Guess-timate...how much for a 1996 Accord radiator and install price.
The top of the radiator in my 96 Accors 4 cyl. is leaking...not too bad, but its leaking. How much would you guys estimate the cost of a new radiator and install?
Coincidently someone was asking about a radiator for a 97 accord here:
https://acurazine.com/forums/car-talk-5/1997-honda-accord-smoke-radiator-381806/
You could probably DIY for under a few hundred, but it's gonna be pricey if you have some one else do it...
I would just get rid of the accord and get a new car
When my 95 Accord's radiator cracked, I paid $100 for the Koyo radiator replacement. Koyo is very good replacement. The labor took about 1 hour to remove, replace, and pour the coolant in.
If you're good with wrenches, it's not a difficult task.
if your paying for the labour it will probably be 400, if you DIY 150-200. I replaced the rad on my 95 Accord, Auto w/ A/C, it's not hard at all. Remove the fans, unhook the coolant and trans cooler lines, 2 bolts on top holding the rad and Poof it pulls straight up.
do it yourself, it is easy. less than $100 at www.rockauto.com plus $10 for the gallon of antifreeze, not the 50/50 stuff
Originally Posted by o1s
or get one from a junkyard. you could do the complete swap including fluids for $25.
Just spend an extra $100 or so and get a new one, unless you enjoy replacing radiators.
Originally Posted by SodaLuvr
And find out a month later that it was completely clogged as the last owner never changed the coolant?
1.6 to 2.1 flat rate hours depending on whether or not it has an automatic and/or A/C.
Probably $200 for a radiator with mechanic's mark-up, less if you DIY obviously.
cycdaniel
12-17-2019 10:58 AM
InFaMouSLink
10-27-2015 06:51 PM
