Looking for feedback on common maintenance items
I just wanted to get a feel for anyone's experience with certain brands/parts from any manufacturers. I need to make the right decisions as part of my job and hopefully we can all learn from each other as well. I'm more interested in bad experiences with well-known brands/sellers and common maintenance items but anything will help.
Just throwing these out there.... anyone have experience with A1 Cardone? They make a lot of remanufactured parts. I'm curious about Autozone Duralast pads and their rotors, as well as Wagner's Thermoquiet line too
Vortex "graphite metallic" brake pads
- good initial bite, dusting is eh, not too bad. No fade with spirited canyon driving, no track experience with them though
Raybestos advanced technology blank rotors
- no warpage, hats are still rust-free
Koni Yellow shocks, single adjustable
- worth every penny
Beck Arnley ignition
- supposed to be OE on certain cars, no problems
BBB remanufactured alternator
- no charging system issues
Interstate Battery
- all I know is that it has a green top, and started my car without hesitation even after not being driven for a month. No tender used either
Moog bushings
- great, though anything is probably an improvement over bushings with 150k+ on them
Goodyear and Gates belts/hoses
Sylvania Silverstar bulbs
- dunno why, but these seem to go out prematurely. I wear clean gloves during install and even then I avoid touching glass
- worth every penny
Interstate Battery
Moog bushings
It's the Halladay season!
Moog sway bar end links
-A lot beefier than OEM, and much easier to remove/install
Raybestos re-manufactured rear brake calipers
-They're holding up fine through a NE winter (about 8-9 months total if I remember right)
-The paint/coating is horrible. They have a lot more rust than my original fronts with 125k on them. I would recommend anyone buying them to paint them with a quality caliper paint before installing.
Interstate Battery
Interstate Battery
as for rotors, it seems like anything is better than the Honda/Acura oem rotors that warp if you just look at them wrong... but most of the 'made in china' rotors nowadays are cheap and will just be replaced at every brake pad change since it isn't worth the tme on the lathe to resurface them...
Beck is oem on some cars...
since discovering Costco batteries, i have never turned back to any other brand sold by autozone or advanced...
and +1 on the Gatorback belts... it must be a Toyota thing, because on the GS and Corolla, which had brand new OEM belts, developed a chatter within a few hundred miles after replacement... was annoying... fixed after switching to the gator belts...
In the Mid-South meow
I put Duralast brake drums and shoes (rear) and rotors and pads (front) on my wife's Corolla about two years ago and they've been excellent. No issues what-so-ever and they have a warranty, so thumbsup from me on those.
AZ Community Team
I had the same experience with Silverstar bulbs. Oddly enough Walmart used to carry these Silverstar knockoff's in the most tacky retail packaging one could imagine, but they were ~1/3 the cost and lasted a couple years where none of my Silverstars made it past a year in my wife's Pilot.
A1 Cardone - I've used their re-manufactured calipers and they were fine, never had a problem and were priced OK.
Used Duralast pads before and they are OK in performance and costs.
RE: Duralast pads.
A few people I know who've had to deal with premature rear brake pad wear use them on their 8th gen Accords and pretty much swear by them. They last a long time and don't dust too much either. Their life time warranty is a bonus too.
RE: Silverstar bulbs
They burn out quicker because they also burn hotter. By burning hotter, they're able to produce more visible light. It's just the way they are.
Costco batteries are made by Johnson Controls which happens to also make Optima, DieHard, and Duralast batteries. That's why they're so good.
The rear calipers on the Infiniti were replaced and the mechanic went with A1 Cardone. Only had them for about 20K miles but no issues.
The sizzle in the Steak
MrHeeltoe
20
02-23-2023 01:54 PM
kb1rl
09-30-2015 10:17 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
