Here is a new ride at my work
Honda HSV-010 GT: Specifications and performance characteristics
Dimensions, weight
Length × Width × Height (m) - 4.675 × 2.000 × (not disclosed)
Wheelbase (m) - 2,700
Vehicle weight (kg) - 1,100 or more
Engine
Engine name - HR10EG
Configuration - Liquid-cooled, naturally aspirated, longitudinal V8
V angle (°) - 90
Valve train - Gear-driven DOHC: 2 intake and 2 exhaust valves per cylinder
Displacement (cm3) - 3397
Bore × stroke (mm) - 93.0 × 62.5
Compression ratio - (Not disclosed)
Maximum output (kW[PS]) - 370 (500) or more
Maximum torque(N m[kg m]) - 392 (40.0) or more
Throttle control system - Mechanical
Fuel supply system - Programmed fuel injection system (Honda PGM-FI)
Fuel - Lead-free premium gasoline
Lubrication- Dry sump
Powertrain, running system
Transmission mechanism - Constant mesh
Transmission shifting method - Steering paddle shifter
Steering system mechanism - Rack and pinion system with electric power steering (EPS)
Tires(Front Rear) - 330/40R18 330/45R17
Brake type and mechanism - Hydraulic ventilated disc system
Suspension system - Double wishbone
Stabilizer - Torsion bar
Dimensions, weight
Engine
V angle (°) - 90
The Third Ball
Received 4,967 Likes
Does nothing for me
6 Forward 1 Back
2,700 meter wheelbase! Whoa. The front is turning 5 minutes before the back catches up.
AZ Community Team
Looks nice, love the "or more" used for weight, power, and torque specs
In the Mid-South meow
I like!
I drive a Subata.
I love it.
Sweet, too bad this will pretty much never see the street.
you guys need to hear this thing, sooo nice. Its suppose to be going up against the gtr.
<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/lCqY-vAX4EA&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/lCqY-vAX4EA&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
Someday, an RS6 Avant+
Nice "no we're not going to produce a NSX replacement but look at this" car.
I like it.... now Honda just needs to whip Acura back into shape and all will be well.
The Sicilian
Preety impressive. The thing sounds like a formula 1 car.
AZ Community Team
dɐɹɔ ǝɥʇ ʇɐɥʍ
I hate to be an optimist but I can easily see that thing being de-tuned, un-widebodied and available as a very attractive production coupe. As much as I love the K-series engine I hope they would put something a bit more robust in it. If you strip away some of the raciness of this, it looks very viable, remove the wing, bring in the fenders quite a bit, remove the scalloping from the hood and you'd potentially have a rival for the 370z.
Then again I knew I said I was being an optimist at the onset of this post...
The sizzle in the Steak
trainwreck thread
rockyboy
08-04-2024 10:35 AM
rockyboy
01-25-2016 06:00 PM
