Is it Illegal to Drive a Right Side Steering in the US
my guess would be...
because it is in order of operations, while having R and D as far away as possible for safety reasons (although, an accidental switch from D to R will do nothing to a modern day car).
so unless you have a circular driveway, or drive a monorail, i would assume you would want to go in the opposite direction in which you arrived in. so, P, then R, then D. (while the placement of N was originally used as a safety buffer zone).
if you want to impress a chick, change that markings to PEMDAS and tell her its in order of operations.
I don't see how that has anything to do with it. The PRND shifter is simply a control unit that talks to the transmission. You can lay the gears out however you like and as long as you keep the required pattern, you're fine.
Most new BMWs don't even have that layout anymore, it's that stupid joystick thingy. I don't think the shift lever is directly connected to the transmission, it's just a unit that sends a signal.
The R34 has become even more impossible to get into the US after last month. Actually, the whole incident has probably made it difficult for any Skyline.
I haven't driven a stickshift RHD car before, but it seems like LHD is more intuitive for shifting
If you think about it, for LHD you're shifting up by pushing up and away from you.
RHD, you're pushing up and towards you
In both LHD and RHD you just push straight back so you can use any variety of hand grips. But most people have more dexterity with their right hand than their left hand either way.
I would say shifting requires more precise hand movement than steering. Steering requires more precise.... arm movement. I'm write handed so when I right with my left hand it's sloppy as hell. I imagine my left hand would be less precise than my right
I just felt like being annoying with the right/write/left thing
Exactly. I guess back in the day having that pattern might have drawn the ire of transmission engineers but with computers controlling everything, it's not the big deal it might have once been.
mike from annapolis
May 7, 2017 08:21 PM
rockyboy
Jan 25, 2016 06:00 PM
