'s Avatar
Registered but harmless
Probably; it looks like the bolt is not in the sidewall.
A reputable shop will both plug the hole and put a patch on the inside of the tire after removing it from the rim.
Should run between $15 and $30 in SoCal.
Old Apr 24, 2013 | 06:55 AM
fsttyms1's Avatar
I have had many tires plugged in that area and never had an issue (we are talking probably 100k combined miles). Now if you plan on doing some top speed runs it may not be advisable, but for every day driving have it repaired and dont worry about it.
Old Apr 24, 2013 | 11:35 AM
SuperTrooper169's Avatar
In the Mid-South meow
Definitely fixable by a pro tire repair place. Not even close to being a danger after it's plugged/patched.
Old Apr 24, 2013 | 02:49 PM
jgj925's Avatar
ive had plugs even closer to the sidewall and ive never had a problem driving it daily
Old Apr 24, 2013 | 04:27 PM
AnthraciteAspec's Avatar
RPF1+RS3 FTW
Same here, plugged many tires in the past and haven't had any issues. If you have the money though just get a new one. Recently I had a similar issue and I just decided to buy new. However someone wanted my old one, plugged it, and is running it at the track with no problem.
Old Apr 24, 2013 | 05:15 PM
1StGenCL's Avatar
958 & 991
Plug, no problem
Old Apr 24, 2013 | 07:01 PM
Moog-Type-S's Avatar
The sizzle in the Steak
You can plug it.
Old Apr 24, 2013 | 07:08 PM
dozabeast's Avatar
I've had my tire now for 2 month driving fine with similar area plug .
Old Apr 24, 2013 | 07:38 PM
terdonal's Avatar
Plug should be fine IMO.
Old Apr 24, 2013 | 07:48 PM
Hapa DC5's Avatar
אני עומד עם ישראל
And what did they say?
Old Apr 24, 2013 | 07:52 PM
Mongolian's Avatar
I can't take it in until this Friday. I'm still away on Business Trip
Old Apr 24, 2013 | 07:54 PM
kwesley2's Avatar
Yes it is long as you can feel cords
Old Apr 24, 2013 | 09:22 PM
Mongolian's Avatar
When you guys mention plug it, are you referring to me doing it or have the shop do it for me. America's Tire is my go to place. I will not try plugging the wheels myself. I need to know if Anericas Tire would fix this.
Old Apr 24, 2013 | 09:27 PM
jgj925's Avatar
call me cheap but i just take mine to the exxon by my house
Old Apr 24, 2013 | 11:55 PM
Will Y.'s Avatar
We're referring to a shop doing it.
Go to a tire place like America's Tire or a reliable mechanic-- they will remove the tire from the rim, put a patch on the inside and a plug in the hole before remounting the tire.
That assumes that the bolt penetrated your tire-- I just noticed you said it wasn't losing tire pressure. If the bolt didn't penetrate the tread, no patch or plug will be applied.
Old Apr 25, 2013 | 01:15 AM
Hapa DC5's Avatar
אני עומד עם ישראל
America's Tire will patch it for free if they can patch it.
Old Apr 25, 2013 | 06:03 AM
dallison's Avatar
registered pw
If i wouldn't put it on my wifes' car then i would say replace it.
Old Apr 25, 2013 | 08:55 AM
RaviNJCLs's Avatar
You should be fine.
TLDude876
Dec 28, 2016 03:18 PM
niray9
Dec 8, 2015 07:34 PM
Trav2390
Oct 20, 2015 07:30 PM
Doc.Hollow
Oct 10, 2015 08:16 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
