Fuel Injection cleaner
Old Dec 16, 2010 | 09:32 AM
cabanalane's Avatar
The instructions said "Up to 21 gallons."
If my truck holds 20 gallons, I use the entire bottle.
If my civic only holds 11 gallons, should I use half a bottle? Or use the entire bottle?
"Up to...." is not clear to me.
Is there any harm in it being more concentrated? Using Bleach as an example. It can make your white shirt whiter. But too much of it will burn a hole in your shirt.
Old Dec 16, 2010 | 09:33 AM
NSXNEXT's Avatar
Moved
Old Dec 16, 2010 | 09:34 AM
NSXNEXT's Avatar
What do the instructions say?
I've always just dumped the whole bottle in and never looked at the reqt's
Old Dec 16, 2010 | 10:02 AM
cabanalane's Avatar
"Up to...." That's why I'm asking the question.
Old Dec 16, 2010 | 11:04 AM
S A CHO's Avatar
That was uncalled for...
It means that single bottle of treatment is effective from 1 gallon UP TO 21 gallons... I wouldn't really advise using 1 whole bottle for 1 gallon though
Old Dec 16, 2010 | 11:10 AM
dallison's Avatar
registered pw
I would wait until the tank is close to mt and then dump it in. I haven't done that in a long time and have no idea if it would actually hurt the motor.
Old Dec 16, 2010 | 12:01 PM
cabanalane's Avatar
Correct. So how about 2 gallons, or 3 gallons, or 8 gallons. I hope you guys are understanding my question.
Old Dec 16, 2010 | 12:35 PM
NSXNEXT's Avatar
Use the entire bottle with a full tank of gas in your Civic
fsttyms1's Avatar
And S A CHO pretty much answered it. It can be used from 1-21 gallons. I have always added it (seafoam) when i had about 1/4 tank and ran it to E before filling up
Old Dec 16, 2010 | 01:06 PM
S A CHO's Avatar
We all completely understand the question, you're not understanding our answers.
Here, I'll simplify this for you; Step 1) Fill gas tank. Step 2) Pour in entire bottle of injector cleaner.
It really is that simple.
Old Dec 16, 2010 | 01:53 PM
NSXNEXT's Avatar
Shouldn't he call Paypal first?
Old Dec 16, 2010 | 02:06 PM
dallison's Avatar
registered pw
He may want to speak to whiskers first
Old Dec 16, 2010 | 02:11 PM
cabanalane's Avatar
That is the answer, and it's what I've always done. So that should be it.
What I was hoping for is an answer as to the different levels of concentration would have an positive or negative effect.
Let me use the same example. Both with full tank of gas.
Would it clean the Civic better (because it'll be more concentrated due to a smaller tank)? On a truck with a 20 gallon tank, the cleaner would be less concentrated, therefore less effective?
P.S. Before anyone think I'm trying to waste your time, do a web search on Techron. There are people that have said if used in too high of a concentration, that it sometimes burns or damages the sock in the fuel tank.
Just hoping to ask here incase there are experts here.
Old Dec 31, 2010 | 08:42 AM
bartruffian's Avatar
9th Gear
fuel injector service
just got back from deaLER...and they suggested about 6 different things; replacing the tranns fluid because it is "burnt" $85, repl air and cabin filters $118, and "JB6" fuel injector cleaner service for $119.
Does the FI svc make sense? worth doing at dealer???
thx
2005 TL
80K mi
Old Dec 31, 2010 | 08:59 AM
dallison's Avatar
registered pw
Do the filters yourself for half the cost. I would check the color of the fluid to see if it's actually burnt. Use a bottle of tecron (sic)
Old Dec 31, 2010 | 10:31 AM
csmeance's Avatar
Redline SI-1 is one of the best fuel cleaners on the market! Dump the whole bottle in your gas tank and refill your tank to full. Drive around and your done!
The filters can be changed yourself, you can buy then for 20 dollars each and install them in less than 20 minutes and save a ton of money.
As far as the transmission fluid goes, pull out the dipstick and wipe it on a towel, check the color. It should be a pinkish red. If it is brown or black it is indeed burnt! Your best be would be to use a better transmission fluid such as Redline...
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
