LED's in the Accord
Old Jan 14, 2017 | 03:58 PM
TL-GIXXER's Avatar
LED's in the Accord
With all of the LED lighting on the front (and rear) of the car, I'm surprised that Honda didn't just throw LED bulbs in the projector housings
Huge improvement both visually and functionally. 5 minute swap/install
Old Jan 16, 2017 | 02:23 PM
eastcoastguy's Avatar
The higher models they have LED headlights so it is probably a cost saving thing and to get people to spring for the higher model.
Old Jan 17, 2017 | 01:26 PM
CLtotheTL32's Avatar
Looks much better!
Old Jan 17, 2017 | 01:29 PM
I believe some V6 and Touring models have the LED headlights and they look pretty damn
Old Jan 18, 2017 | 04:16 AM
F23A4's Avatar
The Accord Touring has a version of jewel eyed headlights. Note: The 9G version differs from the 9.5G.
Old Jan 18, 2017 | 09:28 AM
FFS.. the damn Accord looks better than the new TLX's
you fucking up Acura..
Old Jan 18, 2017 | 04:02 PM
TL-GIXXER's Avatar
Ordering up the OEM optional grille next:
Old Jan 18, 2017 | 04:58 PM
Legend2TL's Avatar
AZ Community Team
I ordered a pair of LED H4's (Banggood) for my wife's 2003 Pilot so I'm curious and will report back how they'll work when they arrive.
Pair 36W 6500K 4500LM H11 H7 H4 HB3 HB4 LED Headlight Driving Fog Lamp Bulb White Sale - Banggood.com
Old Jan 18, 2017 | 06:49 PM
oonowindoo's Avatar
you guys are lucky that the Accord came with projectors.
I installed some LED headlight bulbs in my GF's civic (08) with the reflector housing, the output was laughable. Now she is back with HID again....
Old Jan 18, 2017 | 06:52 PM
oonowindoo's Avatar
Unless you have projectors, otherwise i say don't expect much.... The one i used was 50w... all it did was form a "white cloud" in front of me. It did not even have any hot spot or cutoff of any sort. The light just "evaporates" in the air.
Old Jan 19, 2017 | 12:15 PM
Legend2TL's Avatar
AZ Community Team
Haven't received them yet, but will take a pic of one LED and one halogen H4 to compare when I install them
Old Jan 19, 2017 | 12:45 PM
oonowindoo's Avatar
Are you using them for Fogs or Low beam?
Old Jan 19, 2017 | 01:28 PM
Legend2TL's Avatar
AZ Community Team
^ low/high beam H4
Old Jan 19, 2017 | 10:03 PM
TL-GIXXER's Avatar
H11 low
Old Jan 22, 2017 | 08:22 AM
Legend2TL's Avatar
AZ Community Team
Results of two LED H4 bulbs from Banggood in a 2003 Pilot
Low Beam - Extremely good, the white light really illuminates the road in front and to the side.
High Beam - Fair, distance is not great but I need to to aim the headlight which I haven't done yet.
The only negative is the cooling fan despite being small is heard if the engine is off.
Other than that definitely worth $28 for a pair.
Some pics, I need to aim and polish the headlight lens (they're fairly frosted now).
Old Jan 22, 2017 | 08:41 AM
fsttyms1's Avatar
Now please do the other drivers on the road a favor and take them out. You are creating unnecessary glare for other drivers on the road.
Old Jan 22, 2017 | 08:59 AM
Legend2TL's Avatar
AZ Community Team
Not a single person so far has flashed their high beams so far the past couple nights.
I looked at them from the front, they are bright no doubt but not excessive glare by any means.
I was thinking the same when I did some research online from LED's in older reflector headlamps.
One factor is that headlamp designs are so different on modern vehicles that I suppose it's possible on some LED application on older H4 designs to be OK glare-wise and other designs to be excessive.
Old Jan 22, 2017 | 10:30 AM
Comfy's Avatar
2014 RDX AWD Tech
Appreciate you sharing your mod. Can you post a picture of your headlights on to a flat vertical wall about 25 feet away from your car. It'll provide a better perspective regarding glare than light on the road for the low beams.
My guess is your high beams will be nothing more than a diffuse white wash instead of a well centrally focussed beam. I hope I am wrong.
Thanks.
Old Jan 22, 2017 | 10:34 AM
Comfy's Avatar
2014 RDX AWD Tech
Agree with this 100%.
Old Jan 23, 2017 | 11:25 AM
oonowindoo's Avatar
Thx.... It does not seem that 03 Pilot has projectors in low beam,... so i am very confused about how different the result is compared to the ones i put in the Civic ($70)
Old Jan 23, 2017 | 05:35 PM
havok1212's Avatar
5th Gear
I used Led fogs from Vled on my evo and the were worse the the stocks ones
Old Jan 24, 2017 | 10:10 PM
Legend2TL's Avatar
AZ Community Team
Thanks.
I'll get another pic with a flat brick wall in the future but here's the view on garage doors.
Low Beam
High Beam
FWIW, I tried this headlight lens clearcoat solution from Duplicolor. I'll see how it does over time.
After the application of the kit above.
Old Jan 25, 2017 | 03:32 PM
oonowindoo's Avatar
^ there is a major difference between your "lights on the wall" picture than the one i had in the Civic. Yours at least had some kind of line or cut off. Mine was just a mist of light even when i pointed it directly to a wall. "sigh"
I have tried all different kind of headlight restoration kit, the conclusion is unless you have to use sandpaper, otherwise it will only last up to 1 month or so.
Old Jan 25, 2017 | 03:34 PM
Do a retrofit! I did a few Civics and they were definitely better cutoffs
Old Jan 25, 2017 | 03:37 PM
oonowindoo's Avatar
meh.... It's my gf's car. i wanted to do something "nice" for her, so i got her some LED bulbs.... and had to return them.
Retrofit is too much work, might just encourage her to get a new car instead i live by my own words
Old Jan 25, 2017 | 03:39 PM
I'll do it for her
Old Jan 26, 2017 | 09:28 AM
Legend2TL's Avatar
AZ Community Team
I'll post some pics after six months with the DupliColor headlight clearcoat, it was a pretty good kits. I got tired of re-polishing the lens every year, so I'm hoping it lasts a few years.
As for the LED H4 bulbs, there's a large amount of variability in the performance of LED bulbs in general but especially in low voltage vehicle bulbs.
The older LED's headlight and light bulbs that had a large number of lower power LED's are worthless.
The newer high power Chip-On-Board (COB) are much better in lumen per watt efficiency and have far better thermal management so I decided to try them out.
The H4 pic above only has three elements (they appear to be identical), two for the low-beam and one for the high beam (which is offset to mimic the traditional H4 filaments.
I turned them on outside the headlight housing and are incredibility bright even without looking at them.
Old Jan 26, 2017 | 09:33 PM
Comfy's Avatar
2014 RDX AWD Tech
I'll get another pic with a flat brick wall in the future but here's the view on garage doors. Low Beam High Beam FWIW, I tried this headlight lens clearcoat solution from Duplicolor. I'll see how it does over time. After the application of the kit above.
Thanks for the pictures. These look pretty acceptable to me. If at all there is glare it could be easily controlled by tilting the headlight downwards. I like the way the new LEDs are evolving. Great job.
Old Jan 31, 2017 | 03:18 PM
I agree that the LED technology is getting significantly better but that's not the bottleneck. The LED bulbs in a halogen reflector perform very poorly because it's not the proper application from an optics perspective. Same as HID's in a halogen reflector housing.
Old Feb 3, 2017 | 03:50 PM
quanaman's Avatar
TL-S
Love my sport grill, changes the look of the car IMO. I need to step up my lighting game as well though!
Old Feb 4, 2017 | 08:19 AM
Legend2TL's Avatar
AZ Community Team
LED's by design and physics are cone type optical spreading and incandescent are kinda spherical (most car headlight filament bulbs are vector filament), that's why the better LED's are emulating the filament bulbs with their LED placement.
I won't say they perform poorly, on low beam the LED's I installed were superior to the halogen H4's. Some LED's that are not well designed do perform poorly. The H4 (or any filament replacement) LED's light pattern needs to act like a filament in their optical output to be effective.
Old Apr 19, 2017 | 05:32 PM
FreddyBeach's Avatar
Of course, LEDs came standard on my new Acura RDX and I was truly amazed how much easier night time driving is. Although I almost always offer the courtesy of dimming my high beams when I see a glimpse of oncoming traffic, I had just purchased the RDX and was not paying as much attention to oncoming traffic as I should have. Believe me - the oncoming traffic reminded me!!
