HIDS dont light up. HELPPP
Old Jan 4, 2009 | 02:15 PM
swiftt5389's Avatar
Azine i need your help desperately.
I just installed my dual beam HID headlights and they wont light up
when i switch fron low to high beam they move like they are supposed to but nothing lights up.
can someone help.
have any ideas. Its gunna get dark soon so i need some help fasttttt
Old Jan 4, 2009 | 03:01 PM
Crazy Bimmer's Avatar
What do you mean they "move" when switched from low to high?
Does your low beams work? Check the ground first of all and make sure its connected.
Old Jan 4, 2009 | 03:25 PM
swiftt5389's Avatar
i checked all my grounds and connections.
low and high beams both dont work
its a dual beam (9007) and what i mean by move is like when u click on the high beams the bulbs push backwards literally. but no light watsover
im at a loss
got my silverstars in til the morning
then hopefully figure something out
Old Jan 4, 2009 | 03:30 PM
FiftyFive's Avatar
Moderator Alumnus
What kinda kit are you using? Make sure none of the connections are plugged in backwards, I've seen that happen plenty of times.
Old Jan 4, 2009 | 04:46 PM
swiftt5389's Avatar
i am using this kit
http://cgi.ebay.com/ws/eBayISAPI.dll...:X:AAQ:US:1123
i reconnected everything twice.
still nothing
Old Jan 4, 2009 | 05:30 PM
mitch14's Avatar
CL in lawnmower status
my kit looks exactly the same as yours, except mines only lowbeam. i had mine wrong the first time i plugged them in and all i did was flip the connector going into the ballast the other way, so what side i thought should be power(the red wire) and the side i thought to be ground (the black wire) just flipped the postion of those parts going into the ballast. if it all makes sense and you've tried connecting it in different ways then it might be a bad kit
Old Jan 4, 2009 | 05:31 PM
SuperTrooper169's Avatar
In the Mid-South meow
Did it come with a relay wiring harness? If so I'd check the fuse in the relay and see if it's blown or bad.
Old Jan 4, 2009 | 08:34 PM
phee's Avatar
I got the Shifts
reverse polarity
Old Jan 5, 2009 | 12:01 AM
swiftt5389's Avatar
i have had a lot of people tellin me to check and see if hte plug into the ballast is backwards. so ill check tomorrow and then update you peeps
thanks for all the help thus far =P
-Kyle
Old Jan 5, 2009 | 07:31 AM
FiftyFive's Avatar
Moderator Alumnus
^ I'm pretty sure thats it, i did the same thing when i installed mine the first time, drove me crazy.
Old Jan 5, 2009 | 09:53 AM
swiftt5389's Avatar
Shwinggg.it worked haha.
and im with you fiftyfive. I was PISSED yesterday lmao
o well cant wait to see them at night now.
Old Jan 5, 2009 | 09:55 AM
JS + XES's Avatar
I drive a Subata.
glad to hear that.
Old Jan 5, 2009 | 10:17 AM
mitch14's Avatar
glad to hear they work, you'll love them at night
Old Jan 5, 2009 | 10:29 AM
FiftyFive's Avatar
Moderator Alumnus
I did the exact same thing when i first got my kit. I was pissed and emailed the company, figured it out about 15 minutes later.
Old Jan 5, 2009 | 11:50 AM
swiftt5389's Avatar
haha I emailed the guy too lol.
thanks for all the help. cant wait for nightime.
jsut got done organizing the wires with a buttload of zipties.
get this, my relay and ballasts are mounted with zipties haha
Old Jan 5, 2009 | 12:08 PM
EuRTSX's Avatar
My HID fogs were mounted with zipties too.
Worked for me.
Old Jan 5, 2009 | 12:14 PM
FiftyFive's Avatar
Moderator Alumnus
As long as they are thick enough you should be fine.
Old Jan 5, 2009 | 12:27 PM
swiftt5389's Avatar
yea they are pretty thick.
should hold up pretty well.
Old Jan 5, 2009 | 12:32 PM
mitch14's Avatar
i still need to ziptie my wires, i'm so damn lazy
i mounted my ballasts using 3M double sided tape and it's held up good so far, plus mine's a cheap kit so i don't care if it bounces around in my engine bay, aslong as it doesn't damage something else
cycdaniel
Dec 17, 2019 10:58 AM
pozebly
Sep 23, 2015 07:30 AM
JnC
Sep 11, 2015 06:06 AM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
voigt
Sep 2, 2015 10:44 PM
