G35 Owners: I Need Help
Old Mar 7, 2010 | 08:18 PM
CLtotheTL32's Avatar
So the Slip, VDC, and Parking Brake lights will not turn off in my dad's 05 G35x. It doesn't matter what gear it's in, if you are stopped or moving, or anything.
I've been telling my dad to take it to the shop, but he's been out of town quite a bit recently and hasn't had the chance. I'm no car expert, but maybe a sensor has been knocked loose or something.
Any ideas?
Old Mar 7, 2010 | 08:26 PM
Jiggy2dmax's Avatar
This had happened to a buddy of mine....it was a brake issue. IIRC he needed brake fluid and new pads....it had something to do with the VDC system. However, don't quote me on this.
Old Mar 7, 2010 | 08:29 PM
phee's Avatar
I got the Shifts
uh oh.
if this was an acura: transmission
since its infiniti: probably brakes
Old Mar 7, 2010 | 09:10 PM
nova_G's Avatar
eat, sleep, NGC
I had this same problem. Tell him to check the level of the brake fluid and if it isn't filled to the max it should be. Nissan's sensor is really really sensitive so it'll through those lights if it's low. If that doesn't work take it to the dealership but this is a pretty known issue on g35driver.
http://g35driver.com/forums/brakes-s...light-all.html
Old Mar 7, 2010 | 09:17 PM
mrdeeno's Avatar
It's most likely the brake fluid low and/or worn pads (which leads to low fluid in the reservoir). I have an M45 and it does the same thing when brake pads are worn. Mine was like that since November and I knew it was my front pads (it did the same thing when my rear pads were worn about 10k miles ago, so I knew it was the fronts and especially since they've been squealing pretty badly), but since it was garaged for the winter anyway I didn't replace my front pads until yesterday...all lights are back to normal.
If it's cold out and pads are slightly worn, it'll come and go out when the brakes heat up or if the weather warms up, but eventually the pads will wear further and it will go on and stay on, so plan on having the pads checked and replaced if worn. If it doesn't go out if pads are replaced or aren't worn and fluid is full, then it could be another problem that needs to be checked by the dealer.
Old Mar 8, 2010 | 08:58 AM
Thank you all for your help! I emailed a link to this thread to my dad so he can check it out instead of me trying to explain it to him.
Old Mar 8, 2010 | 09:08 AM
vas25tl's Avatar
The Box
If it was a BMW, it would be a speed sensor. on the G though.
Old Mar 8, 2010 | 11:17 PM
Mongolian's Avatar
You should first check your brake fluid. If it is low, either the front or back pads are most likely done.
Old Mar 9, 2010 | 06:43 AM
Like phee said, if this happened in my TL, it would probably be the transmission
He doesn't drive often, but when he does, the brakes squeak on the rear left side. I guess the car is smarter than we are
Old Mar 9, 2010 | 09:06 AM
mrdeeno's Avatar
Just rear left? I hope both rears are worn. I don't know about the G, but my M's wore out the rears at about 20k miles and the fronts at about 35k...but the rear pads are also thinner than the fronts new. Not sure of the compound though.
Old Mar 9, 2010 | 12:55 PM
It sounds like the rear left mostly, but considering it's loud as shit, it may be covering up the noise from the right one.
My dad bought the car two years ago with 40k miles. Now it's sitting at 54k. Everything was flawless when he bought it, he had a lot of stuff done to it maintenance wise. Maybe it's just time for new pads
Old Mar 9, 2010 | 01:13 PM
subinf's Avatar
One on the right for me
I do quite a bit of work on my friends 04 G35 and his rear pads wore out as fast or faster than his front pads.
He also gets the lights the OP has. I've pulled the pads, cleaned everything, and flushed the fluid and the lights still appear intermittently
Old Mar 9, 2010 | 01:15 PM
Hopefully ours will be going to the shop soon. Both my dad and I told the guys there that the brakes were squeaking under light braking, but they couldn't replicate it.
Old Mar 9, 2010 | 01:19 PM
bgsm1th's Avatar
on to the next one...
Exclamation Speed Sensor
if it's not brake related, it's the speed sensor. I had a 2001 Infiniti I30t that had those exact lights on and it was a faulty rear speed sensor.
Old Mar 9, 2010 | 01:23 PM
Son of a....
Is that something that's crucial that should be looked at asap or can it wait a week? My dad drives 8 miles round trip daily
Old Mar 9, 2010 | 01:39 PM
bgsm1th's Avatar
Son of a....
All it did on my car was de-activate the traction control and the ABS, so no, it was not crucial to short-term driving - I had the lights on for three months before I figured it out...
With that said, go with the path of least resistance first - Brake Fluid, Brake Pads, and if that doesn't work, check the sensors...
Old Mar 9, 2010 | 01:48 PM
Will do. Thank you everyone for your help
Old Mar 9, 2010 | 02:45 PM
subinf's Avatar
The light also came on when his clutch was pretty much shot. It didn't made any sense. His car is sort of a mystery. It was totaled a few weeks ago (I don't understand that either since there was hardly any damage) but I guess it is better to be rid of the thing.
Old Mar 9, 2010 | 03:52 PM
Hm. Hopefully it's not the transmission. My dad's is an automatic.
Old Mar 9, 2010 | 04:39 PM
mrdeeno's Avatar
Well, its not an Acura so immediately that reduces the chance of a transmission problem like 90% already
But seriously, as mentioned above, path of least resistance is brake fluid/brake pads. I've already had the lights occur on 2 separate occasions on my car and both times it was the brakes, first rears then fronts. Your fluid being low may be the direct cause of the lights coming on, but i would check the brakes before filling/flushing it since putting on new pads, if they're worn, would bring the fluid level back to normal enough to turn the lights off. And if the brakes are squealing, then that's just another indication it's time for a brake job.
Old Mar 9, 2010 | 05:15 PM
Majofo's Avatar
Originally Posted by phee
uh oh.
Old Mar 9, 2010 | 06:12 PM
Damn Acura!
Sounds like it's time for a well needed trip to the shop.
Thanks again
Old Mar 9, 2010 | 11:43 PM
Shoofin's Avatar
I don't think the display will light up like an x-mas tree for low brake pads. I can almost guarantee that it's a sensor, probably ABS.
You could always plug it into an OBD2 reader and it would tell you what's up..
Old Mar 10, 2010 | 12:58 AM
tmnhs81's Avatar
OBD2 scanner's don't read ABS codes..
Old Mar 10, 2010 | 06:54 AM
Shoofin's Avatar
Mine does.. :wink:
Old Mar 10, 2010 | 08:54 AM
mrdeeno's Avatar
I would like to see you guarantee that it's a sensor...even though from my experience as an infiniti owner and the experiences of many other owners on infiniti forums indicate otherwise.
It's not lit up for low pads, it's lit up for low fluid, which is an indication of low pads.
My M did this on 2 separate occasions at around the same mileage that other M owners were reporting having their pads replaced. After my pads were replaced, lights stopped coming on.
This is a common question among infiniti forums and the solution is to check the brake fluid level and/or change pads.
Old Mar 10, 2010 | 09:56 AM
bgsm1th's Avatar
Base on MY previous experience as a 3-time Infiniti owner, it could very well be an ABS or Speed sensor...
With that said, check the easy stuff first as Mr. Deeno and I have suggested.
Oh, and I was able to pull that ABS sensor code with my ODBII scanner as well.
Old Mar 12, 2010 | 09:06 PM
Sorry the pictures don't load anymore, went over my damn bandwidth on PB
Dad finally took the G to the shop this morning. He needed brake fluid and brand new rotors and pads up front. About $600
Old Mar 12, 2010 | 11:30 PM
mrdeeno's Avatar
Well, that answers the question.
Was it an infiniti dealer he took it to or an independent shop? Brake jobs are routine (i do mine myself), but dealers charge a crapload for them.
Old Mar 13, 2010 | 12:53 AM
Majofo's Avatar
$600 for a brake job.. damn.
Old Mar 13, 2010 | 01:01 AM
tmnhs81's Avatar
Man, if you were any closer I would have done it for the parts only... $600 is just ridiculous..
Old Mar 13, 2010 | 08:16 AM
Pricey I know, but it was done by a local trusted mechanic. They work on all 3 of our cars and they are legit, no bullshitters.
My dad had some other things done there as well besides the brake job. He got his oil changed, tires rotated, and a cracking belt replaced. So I guess it wasn't $600 just for the brakes, it was $600 including everything else that was done.
Old Mar 13, 2010 | 12:45 PM
subinf's Avatar
That still is a lot of cash but I understand
Old Mar 13, 2010 | 12:51 PM
It is, but he had other things done besides the brakes. I'm just glad those lights don't constantly stay on. Plus the car doesn't sound like a school bus every time it stops now
Old Mar 13, 2010 | 05:52 PM
Shoofin's Avatar
Though it does sound a little expensive. $600 would make more sense if it was rotors and pads all around, still pricey even for all four corners though...
Old Mar 13, 2010 | 08:52 PM
Yea it was pricey, but he had other regular maintenance done as well. The shop is great and I know they wouldn't bullshit us for no reason.
Old Mar 18, 2010 | 12:31 AM
StreetKA's Avatar
my friend had the same problem when he changed the tires for different aspec ratio... went to the dealer they said that ABS module down... but it wasnt... just the tires
Old Mar 18, 2010 | 09:21 AM
^Hm that's weird.
The place we take our cars to said that Infiniti and other manufacturers program the car to make all of the problem lights come on the dash so it gets the drivers attention quicker, no matter what the problem is.
My dad just needed a brake job, your friend used different tires. I guess that's just the car being smarter than we are
Old Apr 16, 2010 | 08:52 AM
gearheadred's Avatar
that is a hefty chunk of change.
check out downloading a repair manual from somewhere like
www.repairmanualdownloads.com
they have a whole section of acura repair manual downloads
http://www.repairmanualdownloads.com/dirbrowse-22.htm
Old Apr 16, 2010 | 09:32 AM
phee's Avatar
I got the Shifts
that annoys me to no end. people pay outrageous prices for a "trusted mechanic" or a "friend of the family"
if he was such a good guy he wouldnt be stretching your asshole.
/rant
glad its fixed
